* | 2003-09-26 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-26 | 1 | -316/+84 |
| | | | | | * nt.t: Significant update of Windows information. Hopefully this is now more useful. | ||||
* | 2003-09-19 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-19 | 1 | -1/+1 |
| | | | | | | * .cvsignore, binaries.t, buildc.t, buildrt.t, intro.t, nextstep.t, nt.t, started.texi: Merge from branch. * tversions.texi.in: New file. | ||||
* | 2003-08-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-27 | 1 | -11/+11 |
| | | | | | | * buildc.t, buildrt.t, nt.t, sample.t, tversions.texi: Don't use VARIABLEs containing '-' in @set and @value (violates texi-syntax). | ||||
* | 2002-11-13 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-13 | 1 | -3/+3 |
| | | | | | | * Makefile.am, buildc.t, buildrt.t, nt.t, require.t, tversions.texi: Removed all references to bit scripts. * gdb.t: Removed. | ||||
* | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-01-17 | 1 | -58/+81 |
| | | | | | | | * SUPPORT, LICENSE: New files. * Numerous files touched as part of merging the 4.5 branch onto the mainline development trunk and ensuring that the script that cuts snapshots and releases works on the documentation. | ||||
* | Purged as many egcs references as possible. | Joel Sherrill | 2000-06-10 | 1 | -2/+2 |
* | Updated NT editor information to update status on PFE and add | Joel Sherrill | 2000-05-09 | 1 | -6/+24 |
| | | | | pointers to emacs and vim. | ||||
* | Modifed to avoid using @uref directive since that does not seem | Joel Sherrill | 2000-05-04 | 1 | -4/+8 |
| | | | | to work with pdf generation. | ||||
* | Numerous changes based on comments from Stephan Wilms <Stephan.Wilms@CWA.de> | Joel Sherrill | 2000-05-04 | 1 | -5/+5 |
| | | | | | | including a new section in the Getting Started called "Where to Go From Here", lots of index entries added, and more configuration table information. | ||||
* | Modified to correct references to gmake per comment from Stephan Wilms | Joel Sherrill | 2000-05-02 | 1 | -1/+1 |
| | | | | <Stephan.Wilms@CWA.de>. | ||||
* | Changed copyright date to 1999. | Joel Sherrill | 1999-11-16 | 1 | -1/+1 |
* | Numerous minor changes required to transition to the latest version | Joel Sherrill | 1999-10-01 | 1 | -24/+4 |
| | | | | | of texinfo and TeX. This version of the tools can produce PDF with figures included. | ||||
* | fixes from David Fiddes | Joel Sherrill | 1998-10-27 | 1 | -8/+6 |
* | Update from David Fiddes. | Joel Sherrill | 1998-10-27 | 1 | -108/+83 |
* | Now builds for all formats and includes urls | Joel Sherrill | 1998-04-14 | 1 | -5/+29 |
* | Comments from Geoffroy Montel | Joel Sherrill | 1998-04-14 | 1 | -9/+26 |
* | Now builds for all formats. | Joel Sherrill | 1998-04-13 | 1 | -8/+8 |
| | | | | Updated to include Steve's figures for the first time. | ||||
* | Added Resources on the Internet section | Joel Sherrill | 1998-04-13 | 1 | -0/+4 |
* | New file based on Word document from Geoffroy Montel <g_montel@yahoo.com> | Joel Sherrill | 1998-04-13 | 1 | -0/+347 |
who was assisted by D.J.Fiddes@hw.ac.uk. |
