* | Merger from rtems-4-6-branch | Ralf Corsepius | 2003-05-22 | 22 | -12/+56 |
* | 2003-01-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-01-28 | 2 | -0/+42 |
| | | | | * .cvsignore: New file. | ||||
* | 2003-01-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-25 | 2 | -1/+5 |
| | | | | * template.texi: Set @setfilename template.info. | ||||
| | | | | * sparc.texi: Set @setfilename sparc.info. | ||||
| | | | | * sh.texi: Set @setfilename sh.info. | ||||
| | | | | * powerpc.texi: Set @setfilename powerpc.info. | ||||
| | | | | * mips64orion.texi: Set @setfilename mips64orion.info. | ||||
| | | | | * mips.texi: Set @setfilename mips.info. | ||||
| | | | | * m68k.texi: Set @setfilename m68k.info. | ||||
| | | | | * i960.texi: Set @setfilename i960.info. | ||||
| | | | | * i386.texi: Set @setfilename i386.info. | ||||
| | | | | * hppa1_1.texi: Set @setfilename hppa1_1.info. | ||||
| | | | | * c4x.texi: Set @setfilename c4x.info. | ||||
| | | | | * arm.texi: Set @setfilename arm.info. | ||||
* | 2003-01-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-25 | 2 | -1/+16 |
| | | | | * Makefile.am: Add c4x, cosmetical changes. | ||||
* | 2003-01-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-25 | 5 | -23/+131 |
| | | | | | | * Makefile.am: New. * c4x.texi, cpumodel.t, timeBSP.t: Various minor changes to get them building. | ||||
* | 2003-01-24 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-01-24 | 12 | -0/+1378 |
| | | | | | | * BSP_TIMES, bsp.t, c4x.texi, callconv.t, cpumodel.t, cputable.t, fatalerr.t, intr_NOTIMES.t, memmodel.t, preface.texi, timeBSP.t: New files. These should have been added long ago. | ||||
* | 2003-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-24 | 2 | -4/+4 |
| | | | | * supplements.am: Remove AM_MAKEINFOFLAGS, TEXI2DVI, TEXI2PDF. | ||||
* | 2003-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-24 | 22 | -111/+155 |
| | | | | * Makefile.am: Put GENERATED_FILES into $builddir. | ||||
* | 2003-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-23 | 2 | -3/+8 |
| | | | | | * supplements.am: Use automake rules to build ps, pdf, info. Various minor changes. | ||||
* | 2003-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-22 | 44 | -162/+184 |
| | | | | | | | | * version.texi: Remove from CVS. * stamp-vti: Remove from CVS. * .cvsignore: Add version.texi. Add stamp-vti. Re-sort. | ||||
* | 2003-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-22 | 3 | -897/+5 |
| | | | | | * wksheets.texi: Remove from CVS. * timing.texi: Remove from CVS. | ||||
* | 2003-01-21 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-01-21 | 33 | -44/+88 |
| | | | | * stamp-vti, version.texi: Regenerated. | ||||
* | 2002-12-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-12-08 | 2 | -1/+5 |
| | | | | * supplement.am: Append -I $(topsrc_dir) to AM_MAKEINFOFLAGS. | ||||
* | 2002-11-13 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-13 | 33 | -44/+88 |
* | 2002-11-13 Jay Monkman <jtm@smoothsmoothie.com> | Joel Sherrill | 2002-11-13 | 2 | -123/+53 |
| | | | | * intr_NOTIMES.t: Real version submitted. | ||||
* | 2002-10-24 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-10-24 | 33 | -44/+88 |
* | 2002-08-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-08-02 | 3 | -278/+284 |
| | | | | | | * BSP_TIMES, wksheets.texi: Updated to reflect ARM times reported by Jay Monkman <jmonkman@adventnetworks.com>. These times are subject to change as he tunes the ARM port and their BSP. | ||||
* | 2002-07-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-07-31 | 2 | -1/+5 |
| | | | | * Makefile.am: Added arm subdirectory. | ||||
* | 2002-07-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-07-31 | 9 | -27/+51 |
