closes #2812.
* fix and remove some macros in rtems.texi.in.
* refer to devel mailing list.
* remove reference to Debian packaging in requirements section.
* remove section on prebuilt tools.
* replace toolset build instructions with link to RSB docs.
* Add a note in building RTEMS section about using RSB.
* Fix URLs
Closes #2291.
Remove references to Cygnus
Fix issues introduced in previous edits
PR 1947/doc
* started/buildrt.t: Make note that native toolset is needed to
configure and build RTEMS.
* started/buildc.t, started/buildrt.t, started/nt.t, started/require.t,
started/sample.t: Review and improve.
* Makefile.am, configure.ac, common/cpright.texi, common/rtems.texi.in,
cpu_supplement/.cvsignore, started/Makefile.am, started/binaries.t,
started/buildc.t, started/buildrt.t, started/intro.t,
started/nextstep.t, started/nt.t, started/require.t,
started/sample.t, started/started.texi, started/version.texi: Major
update which includes removal of references to specific tool versions
and patches.
* started/tversions.texi.in: Removed.
* FAQ/basic.texi, FAQ/bsp.texi, FAQ/build45.texi, FAQ/concepts.texi,
FAQ/debug.texi, FAQ/endoftime.texi, FAQ/freesw.texi,
FAQ/hwdebugaids.texi, FAQ/projects.texi, FAQ/stamp-vti,
FAQ/tools.texi, FAQ/version.texi, bsp_howto/rtc.t, started/buildc.t,
started/buildrt.t, user/Makefile.am, user/region.t: Fix typos and
regenerate.
PR 681/doc
PR 682/doc
* buildc.t, buildrt.t, sample.t: Fix PATH and tar examples. Enable
binutils link again.
* user/overview.t: Chapter numbering in preface was wrong.
* started/buildc.t: Use tar xjf for bzip'ed files.
* started/buildrt.t: Use tar xjf to unzip rtems.
* HELP.html, index.html.in, rtems_footer.html.in, rtems_header.html.in,
FAQ/basic.t, gnu_docs/gnu_footer.html, gnu_docs/index.html,
gnu_docs/refcard.html, gnu_docs/rtems_tools_index.html,
started/binaries.t, started/buildc.t, started/buildrt.t,
started/intro.t, started/require.t, started/sample.t,
started/tversions.texi.in: Incorporating changes from pre-4.6.0
review.
* .cvsignore, binaries.t, buildc.t, buildrt.t, intro.t, nextstep.t,
nt.t, started.texi: Merge from branch.
* tversions.texi.in: New file.
* buildc.t, buildrt.t, nt.t, sample.t, tversions.texi:
Don't use VARIABLEs containing '-' in @set and @value (violates
texi-syntax).
* Makefile.am, buildc.t, buildrt.t, nt.t, require.t, tversions.texi:
Removed all references to bit scripts.
* gdb.t: Removed.
binaries rather than unpacking everything.
including a new section in the Getting Started called "Where to
Go From Here", lots of index entries added, and more configuration
table information.
<Stephan.Wilms@CWA.de>.
Pictures now in ASCII.
were corrected as the Getting Started with GNAT/RTEMS manual was
created.
now in variables and some updates already in place.
