path: root/doc/user/Makefile (follow)
* Changed copyright date to 1999.Joel Sherrill1999-11-161-1/+1
* Added task variable services.Joel Sherrill1999-11-161-1/+1
* Formatting improvements.Joel Sherrill1999-10-251-1/+1
* Added files generated by index process to clean stanza.Joel Sherrill1999-10-111-1/+3
* Turned on concept and function name indexing.Joel Sherrill1999-10-111-5/+9
* Remove $(PROJECT).pdf not *.pdf. We were accidentally removing theJoel Sherrill1999-10-071-1/+2
| | | | | | pdf version of figures. Added convert stanza to generate pdf's from eps of figures.
* Cleaned up use of $(PROJECT) instead of hard-coding c_user.Joel Sherrill1999-10-071-3/+5
| | | | Added rule to convert rtemspie.eps to .pdf.
* Enabled images. They appear to work ok for PostScript but not as wellJoel Sherrill1999-10-061-1/+1
| | | | for PDF -- at least according to ghostview.
* Numerous minor changes required to transition to the latest versionJoel Sherrill1999-10-011-3/+9
| | | | | of texinfo and TeX. This version of the tools can produce PDF with figures included.
* Removed concept of distribution level.Joel Sherrill1999-07-031-1/+0
* Went back to not printing an index. makeinfo does fine if you have indicesJoel Sherrill1998-04-021-4/+4
| | | | but do not print them. texi2dvi barfs if the entries are even there.
* Making the stanza right and improving the way the isntall directories are builtJoel Sherrill1998-03-301-15/+7
* Corrected distribution levels for htmlJoel Sherrill1998-03-301-2/+2
* Added distribution level to each manualJoel Sherrill1998-03-301-2/+3
* Added dependency so html would build from scratch.Joel Sherrill1998-03-271-1/+1
* Nodes, menus, etc are automatically generated nowJoel Sherrill1998-03-271-1/+127
* Updated copyrightsJoel Sherrill1998-02-061-1/+1
* added CVS Id stringJoel Sherrill1997-06-041-0/+2
* Initial revisionJoel Sherrill1997-05-271-0/+59