| | | | | * intr_NOTIMES.t, timeBSP.t: Replaced XXX's with real info. | ||||
* | 2002-07-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-07-31 | 4 | -28/+37 |
| | | | | | * .cvsignore: Corrected some errors. * intr_NOTIMES.t, timeBSP.t: Replaced XXX's with real info. | ||||
* | 2002-07-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-07-31 | 3 | -8/+20 |
| | | | | * timeMVME136.t, timedata.t: Replaced XXX's with real info. | ||||
* | 2002-07-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-07-31 | 2 | -13/+17 |
| | | | | | * callconf.t: Added some markups for fonts and clarified some places. | ||||
* | 2002-07-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-07-30 | 20 | -44/+44 |
| | | | | | * stamp-vti, verstion.texi: Regenerated. | ||||
* | 2002-07-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-07-30 | 2 | -17/+22 |
| | | | | * .cvsignore: Corrected by tailoring for the ARM. | ||||
* | 2002-07-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-07-30 | 2 | -0/+39 |
* | 2002-07-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-07-30 | 17 | -0/+2175 |
| | | | | | | | * BSP_TIMES, ChangeLog, Makefile.am, arm.texi, bsp.t, callconv.t, cpumodel.t, cputable.t, fatalerr.t, intr_NOTIMES.t, memmodel.t, preface.texi, stamp-vti, timeBSP.t, timing.texi, version.texi, wksheets.texi: New files as ARM supplement initial version added. | ||||
* | BSPDIR=/opt/rtems/powerpc-rtems/mcp750/lib/include | Joel Sherrill | 2002-07-26 | 2 | -1/+6 |
| | | | | | | | | | | | | | | CPUDIR=/opt/rtems/powerpc-rtems/include cd $BSPDIR find . -name "*.h" | while read f do if [ -r ${CPUDIR}/${f} ] ; then echo Conflict on ${f} fi done | ||||
* | 2002-06-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-06-28 | 2 | -0/+75 |
| | | | | | * intr_NOTIMES.t: Per PR70 incorporate the posting by Zoltan Kocsi <zoltan@bendor.com.au> explaining a m68k vectoring trick. | ||||
* | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-03-28 | 22 | -11/+44 |
| | | | | * Makefile.am: Remove AUTOMAKE_OPTIONS. | ||||
* | 2001-03-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-03-01 | 2 | -0/+40 |
* | 2001-02-14 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-02-14 | 2 | -1/+5 |
| | | | | * mips: New supplement. | ||||
* | 2002-02-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-02-14 | 15 | -0/+1278 |
| | | | | | | * bsp.t, BSP_TIMES, callconv.t, ChangeLog, cpumodel.t, cputable.t, fatalerr.t, intr_NOTIMES.t, Makefile.am, memmodel.t, mips.texi, preface.texi, stamp-vti, timeBSP.t, version.texi: New files. | ||||
* | regenerated | Joel Sherrill | 2002-01-20 | 18 | -36/+54 |
* | 2002-01-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-01-20 | 20 | -37/+41 |
| | | | | * supplement.am: Replace TEXI_COMMON with AM_MAKEINFOFLAGS. | ||||
* | 2002-01-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-01-18 | 20 | -10/+50 |
| | | | | * Makefile.am: Require automake-1.5. | ||||
* | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-01-17 | 18 | -0/+54 |
| | | | | * .cvsignore: Added rtems_header.html and rtems_footer.html. | ||||
* | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-01-17 | 119 | -137/+146 |
| | | | | | | | * SUPPORT, LICENSE: New files. * Numerous files touched as part of merging the 4.5 branch onto the mainline development trunk and ensuring that the script that cuts snapshots and releases works on the documentation. | ||||
* | Adding ChangeLogs. | Joel Sherrill | 2000-08-25 | 10 | -0/+30 |
* | Patch rtemsdoc-4.5.0-rc-13-cvs.diff.gz from Ralf Corsepius | Joel Sherrill | 2000-06-14 | 10 | -9/+3 |
| | | | | | | | | <corsepiu@faw.uni-ulm.de> which: * should fix the building rtemsdoc outside of the sourcetree with relative srcdir issue * adds --enable-papersize=[letter|a4|] |
