* | Numerous minor changes required to transition to the latest version | Joel Sherrill | 1999-10-01 | 2 | -3/+8 |
| | | | | | of texinfo and TeX. This version of the tools can produce PDF with figures included. | ||||
* | Removed concept of distribution level. | Joel Sherrill | 1999-07-03 | 1 | -1/+0 |
* | Applied updates from remote work while doing class. | Joel Sherrill | 1998-11-19 | 1 | -14/+12 |
* | Moved things around so html and clean were above stanzas which generate | Joel Sherrill | 1998-10-19 | 1 | -17/+16 |
| | | | | chapters. | ||||
* | All of the Supplemental manuals are now generated as automatically | Joel Sherrill | 1998-10-19 | 1 | -3/+3 |
| | | | | as possible. | ||||
* | Renamed a lot and got as much as possible automatically generated. | Joel Sherrill | 1998-10-19 | 11 | -349/+91 |
* | Renamed. | Joel Sherrill | 1998-10-19 | 1 | -215/+0 |
* | Renamed | Joel Sherrill | 1998-10-19 | 3 | -1671/+0 |
* | Renamed memmodel.texi to memmodel.t. | Joel Sherrill | 1998-10-19 | 1 | -125/+0 |
* | Renamed fatalerr.texi to fatalerr.t. | Joel Sherrill | 1998-10-19 | 1 | -62/+0 |
* | Renamed cputable.texi to cputable.t. | Joel Sherrill | 1998-10-19 | 1 | -171/+0 |
* | Renamed cpumodel.texi to cpumodel.t. | Joel Sherrill | 1998-10-19 | 1 | -223/+0 |
* | Renamed callconv.texi to callconv.t. | Joel Sherrill | 1998-10-19 | 1 | -280/+0 |
* | Renamed bsp.texi to bsp.t. | Joel Sherrill | 1998-10-19 | 1 | -95/+0 |
* | Makefiles in much better shape even though not all files have automatically | Joel Sherrill | 1998-10-19 | 4 | -24/+43 |
| | | | | generated menus yet. | ||||
* | Worksheets now generated from a common file and the node info structure | Joel Sherrill | 1998-10-19 | 1 | -10/+26 |
| | | | | is generated automatically. | ||||
* | Added idle_task_stack_size field to CPU Table. | Joel Sherrill | 1998-10-12 | 2 | -0/+12 |
* | Made the description of timeing generation more accurate. | Joel Sherrill | 1998-08-20 | 2 | -8/+42 |
* | Changed wording to read better for PSIM. | Joel Sherrill | 1998-08-20 | 2 | -2/+2 |
* | New times. | Joel Sherrill | 1998-08-20 | 2 | -168/+169 |
* | Changed distribution level for this document. | Joel Sherrill | 1998-08-20 | 1 | -1/+1 |
* | New times for 4.0.0-lmco | Joel Sherrill | 1998-08-13 | 5 | -269/+278 |
* | New file | Joel Sherrill | 1998-08-13 | 1 | -0/+247 |
* | Added DMV177 times files and made this all regenerate with two timing | Joel Sherrill | 1998-08-13 | 10 | -59/+1726 |
| | | | | chapters. | ||||
* | Corrected paths after moving all supplements into a subdirectory. | Joel Sherrill | 1998-04-11 | 4 | -14/+14 |
* | Making the stanza right and improving the way the isntall directories are built | Joel Sherrill | 1998-03-30 | 1 | -15/+7 |
* | Corrected distribution levels for html | Joel Sherrill | 1998-03-30 | 1 | -1/+1 |
* | Added distribution level to each manual | Joel Sherrill | 1998-03-30 | 1 | -1/+3 |
* | Added variables for dates and revision info | Joel Sherrill | 1998-03-26 | 1 | -4/+4 |
* | updates | Joel Sherrill | 1998-02-11 | 15 | -649/+534 |
* | Updated copyrights | Joel Sherrill | 1998-02-06 | 19 | -19/+19 |
* | minor updates .. mostly version | Joel Sherrill | 1998-01-23 | 5 | -48/+51 |
* | Modified SPARC to PowerPC. Modified specific requirements to be | Jennifer Averett | 1997-12-02 | 2 | -14/+14 |
| | | | | for the PowerPC instead of the SPARC. | ||||
* | Added definations for serial_per_sec, serial_rate, and serial_xon_xoff. | Jennifer Averett | 1997-12-02 | 2 | -12/+12 |
* | Modified referances to SPARC to PowerPC. Updated the Information Table to | Jennifer Averett | 1997-12-02 | 2 | -12/+46 |
| | | | | | | | match the one in CPU.H. Added spurious_handler and exceptions_in_RAM items. Added definations for clicks_per_usec, spurious_handler,exceptions_in_RAM, serial_external_clock, serial_cts_rts, timer_average_overhead, and timer_least_valid. | ||||
* | Fixed node links. | Joel Sherrill | 1997-08-04 | 3 | -3/+3 |
* | Added more info. | Joel Sherrill | 1997-07-31 | 6 | -272/+276 |
* | Updated to the PowerPC. | Joel Sherrill | 1997-07-02 | 2 | -2/+70 |
* | updated to properly reflect powerpc | Joel Sherrill | 1997-07-02 | 6 | -228/+86 |
* | New files -- PowerPC supplement is based on the SPARC supplement. | Joel Sherrill | 1997-07-01 | 20 | -0/+3307 |
This version has had some initial work done to convert it to be PowerPC specific. |
