* | Patch rtemsdoc-4.5.0-rc-3.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>: | Joel Sherrill | 2000-05-01 | 2 | -41/+36 |
| | | | | | | | | | | | | | | | | | | | | | | | | | It addresses: * .cvsignore (only minor changes to yours, as they were pretty clean, most changes result from my mkcvsignore script being overly pedantic sorting entries alphabetically.) * timing.t handling and time<BSP>_.texi handling in supplements * network.t handling in bsp_howto * RTEMS_DATE and RTEMS_UPDATE handling in configure.in. [It actually is a hack, as we could apply automake's version.texi handling instead - I know think to understand what automake does with it.] * avoid using temporary files; Therefore a new tool called bmenu2, derived from bemenu, is introduced, which reads a single file from stdin and writes to stdio. To apply: cd rtemsdoc patch -p1 < rtemsdoc-4.5.0-rc-3.diff cvs rm -f bsp_howto/network.t cvs add tools/bmenu/bmenu2.c ./bootstrap BTW: word-replace now is unused. It could be removed if you like to. | ||||
* | New files. First attempt. | Joel Sherrill | 2000-04-27 | 1 | -0/+36 |
* | Removed -- temporary files. | Joel Sherrill | 2000-04-27 | 2 | -2878/+0 |
* | Patch rtemsdoc-4.5.0-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-04-26 | 5 | -185/+3014 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | which contains the bulk of converting the documentation tree to automake and GNU conventions. Comments follow: This is the automake port of rtemsdoc. To apply: cvs co rtemsdoc cd rtemsdoc sh cvs-rm.sh patch -p0 < rtemsdoc-4.5.0-rc-0.diff sh cvs-add.sh [Attention: cvs-rm.sh and cvs-add.sh directly modify cvs] Known bugs: 1) src2html is not supported (yet? - Is this supposed to work?) 2) all *.pdf images now are generated on-the-fly, but not yet deleted during "make distclean" 3) All supplements, including the templated ones, get build and installed. 4) Building outside of the source tree is completely untested and very likely does not work. 5) Make [ps|pdf] are not (yet) supported, make [dvi|info] are supported by automake's default texinfo rules. Fixing 2, 3 and 5 is almost trivial and needs to be done. 4) is a matter of testing and tool-properties, for now it is simply untested. General issues: * gif vs jpg vs png. I would recommend to replace all images with pngs to avoid potential copyright issues (gif) or lack in quality (jpg, jpg is good for real world photographs, but extremely poor on artificial images, graphs). * pdf images do net get placed correctly in pdf-documents. * texinfo: We now use a local copy of texinfo-4.0's texinfo.tex in texinfo/texinfo.tex for generating infos. However pdftex's system-wide texinfo.tex and pdftexinfo.tex are used for generating *.dvi, *.ps, *.pdf. * .cvsignore files still missing. * I have renamed the supplements filename not to use c_<supplement>, because automake seems to have problems with it. Notes: * Again, I recommend not to put any generated files into CVS. Here, this comprises some *texi, all *.pdf and many *.html pages. Ie. I recommend to run make maintainer-clean before checking in any files. * To get building started, this should be sufficient: ./bootstrap ./configure cd tools; make; cd .. make info * To make a public tarball: [cvs co ; ./bootstrap] ./configure cd tools; make; cd .. make info [make clean] make dist => This generates a rtems-<version>.tar.gz in the toplevel directory. => Building the tools only is required after a "cvs co", but not in a distribution tarball. | ||||
* | Changed copyright date to 1999. | Joel Sherrill | 1999-11-16 | 12 | -12/+12 |
* | Fixing many lines that are too long to format cleanly. | Joel Sherrill | 1999-10-25 | 1 | -2/+3 |
* | Cleaned up to install dvi, use native texi2dvi, etc.. | Joel Sherrill | 1999-10-11 | 1 | -5/+6 |
* | Remove $(PROJECT).pdf not *.pdf. We were accidentally removing the | Joel Sherrill | 1999-10-07 | 1 | -1/+1 |
| | | | | pdf version of figures. | ||||
* | Enabled table of contents generation so the left hand side of the PDF | Joel Sherrill | 1999-10-07 | 1 | -1/+1 |
| | | | | viewer can have section headings. | ||||
* | Numerous minor changes required to transition to the latest version | Joel Sherrill | 1999-10-01 | 2 | -3/+8 |
