path: root/doc/user/Makefile (follow)
* Patch rtemsdoc-4.5.0-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-04-261-194/+0
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | which contains the bulk of converting the documentation tree to automake and GNU conventions. Comments follow: This is the automake port of rtemsdoc. To apply: cvs co rtemsdoc cd rtemsdoc sh cvs-rm.sh patch -p0 < rtemsdoc-4.5.0-rc-0.diff sh cvs-add.sh [Attention: cvs-rm.sh and cvs-add.sh directly modify cvs] Known bugs: 1) src2html is not supported (yet? - Is this supposed to work?) 2) all *.pdf images now are generated on-the-fly, but not yet deleted during "make distclean" 3) All supplements, including the templated ones, get build and installed. 4) Building outside of the source tree is completely untested and very likely does not work. 5) Make [ps|pdf] are not (yet) supported, make [dvi|info] are supported by automake's default texinfo rules. Fixing 2, 3 and 5 is almost trivial and needs to be done. 4) is a matter of testing and tool-properties, for now it is simply untested. General issues: * gif vs jpg vs png. I would recommend to replace all images with pngs to avoid potential copyright issues (gif) or lack in quality (jpg, jpg is good for real world photographs, but extremely poor on artificial images, graphs). * pdf images do net get placed correctly in pdf-documents. * texinfo: We now use a local copy of texinfo-4.0's texinfo.tex in texinfo/texinfo.tex for generating infos. However pdftex's system-wide texinfo.tex and pdftexinfo.tex are used for generating *.dvi, *.ps, *.pdf. * .cvsignore files still missing. * I have renamed the supplements filename not to use c_<supplement>, because automake seems to have problems with it. Notes: * Again, I recommend not to put any generated files into CVS. Here, this comprises some *texi, all *.pdf and many *.html pages. Ie. I recommend to run make maintainer-clean before checking in any files. * To get building started, this should be sufficient: ./bootstrap ./configure cd tools; make; cd .. make info * To make a public tarball: [cvs co ; ./bootstrap] ./configure cd tools; make; cd .. make info [make clean] make dist => This generates a rtems-<version>.tar.gz in the toplevel directory. => Building the tools only is required after a "cvs co", but not in a distribution tarball.
* Changed copyright date to 1999.Joel Sherrill1999-11-161-1/+1
* Added task variable services.Joel Sherrill1999-11-161-1/+1
* Formatting improvements.Joel Sherrill1999-10-251-1/+1
* Added files generated by index process to clean stanza.Joel Sherrill1999-10-111-1/+3
* Turned on concept and function name indexing.Joel Sherrill1999-10-111-5/+9
* Remove $(PROJECT).pdf not *.pdf. We were accidentally removing theJoel Sherrill1999-10-071-1/+2
| | | | | | pdf version of figures. Added convert stanza to generate pdf's from eps of figures.
* Cleaned up use of $(PROJECT) instead of hard-coding c_user.Joel Sherrill1999-10-071-3/+5
| | | | Added rule to convert rtemspie.eps to .pdf.
* Enabled images. They appear to work ok for PostScript but not as wellJoel Sherrill1999-10-061-1/+1
| | | | for PDF -- at least according to ghostview.
* Numerous minor changes required to transition to the latest versionJoel Sherrill1999-10-011-3/+9
| | | | | of texinfo and TeX. This version of the tools can produce PDF with figures included.
* Removed concept of distribution level.Joel Sherrill1999-07-031-1/+0
* Went back to not printing an index. makeinfo does fine if you have indicesJoel Sherrill1998-04-021-4/+4
| | | | but do not print them. texi2dvi barfs if the entries are even there.
* Making the stanza right and improving the way the isntall directories are builtJoel Sherrill1998-03-301-15/+7
* Corrected distribution levels for htmlJoel Sherrill1998-03-301-2/+2
* Added distribution level to each manualJoel Sherrill1998-03-301-2/+3
* Added dependency so html would build from scratch.Joel Sherrill1998-03-271-1/+1
* Nodes, menus, etc are automatically generated nowJoel Sherrill1998-03-271-1/+127
* Updated copyrightsJoel Sherrill1998-02-061-1/+1
* added CVS Id stringJoel Sherrill1997-06-041-0/+2
* Initial revisionJoel Sherrill1997-05-271-0/+59
