* user/.cvsignore: Add semaphore_attributes.pdf.
* user/.cvsignore: Add Object ID PDF files.
* user/.cvsignore: Add chains.texi.
* user/.cvsignore, user/Makefile.am, user/c_user.texi, user/concepts.t,
user/conf.t, user/dirstat.texi, user/stackchk.t, user/task.t,
user/userext.t: Add new Object Services collection. Tidy up some
configuration documentation from earlier changes.
* user/object.t: New file.
* user/.cvsignore, user/cpuuse.t, user/stackchk.t: Stack checker and
CPU usage chapters are now OK in the manual.
* user/.cvsignore: Update.
* stamp-vti: Remove from CVS.
Add stamp-vti.
Re-sort.
Ralf's comments follow:
* Enhanced versioning:
- Abandoning setup.texi.in
files (stamp-vti)).
* Fixing info dir support
* Avoid using temporary files
are very close to it.
It addresses:
and writes to stdio.
cd rtemsdoc
cvs rm -f bsp_howto/network.t
cvs add tools/bmenu/bmenu2.c
./bootstrap
