path: root/doc/relnotes (follow)
* RTEMS: Delete ChangeLog files.Gedare Bloom2013-03-081-89/+0
| | | | | | | | | This commit deletes all RTEMS ChangeLog files. These files have been abandoned since converting to git version control. The historical data may be recovered by checking out any commit before this one. Most of the contents of these ChangeLog files can also be found in the git log. Two external ChangeLog files, ChangeLog.slac and ChangeLog.zlib, remain.
* doc master include files: Do not include top node on printed outputJoel Sherrill2013-02-261-0/+2
| | | | | | In PDF, DVI, and PostScript files, the contents of the @top node were being printed. These are intended only for info and html output formats.
* doc: Update version.texi and stamp-vti filesJoel Sherrill2013-02-262-4/+4
| | | | | See http://www.rtems.org/pipermail/rtems-devel/2013-February/002466.html for instructions on how to do this.
* doc: Update to build info format with texinfo 4.13 and 5.0Joel Sherrill2013-02-261-6/+6
| | | | | Texinfo 5.0 is a complete reimplementation and has stricter interpretations of the texinfo language.
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-116-18/+0
* Revert: Remove CVS IdsJoel Sherrill2012-05-071-0/+3
* Remove CVS-Ids.Ralf Corsépius2012-05-041-3/+0
* Remove all .cvsignore files.Joel Sherrill2012-02-011-19/+0
* 2011-12-06 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-12-067-69/+12
| | | | | | PR 1793/doc * .cvsignore, install.texi, intro.texi, probrep.texi, relnotes.texi, status.texi: Convert from texi2www to texi2html.
* 2011-12-05 Joel Sherrill <joel.sherrilL@OARcorp.com>Joel Sherrill2011-12-052-2/+7
| | | | | * version.texi: Update to match when files in directory where last touched.
* New.Ralf Corsepius2010-06-112-0/+8
* Remove EDITION (Unused)Ralf Corsepius2010-06-112-3/+0
* 2009-10-14 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-141-12/+0
| | | | | * HELP.html, bsp_howto/support.t, relnotes/status.texi, started_ada/buildada.t: Remove references to posix/Unix port.
* 2007-06-21 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-06-212-1/+7
| | | | | * relnotes.texi: Print table of contents in front of manual where it should be when you print.
* 2006-10-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2006-10-261-0/+1
| | | | | | | * ada_user/.cvsignore, bsp_howto/.cvsignore, cpu_supplement/.cvsignore, develenv/.cvsignore, filesystem/.cvsignore, itron3.0/.cvsignore, networking/.cvsignore, new_chapters/.cvsignore, porting/.cvsignore, posix1003.1/.cvsignore, relnotes/.cvsignore: Add missing files.
* 2004-09-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-09-293-14/+4
| | | | * intro.texi, status.texi: i960 obsoleted.
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-122-1/+4
| | | | * Makefile.am: Cosmetics.
* 2003-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-112-1/+5
* 2003-11-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-262-0/+7
| | | | | * Makefile.am: Add *.info to CLEANFILES to accomodate automake-1.7f/1.8 breaking building infos.
* 2003-09-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-262-5/+4
| | | | * status.texi: Obsoleting HP PA-RISC port and removing all references.
* 2003-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-222-2/+5
| | | | * Makefile.am: Merger from rtems-4-6-branch.
* 2003-09-19 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-195-99/+19
| | | | | * install.texi, intro.texi, relnotes.texi, status.texi: Merge from branch.
* 2003-01-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-252-1/+5
| | | | * relnotes.texi: Set @setfilename relnotes.info.
* 2003-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-224-11/+13
| | | | | | | | * version.texi: Remove from CVS. * stamp-vti: Remove from CVS. * .cvsignore: Add version.texi. Add stamp-vti. Re-sort.
* 2003-01-21 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-01-213-4/+8
| | | | * stamp-vti, version.texi: Regenerated.
* 2002-11-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-11-133-4/+8
* 2002-10-24 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-10-243-4/+8
* 2002-07-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-302-4/+4
| | | | | * stamp-vti, verstion.texi: Regenerated.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-282-1/+4
| | | | * Makefile.am: Remove AUTOMAKE_OPTIONS.
* regeneratedJoel Sherrill2002-01-202-4/+6
* regeneratedJoel Sherrill2002-01-202-4/+4
* 2002-01-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-182-1/+6
| | | | * Makefile.am: include main.am, require automake-1.5.
