path: root/doc/user/overview.t (follow)
* 2001-01-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-171-1/+1
* Changed copyright date to 1999.Joel Sherrill1999-11-161-1/+1
* Enabled images. They appear to work ok for PostScript but not as wellJoel Sherrill1999-10-061-1/+1
| | | | for PDF -- at least according to ghostview.
* Corrected a typo.Joel Sherrill1999-10-061-20/+22
* Nodes, menus, etc are automatically generated nowJoel Sherrill1998-03-271-52/+1
* Updated copyrightsJoel Sherrill1998-02-061-1/+1
* added CVS Id stringJoel Sherrill1997-06-041-0/+2
* final corrections before 4.1.0 documentation freeze.Joel Sherrill1997-06-041-1/+1
* Changed bitwise OR's used to build up option and attribute setsJoel Sherrill1997-05-311-3/+3
| | | | | | | | to be correct in either C or Ada. Added the interrupt disable, enable, flash, and is in progress directives. changed "97" to "1997"
* fixed typosJoel Sherrill1997-05-301-2/+2
* first cut at Ada bindings manualJoel Sherrill1997-05-291-3/+4
* Initial revisionJoel Sherrill1997-05-271-0/+578
