* | Fixing many lines that are too long to format cleanly. | Joel Sherrill | 1999-10-25 | 2 | -15/+27 |
* | Cleaned up to install dvi, use native texi2dvi, etc.. | Joel Sherrill | 1999-10-11 | 1 | -5/+4 |
* | Remove $(PROJECT).pdf not *.pdf. We were accidentally removing the | Joel Sherrill | 1999-10-07 | 1 | -1/+1 |
| | | | | pdf version of figures. | ||||
* | Numerous minor changes required to transition to the latest version | Joel Sherrill | 1999-10-01 | 2 | -3/+8 |
| | | | | | of texinfo and TeX. This version of the tools can produce PDF with figures included. | ||||
* | Removed concept of distribution level. | Joel Sherrill | 1999-07-03 | 1 | -1/+0 |
* | Fixed target name. | Joel Sherrill | 1999-04-02 | 1 | -1/+1 |
* | Added thank you. | Joel Sherrill | 1999-02-10 | 1 | -2/+2 |
* | Now generates HTML, PostScript, and info correctly. | Joel Sherrill | 1999-02-10 | 7 | -63/+42 |
* | Base file. | Joel Sherrill | 1999-02-10 | 1 | -0/+129 |
* | Base version. | Joel Sherrill | 1999-02-10 | 7 | -0/+374 |
