* cpumodel.t: Obsoleting HP PA-RISC port and removing all references.
* m68k.texi: Merge from branch.
* m68k.texi: Set @setfilename m68k.info.
* stamp-vti: Remove from CVS.
Add stamp-vti.
Re-sort.
* timeMVME136.t, timedata.t: Replaced XXX's with real info.
CPUDIR=/opt/rtems/powerpc-rtems/include
cd $BSPDIR
find . -name "*.h" | while read f
do
if [ -r ${CPUDIR}/${f} ] ; then
echo Conflict on ${f}
fi
done
* intr_NOTIMES.t: Per PR70 incorporate the posting by
Zoltan Kocsi <zoltan@bendor.com.au> explaining a m68k vectoring trick.
* supplement.am: Replace TEXI_COMMON with AM_MAKEINFOFLAGS.
relative srcdir issue
Ralf's comments:
tree.
per sub-package.
Advantages (IMHO).
other *spec.ins
should not have changed.
To Apply:
cvs rm -f scripts/config.sub
cvs rm -f scripts/install-sh
cvs rm -f scripts/missing
cvs add scripts/*/*.add
cvs add scripts/*/README
Ralf's comments follow:
* Enhanced versioning:
- Abandoning setup.texi.in
files (stamp-vti)).
* Fixing info dir support
* Avoid using temporary files
are very close to it.
It addresses:
and writes to stdio.
cd rtemsdoc
cvs rm -f bsp_howto/network.t
cvs add tools/bmenu/bmenu2.c
./bootstrap
cvs co rtemsdoc
cd rtemsdoc
sh cvs-rm.sh
sh cvs-add.sh
Known bugs:
during "make distclean"
installed.
likely does not work.
untested.
General issues:
images, graphs).
./bootstrap
./configure
cd tools; make; cd ..
make info
* To make a public tarball:
[cvs co ; ./bootstrap]
./configure
make info
[make clean]
make dist
distribution tarball.
pdf version of figures.
viewer can have section headings.
figures included.
chapters.
as possible.
generated menus yet.
is generated automatically.
based on board model.