| | | | | | of texinfo and TeX. This version of the tools can produce PDF with figures included. | ||||
* | Removed concept of distribution level. | Joel Sherrill | 1999-07-03 | 1 | -1/+0 |
* | Applied updates from remote work while doing class. | Joel Sherrill | 1998-11-19 | 1 | -14/+12 |
* | Moved things around so html and clean were above stanzas which generate | Joel Sherrill | 1998-10-19 | 1 | -17/+16 |
| | | | | chapters. | ||||
* | All of the Supplemental manuals are now generated as automatically | Joel Sherrill | 1998-10-19 | 1 | -3/+3 |
| | | | | as possible. | ||||
* | Renamed a lot and got as much as possible automatically generated. | Joel Sherrill | 1998-10-19 | 11 | -349/+91 |
* | Renamed. | Joel Sherrill | 1998-10-19 | 1 | -215/+0 |
* | Renamed | Joel Sherrill | 1998-10-19 | 3 | -1671/+0 |
* | Renamed memmodel.texi to memmodel.t. | Joel Sherrill | 1998-10-19 | 1 | -125/+0 |
* | Renamed fatalerr.texi to fatalerr.t. | Joel Sherrill | 1998-10-19 | 1 | -62/+0 |
* | Renamed cputable.texi to cputable.t. | Joel Sherrill | 1998-10-19 | 1 | -171/+0 |
* | Renamed cpumodel.texi to cpumodel.t. | Joel Sherrill | 1998-10-19 | 1 | -223/+0 |
* | Renamed callconv.texi to callconv.t. | Joel Sherrill | 1998-10-19 | 1 | -280/+0 |
* | Renamed bsp.texi to bsp.t. | Joel Sherrill | 1998-10-19 | 1 | -95/+0 |
* | Makefiles in much better shape even though not all files have automatically | Joel Sherrill | 1998-10-19 | 4 | -24/+43 |
| | | | | generated menus yet. | ||||
* | Worksheets now generated from a common file and the node info structure | Joel Sherrill | 1998-10-19 | 1 | -10/+26 |
| | | | | is generated automatically. | ||||
* | Added idle_task_stack_size field to CPU Table. | Joel Sherrill | 1998-10-12 | 2 | -0/+12 |
* | Made the description of timeing generation more accurate. | Joel Sherrill | 1998-08-20 | 2 | -8/+42 |
* | Changed wording to read better for PSIM. | Joel Sherrill | 1998-08-20 | 2 | -2/+2 |
* | New times. | Joel Sherrill | 1998-08-20 | 2 | -168/+169 |
* | Changed distribution level for this document. | Joel Sherrill | 1998-08-20 | 1 | -1/+1 |
* | New times for 4.0.0-lmco | Joel Sherrill | 1998-08-13 | 5 | -269/+278 |
* | New file | Joel Sherrill | 1998-08-13 | 1 | -0/+247 |
* | Added DMV177 times files and made this all regenerate with two timing | Joel Sherrill | 1998-08-13 | 10 | -59/+1726 |
| | | | | chapters. | ||||
* | Corrected paths after moving all supplements into a subdirectory. | Joel Sherrill | 1998-04-11 | 4 | -14/+14 |
* | Making the stanza right and improving the way the isntall directories are built | Joel Sherrill | 1998-03-30 | 1 | -15/+7 |
* | Corrected distribution levels for html | Joel Sherrill | 1998-03-30 | 1 | -1/+1 |
* | Added distribution level to each manual | Joel Sherrill | 1998-03-30 | 1 | -1/+3 |
* | Added variables for dates and revision info | Joel Sherrill | 1998-03-26 | 1 | -4/+4 |
* | updates | Joel Sherrill | 1998-02-11 | 15 | -649/+534 |
* | Updated copyrights | Joel Sherrill | 1998-02-06 | 19 | -19/+19 |
* | minor updates .. mostly version | Joel Sherrill | 1998-01-23 | 5 | -48/+51 |
* | Modified SPARC to PowerPC. Modified specific requirements to be | Jennifer Averett | 1997-12-02 | 2 | -14/+14 |
| | | | | for the PowerPC instead of the SPARC. | ||||
* | Added definations for serial_per_sec, serial_rate, and serial_xon_xoff. | Jennifer Averett | 1997-12-02 | 2 | -12/+12 |
* | Modified referances to SPARC to PowerPC. Updated the Information Table to | Jennifer Averett | 1997-12-02 | 2 | -12/+46 |
| | | | | | | | match the one in CPU.H. Added spurious_handler and exceptions_in_RAM items. Added definations for clicks_per_usec, spurious_handler,exceptions_in_RAM, serial_external_clock, serial_cts_rts, timer_average_overhead, and timer_least_valid. | ||||
* | Fixed node links. | Joel Sherrill | 1997-08-04 | 3 | -3/+3 |
* | Added more info. | Joel Sherrill | 1997-07-31 | 6 | -272/+276 |
* | Updated to the PowerPC. | Joel Sherrill | 1997-07-02 | 2 | -2/+70 |
* | updated to properly reflect powerpc | Joel Sherrill | 1997-07-02 | 6 | -228/+86 |
* | New files -- PowerPC supplement is based on the SPARC supplement. | Joel Sherrill | 1997-07-01 | 20 | -0/+3307 |
This version has had some initial work done to convert it to be PowerPC specific. |
