Remove references to Cygnus
Fix issues introduced in previous edits
In PDF, DVI, and PostScript files, the contents of the @top
node were being printed. These are intended only for info
and html output formats.
See http://www.rtems.org/pipermail/rtems-devel/2013-February/002466.html
for instructions on how to do this.
Texinfo 5.0 is a complete reimplementation and has stricter
interpretations of the texinfo language.
for details.
PR 1793/doc
* .cvsignore, Makefile.am, README, configure.ac, index.html.in,
main.am, project.am, ada_user/.cvsignore, ada_user/ada_user.texi,
ada_user/example.texi, bsp_howto/.cvsignore,
bsp_howto/bsp_howto.texi, cpu_supplement/.cvsignore,
cpu_supplement/cpu_supplement.texi, cpu_supplement/preface.texi,
develenv/.cvsignore, develenv/develenv.texi, develenv/intro.texi,
filesystem/.cvsignore, filesystem/filesystem.texi,
filesystem/preface.texi, networking/.cvsignore,
networking/networking.texi, networking/preface.texi,
porting/.cvsignore, porting/porting.texi, porting/preface.texi,
posix1003.1/.cvsignore, posix1003.1/posix1003_1.texi,
posix_users/.cvsignore, posix_users/posix_users.texi,
posix_users/preface.texi, shell/.cvsignore, shell/preface.texi,
shell/shell.texi, started/.cvsignore, started/started.texi,
user/.cvsignore, user/c_user.texi, user/dirstat.texi,
user/example.texi, user/glossary.texi, user/preface.texi: Convert
from texi2www to texi2html.
* texi2html_init.in: New file.
* rtems_footer.html.in, rtems_header.html.in: Removed.
* ada_user/version.texi, bsp_howto/version.texi,
cpu_supplement/version.texi, develenv/version.texi,
filesystem/version.texi, networking/version.texi,
porting/version.texi, posix1003.1/version.texi,
posix_users/version.texi, shell/version.texi, started/version.texi,
user/version.texi: Update to match when files in directory where last
touched.
PR 1947/doc
* started/buildrt.t: Make note that native toolset is needed to
configure and build RTEMS.
* started/buildc.t, started/buildrt.t, started/nt.t, started/require.t,
started/sample.t: Review and improve.
* Makefile.am, configure.ac, common/cpright.texi, common/rtems.texi.in,
cpu_supplement/.cvsignore, started/Makefile.am, started/binaries.t,
started/buildc.t, started/buildrt.t, started/intro.t,
started/nextstep.t, started/nt.t, started/require.t,
started/sample.t, started/started.texi, started/version.texi: Major
update which includes removal of references to specific tool versions
and patches.
* started/tversions.texi.in: Removed.
* Makefile.am, configure.ac, index.html.in, develenv/direct.t,
posix_users/gen_size_report, started/nextstep.t,
started_ada/buildada.t, user/conf.t, user/object.t: Remove ITRON API.
* itron3.0/.cvsignore, itron3.0/Makefile.am, itron3.0/config.t,
itron3.0/eventflags.t, itron3.0/fixedblock.t, itron3.0/gen_all,
itron3.0/gen_section, itron3.0/gen_status_shell,
itron3.0/interrupt.t, itron3.0/itron.texi, itron3.0/mailbox.t,
itron3.0/memorypool.t, itron3.0/msgbuffer.t, itron3.0/network.t,
itron3.0/preface.texi, itron3.0/rendezvous.t, itron3.0/semaphore.t,
itron3.0/stamp-vti, itron3.0/status.t, itron3.0/task.t,
itron3.0/tasksync.t, itron3.0/time.t, itron3.0/version.texi: Removed.
* setup.def, started/buildc.t: Update.
* started/buildc.t: Add paragraph on see CVS for latest patches.
* user/conf.t: Add CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE and example
of how to compute message CONFIGURE_MESSAGE_BUFFER_MEMORY using it.
* ada_user/ada_user.texi, bsp_howto/bsp_howto.texi,
cpu_supplement/cpu_supplement.texi, develenv/develenv.texi,
filesystem/filesystem.texi, itron3.0/itron.texi,
networking/networking.texi, porting/porting.texi,
posix1003.1/posix1003_1.texi, posix_users/posix_users.texi,
rgdb_specs/rgdb_specs.texi, rtems_gdb/rtems_gdb.texi,
started/started.texi, started_ada/started_ada.texi, user/c_user.texi:
Print table of contents in front of manual where it should be when
you print.
* started/binaries.t, started/buildc.t, started/tversions.texi.in:
Various update to reflect current toolchains.
* posix_users/.cvsignore, rgdb_specs/.cvsignore, rtems_gdb/.cvsignore,
started/.cvsignore, started_ada/.cvsignore: Add more generated files.
* FAQ/basic.texi, FAQ/bsp.texi, FAQ/build45.texi, FAQ/concepts.texi,
FAQ/debug.texi, FAQ/endoftime.texi, FAQ/freesw.texi,
FAQ/hwdebugaids.texi, FAQ/projects.texi, FAQ/stamp-vti,
FAQ/tools.texi, FAQ/version.texi, bsp_howto/rtc.t, started/buildc.t,
started/buildrt.t, user/Makefile.am, user/region.t: Fix typos and
regenerate.
* configure.ac, index.html.in, FAQ/basic.t, FAQ/basic.texi, FAQ/entry,
porting/cpumodels.t, started/buildc.t, started_ada/buildada.t,
user/preface.texi: i960 obsoleted.
PR 681/doc
PR 682/doc
* buildc.t, buildrt.t, sample.t: Fix PATH and tar examples. Enable
binutils link again.
* user/overview.t: Chapter numbering in preface was wrong.
* started/buildc.t: Use tar xjf for bzip'ed files.
* started/buildrt.t: Use tar xjf to unzip rtems.
* started/tversions.texi: Remove (Bogus).
* HELP.html, index.html.in, rtems_footer.html.in, rtems_header.html.in,
FAQ/basic.t, gnu_docs/gnu_footer.html, gnu_docs/index.html,
gnu_docs/refcard.html, gnu_docs/rtems_tools_index.html,
started/binaries.t, started/buildc.t, started/buildrt.t,
started/intro.t, started/require.t, started/sample.t,
started/tversions.texi.in: Incorporating changes from pre-4.6.0
review.
* configure.ac: Add RTEMSRPMGROUP.
* common/rtems.texi.in: Add RTEMSRPMGROUP.
* started/binaries.t: Add RTEMSRPMGROUP.
* ChangeLog: Merge-in started/ChangeLog.
* started/ChangeLog: Remove.
* binaries.t, buildc.t: Use @value{RTEMSRPMPREFIX} in refs to rpms.
PR 555/doc
* sample.t: Fix RTEMS_MAKEFILE_PATH reference.
* Makefile.am: Add tversions.texi.in to EXTRA_DIST.
* Makefile.am: Cosmetics.
PR 513/doc
* started.texi: Rename to be non-language specific.
* Makefile.am, binaries.t, buildc.t, intro.t, nextstep.t, require.t,
sample.t, started.texi: General improvements and merge enough Ada
information to justify dropping the Ada specific manual. There is
likely still Ada specific information to merge though.
* nextstep.t: RTEMS applications can now use main() so correct the
discussion of this.
