path: root/doc/started/buildrt.t (follow)
* Remove texinfo format documentation. Replaced by Sphinx formatted documentation.Joel Sherrill2017-01-111-192/+0
| | | | closes #2812.
* doc/started: simplify and fixGedare Bloom2015-03-111-12/+16
| | | | | | | | | | | | * fix and remove some macros in rtems.texi.in. * refer to devel mailing list. * remove reference to Debian packaging in requirements section. * remove section on prebuilt tools. * replace toolset build instructions with link to RSB docs. * Add a note in building RTEMS section about using RSB. * Fix URLs Closes #2291.
* doc misc: Building again and updatesJoel Sherrill2014-03-211-2/+3
| | | | | Remove references to Cygnus Fix issues introduced in previous edits
* started/buildrt.t: Change CVS to GitJoel Sherrill2014-03-201-12/+6
* Change all references of rtems.com to rtems.org.Chris Johns2014-03-211-4/+4
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-111-3/+0
* 2011-10-31 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-10-311-0/+6
| | | | | | PR 1947/doc * started/buildrt.t: Make note that native toolset is needed to configure and build RTEMS.
* 2011-01-02 Danila Bespalov <danila DOT bespalov AT gmail DOT com>Joel Sherrill2011-01-021-13/+28
| | | | | * started/buildc.t, started/buildrt.t, started/nt.t, started/require.t, started/sample.t: Review and improve.
* 2010-12-14 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-12-141-68/+66
| | | | | | | | | | | * Makefile.am, configure.ac, common/cpright.texi, common/rtems.texi.in, cpu_supplement/.cvsignore, started/Makefile.am, started/binaries.t, started/buildc.t, started/buildrt.t, started/intro.t, started/nextstep.t, started/nt.t, started/require.t, started/sample.t, started/started.texi, started/version.texi: Major update which includes removal of references to specific tool versions and patches. * started/tversions.texi.in: Removed.
* 2005-09-02 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2005-09-021-1/+1
| | | | | | | | | * FAQ/basic.texi, FAQ/bsp.texi, FAQ/build45.texi, FAQ/concepts.texi, FAQ/debug.texi, FAQ/endoftime.texi, FAQ/freesw.texi, FAQ/hwdebugaids.texi, FAQ/projects.texi, FAQ/stamp-vti, FAQ/tools.texi, FAQ/version.texi, bsp_howto/rtc.t, started/buildc.t, started/buildrt.t, user/Makefile.am, user/region.t: Fix typos and regenerate.
* 2004-09-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-09-271-7/+6
| | | | | | | | PR 681/doc PR 682/doc * buildc.t, buildrt.t, sample.t: Fix PATH and tar examples. Enable binutils link again. * user/overview.t: Chapter numbering in preface was wrong.
* 2004-03-31 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-311-1/+1
| | | | | * started/buildc.t: Use tar xjf for bzip'ed files. * started/buildrt.t: Use tar xjf to unzip rtems.
* 2004-02-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-02-041-7/+7
| | | | | | | | | | * HELP.html, index.html.in, rtems_footer.html.in, rtems_header.html.in, FAQ/basic.t, gnu_docs/gnu_footer.html, gnu_docs/index.html, gnu_docs/refcard.html, gnu_docs/rtems_tools_index.html, started/binaries.t, started/buildc.t, started/buildrt.t, started/intro.t, started/require.t, started/sample.t, started/tversions.texi.in: Incorporating changes from pre-4.6.0 review.
* 2003-09-19 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-191-9/+7
| | | | | | * .cvsignore, binaries.t, buildc.t, buildrt.t, intro.t, nextstep.t, nt.t, started.texi: Merge from branch. * tversions.texi.in: New file.
* 2003-08-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-271-17/+17
| | | | | | * buildc.t, buildrt.t, nt.t, sample.t, tversions.texi: Don't use VARIABLEs containing '-' in @set and @value (violates texi-syntax).
* 2002-11-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-11-131-125/+5
| | | | | | * Makefile.am, buildc.t, buildrt.t, nt.t, require.t, tversions.texi: Removed all references to bit scripts. * gdb.t: Removed.
* 2001-01-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-171-65/+202
* Corrected typo.Joel Sherrill2000-05-281-1/+1
* Added information on how to do this step if you installed toolJoel Sherrill2000-05-281-1/+21
| | | | binaries rather than unpacking everything.
* Numerous changes based on comments from Stephan Wilms <Stephan.Wilms@CWA.de>Joel Sherrill2000-05-041-0/+6
| | | | | | including a new section in the Getting Started called "Where to Go From Here", lots of index entries added, and more configuration table information.
* Modified to correct references to gmake per comment from Stephan WilmsJoel Sherrill2000-05-021-2/+2
| | | | <Stephan.Wilms@CWA.de>.
* Changed copyright date to 1999.Joel Sherrill1999-11-161-1/+1
* Added information about the bit_rtems script.Joel Sherrill1998-10-201-3/+39
* "arc" changed to "archive"Joel Sherrill1998-04-141-1/+1
| | | | Pictures now in ASCII.
* Added urls as linksJoel Sherrill1998-04-141-2/+2
* Comments from Chris JohnsJoel Sherrill1998-04-141-3/+36
* Mostly correcting case of section headings although a few minor thingsJoel Sherrill1998-04-111-6/+4
| | | | | were corrected as the Getting Started with GNAT/RTEMS manual was created.
* In texinfo nicely with all version dependent informationJoel Sherrill1998-04-101-18/+22
| | | | now in variables and some updates already in place.
* Now builds clean for info, html, and ps.Joel Sherrill1998-04-091-167/+31
* base versionJoel Sherrill1998-04-091-0/+202
