* | Removed -- temporary files. | Joel Sherrill | 2000-04-27 | 1 | -1435/+0 |
* | Patch rtemsdoc-4.5.0-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-04-26 | 4 | -172/+1552 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | which contains the bulk of converting the documentation tree to automake and GNU conventions. Comments follow: This is the automake port of rtemsdoc. To apply: cvs co rtemsdoc cd rtemsdoc sh cvs-rm.sh patch -p0 < rtemsdoc-4.5.0-rc-0.diff sh cvs-add.sh [Attention: cvs-rm.sh and cvs-add.sh directly modify cvs] Known bugs: 1) src2html is not supported (yet? - Is this supposed to work?) 2) all *.pdf images now are generated on-the-fly, but not yet deleted during "make distclean" 3) All supplements, including the templated ones, get build and installed. 4) Building outside of the source tree is completely untested and very likely does not work. 5) Make [ps|pdf] are not (yet) supported, make [dvi|info] are supported by automake's default texinfo rules. Fixing 2, 3 and 5 is almost trivial and needs to be done. 4) is a matter of testing and tool-properties, for now it is simply untested. General issues: * gif vs jpg vs png. I would recommend to replace all images with pngs to avoid potential copyright issues (gif) or lack in quality (jpg, jpg is good for real world photographs, but extremely poor on artificial images, graphs). * pdf images do net get placed correctly in pdf-documents. * texinfo: We now use a local copy of texinfo-4.0's texinfo.tex in texinfo/texinfo.tex for generating infos. However pdftex's system-wide texinfo.tex and pdftexinfo.tex are used for generating *.dvi, *.ps, *.pdf. * .cvsignore files still missing. * I have renamed the supplements filename not to use c_<supplement>, because automake seems to have problems with it. Notes: * Again, I recommend not to put any generated files into CVS. Here, this comprises some *texi, all *.pdf and many *.html pages. Ie. I recommend to run make maintainer-clean before checking in any files. * To get building started, this should be sufficient: ./bootstrap ./configure cd tools; make; cd .. make info * To make a public tarball: [cvs co ; ./bootstrap] ./configure cd tools; make; cd .. make info [make clean] make dist => This generates a rtems-<version>.tar.gz in the toplevel directory. => Building the tools only is required after a "cvs co", but not in a distribution tarball. | ||||
* | Changed copyright date to 1999. | Joel Sherrill | 1999-11-16 | 11 | -11/+11 |
* | Cleaned up to install dvi, use native texi2dvi, etc.. | Joel Sherrill | 1999-10-11 | 1 | -5/+6 |
* | Remove $(PROJECT).pdf not *.pdf. We were accidentally removing the | Joel Sherrill | 1999-10-07 | 1 | -1/+1 |
| | | | | pdf version of figures. | ||||
* | Enabled table of contents generation so the left hand side of the PDF | Joel Sherrill | 1999-10-07 | 1 | -1/+1 |
| | | | | viewer can have section headings. | ||||
* | Numerous minor changes required to transition to the latest version | Joel Sherrill | 1999-10-01 | 2 | -3/+8 |
| | | | | | of texinfo and TeX. This version of the tools can produce PDF with figures included. | ||||
* | Removed concept of distribution level. | Joel Sherrill | 1999-07-03 | 1 | -1/+0 |
* | Applied updates from remote work while doing class. | Joel Sherrill | 1998-11-19 | 1 | -14/+12 |
* | Moved things around so html and clean were above stanzas which generate | Joel Sherrill | 1998-10-19 | 1 | -16/+15 |
| | | | | chapters. | ||||
* | All of the Supplemental manuals are now generated as automatically | Joel Sherrill | 1998-10-19 | 1 | -21/+5 |
| | | | | as possible. | ||||
* | Nearly everything that can be is now automatically generated. | Joel Sherrill | 1998-10-19 | 18 | -1183/+92 |
* | Makefiles in much better shape even though not all files have automatically | Joel Sherrill | 1998-10-19 | 6 | -21/+50 |
| | | | | generated menus yet. | ||||
* | Worksheets now generated from a common file and the node info structure | Joel Sherrill | 1998-10-19 | 1 | -10/+26 |
| | | | | is generated automatically. | ||||
* | Added idle_task_stack_size field to CPU Table. | Joel Sherrill | 1998-10-12 | 2 | -0/+12 |
* | Switched from presenting timing data based on CPU models to presenting it | Joel Sherrill | 1998-08-13 | 5 | -51/+52 |
| | | | | based on board model. | ||||
* | Added bswap feature. | Joel Sherrill | 1998-08-13 | 2 | -4/+30 |
* | Added text from Erik Ivanenko <erik.ivanenko@utoronto.ca> describing | Joel Sherrill | 1998-06-01 | 2 | -144/+172 |
| | | | | transition from real to protected mode and modified the spacing. | ||||
* | Corrected paths after moving all supplements into a subdirectory. | Joel Sherrill | 1998-04-11 | 4 | -14/+14 |
* | Making the stanza right and improving the way the isntall directories are built | Joel Sherrill | 1998-03-30 | 1 | -15/+7 |
* | Corrected distribution levels for html | Joel Sherrill | 1998-03-30 | 1 | -1/+1 |
* | Added distribution level to each manual | Joel Sherrill | 1998-03-30 | 1 | -1/+3 |
* | Added variables for dates and revision info | Joel Sherrill | 1998-03-26 | 1 | -4/+4 |
* | Updated copyrights | Joel Sherrill | 1998-02-06 | 19 | -19/+19 |
* | minor updates .. mostly version | Joel Sherrill | 1998-01-23 | 1 | -12/+5 |
* | Fixed wildcard in copy command. | Joel Sherrill | 1997-08-04 | 1 | -1/+1 |
* | Corrected bug in Makefile | Joel Sherrill | 1997-07-31 | 1 | -1/+1 |
* | corrected typos and changes LANGUAGE to RTEMS-LANGUAGE. | Joel Sherrill | 1997-07-31 | 2 | -4/+8 |
* | added CVS Id string | Joel Sherrill | 1997-06-04 | 20 | -0/+64 |
* | added CVS Id string | Joel Sherrill | 1997-06-04 | 1 | -0/+2 |
* | changed edition and version information | Joel Sherrill | 1997-06-04 | 1 | -2/+2 |
* | Changed bitwise OR's used to build up option and attribute sets | Joel Sherrill | 1997-05-31 | 1 | -2/+2 |
| | | | | | | | | to be correct in either C or Ada. Added the interrupt disable, enable, flash, and is in progress directives. changed "97" to "1997" | ||||
* | fixed typos | Joel Sherrill | 1997-05-30 | 3 | -10/+10 |
* | version changed | Joel Sherrill | 1997-05-28 | 1 | -2/+2 |
* | 4.0.0 release docs | Joel Sherrill | 1997-05-28 | 2 | -3/+3 |
* | Initial revision | Joel Sherrill | 1997-05-27 | 20 | -0/+2276 |
