* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 1 | -3/+0 |
* | 2010-06-16 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-06-16 | 1 | -1/+16 |
| | | | | | PR 1568/doc * user/intr.t: Fix list of services callable from ISR. | ||||
* | 2009-02-27 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-02-27 | 1 | -7/+20 |
| | | | | | | PR 1387/doc * user/intr.t: Add Interrupt Manager services to list of services callable from ISR. | ||||
* | Convert to "bool". | Ralf Corsepius | 2008-09-09 | 1 | -1/+1 |
* | 2008-08-04 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-08-04 | 1 | -11/+20 |
| | | | | | PR 1288/doc * user/intr.t: Update callable from ISR section. | ||||
* | 2008-04-16 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-04-16 | 1 | -3/+3 |
| | | | | | | * user/bsp.t, user/conf.t, user/init.t, user/intr.t, user/overview.t, user/timer.t: Correct default values. Make it clear that confdefs.h calculates the memory required for you. | ||||
* | 2007-10-25 Glenn Humphrey <glenn.humphrey@OARcorp.com> | Glenn Humphrey | 2007-10-25 | 1 | -14/+5 |
| | | | | | | | * user/barrier.t, user/clock.t, user/concepts.t, user/cpuuse.t, user/init.t, user/intr.t, user/io.t, user/mp.t, user/rtmon.t, user/sem.t, user/stackchk.t, user/task.t, user/timer.t: Updated the Ada documentation to reflect the current binding. | ||||
* | 2002-03-27 Eric Norum <eric.norum@usask.ca> | Joel Sherrill | 2002-03-28 | 1 | -6/+1 |
| | | | | | * intr.t: Per PR165, now correctly states that passing a NULL pointer for the return argument is an error. | ||||
* | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-01-17 | 1 | -1/+1 |
| | | | | | | | * SUPPORT, LICENSE: New files. * Numerous files touched as part of merging the 4.5 branch onto the mainline development trunk and ensuring that the script that cuts snapshots and releases works on the documentation. | ||||
* | Numerous changes based on comments from Stephan Wilms <Stephan.Wilms@CWA.de> | Joel Sherrill | 2000-05-04 | 1 | -1/+8 |
| | | | | | | including a new section in the Getting Started called "Where to Go From Here", lots of index entries added, and more configuration table information. | ||||
* | Changed copyright date to 1999. | Joel Sherrill | 1999-11-16 | 1 | -1/+1 |
* | Turned on concept and function name indexing. | Joel Sherrill | 1999-10-11 | 1 | -6/+37 |
* | Corrected a typo. | Joel Sherrill | 1999-10-06 | 1 | -1/+1 |
* | Changed rtems_isr_level to rtems_interrupt_level per Chris Johns' | Joel Sherrill | 1999-10-01 | 1 | -3/+3 |
| | | | | <ccj@acm.org> suggestion. | ||||
* | Clarified catch and disable per suggestion from Chris Johns <ccj@acm.org>. | Joel Sherrill | 1999-10-01 | 1 | -0/+10 |
* | Added "findex" for all directive pages but it turns out that this | Joel Sherrill | 1998-04-02 | 1 | -0/+5 |
| | | | | blows up both makeinfo and texi2dvi. So I have commented them out. | ||||
* | Nodes, menus, etc are automatically generated now | Joel Sherrill | 1998-03-27 | 1 | -78/+3 |
* | Completed sweep adding directive and constant prefixes. | Joel Sherrill | 1998-03-27 | 1 | -8/+12 |
* | Conditionally adding RTEMS_ and rtems_ prefixes. | Joel Sherrill | 1998-03-27 | 1 | -13/+13 |
* | Attempting to add variable so that in C all constants start with RTEMS_ | Joel Sherrill | 1998-03-27 | 1 | -5/+5 |
| | | | | and all directives start with rtems_. | ||||
* | Updated copyrights | Joel Sherrill | 1998-02-06 | 1 | -1/+1 |
* | minor updates .. mostly version | Joel Sherrill | 1998-01-23 | 1 | -1/+1 |
* | added CVS Id string | Joel Sherrill | 1997-06-04 | 1 | -0/+2 |
* | final corrections before 4.1.0 documentation freeze. | Joel Sherrill | 1997-06-04 | 1 | -2/+6 |
* | Changed bitwise OR's used to build up option and attribute sets | Joel Sherrill | 1997-05-31 | 1 | -4/+168 |
| | | | | | | | | to be correct in either C or Ada. Added the interrupt disable, enable, flash, and is in progress directives. changed "97" to "1997" | ||||
* | fixed typos | Joel Sherrill | 1997-05-30 | 1 | -2/+2 |
* | first cut at Ada bindings manual | Joel Sherrill | 1997-05-29 | 1 | -4/+26 |
* | Initial revision | Joel Sherrill | 1997-05-27 | 1 | -0/+300 |