* 2001-01-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-172-0/+6
| | | | * .cvsignore: Added rtems_header.html and rtems_footer.html.
* 2001-01-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-178-10/+11
* 2000-09-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-222-1/+5
| | | | * Makefile.am: Removed GENERATED_FILES from list of TEXINFOS.
* Adding ChangeLogs.Joel Sherrill2000-08-251-0/+3
* Patch rtemsdoc-4.5.0-rc-13-cvs.diff.gz from Ralf CorsepiusJoel Sherrill2000-06-141-1/+0
| | | | | | | | <corsepiu@faw.uni-ulm.de> which: * should fix the building rtemsdoc outside of the sourcetree with relative srcdir issue * adds --enable-papersize=[letter|a4|]
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to correct problemsJoel Sherrill2000-06-123-7/+7
| | | | on RELEASE versus VERSION.
* Patch rtems-rc-4.5.0-21.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-06-102-3/+4
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | which splits the current monolithic specs files into a sequence of subparts. These can be concatenated togather to make a the whole .spec file. This cleans up the maintenance problem of having "all languages" and a "C/C++ only" gccnewlib spec files. Plus it should make it easier to produce variants like the gdb-m68k-bdm which require special hackery. :) Ralf's comments: It addresses the way *.spec.in get composed inside of the source tree. Changes: * Each spec.in is broken into several files (*.add), one *.add file per sub-package. * Each Makefile.am composes spec.ins from the *.add files * Removal of redundant automake support files. * Default value for BuildRoot changed to /tmp/<spec-file-name> * %clean stage added to *specs Advantages (IMHO). * The *.add files are easier to adminstrate and more flexible in comparison to the former *.specs.ins. * gccnewlib_c_only.spec.in now is composed from the same sources as gccnewlib.spec.in (less errors) * If using the default BuildRoot --clean now deletes all files that were generated while building. Notes: * rtems.spec.in has not yet been adapted to the scheme used for the other *spec.ins * Except for cosmetical changes the internals of the *.spec files should not have changed. To Apply: cvs rm -f scripts/binutils/binutils.spec.in cvs rm -f scripts/gccnewlib/gccnewlib.spec.in cvs rm -f scripts/gccnewlib/gccnewlib_c_only.spec.in cvs rm -f scripts/gdb/gdb.spec.in cvs rm -f scripts/config.sub cvs rm -f scripts/config.guess cvs rm -f scripts/install-sh cvs rm -f scripts/mkinstalldirs cvs rm -f scripts/missing patch -p1 < rtems-rc-4.5.0-21.diff cvs add scripts/*/*.add cvs add scripts/*/README
* Patch rtemsdoc-4.5.0-rc-8.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-06-015-21/+21
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Ralf's comments follow: Changes: * Enhanced versioning: - Addition of automake's version.texi support - Replacement of rtemsdoc's former versioning support by automake's versioning support (Abandoning RTEMS-UPDATE-* etc.) - Abandoning setup.texi.in - Add EDITION to each documents Makefile.am - version.texi support in project.am - Addition of maintainer mode (currently only used to prevent incorrectly updating timestamps when users touch automake's version.texi timestamp files (stamp-vti)). * Fixing info dir support - Use texinfo's @dircategory and @direntry instead of infos *-DIR-ENTRY - $(infodir)/dir is now correctly set up * Avoid using temporary files - Pipe texts through REPLACE2 into BMENU2 instead of using temporary files. - Abandon using bmenu in favor of bmenu2 (bmenu could be removed now) * Prepare Makefile.ams for building in a separate buildtree - prefix files with $(srcdir) in Makefile.am for files which must be generated inside of the source tree Notes: * rtemsdoc can not yet be build in a separate source-tree, but we are very close to it. * You as the maintainer of this package now should always use --enable-maintainer-mode to configure rtemsdoc.
* Patch rtemsdoc-4.5.0-rc-3.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill2000-05-011-9/+9
| | | | | | | | | | | | | | | | | | | | | | | | | It addresses: * .cvsignore (only minor changes to yours, as they were pretty clean, most changes result from my mkcvsignore script being overly pedantic sorting entries alphabetically.) * timing.t handling and time<BSP>_.texi handling in supplements * network.t handling in bsp_howto * RTEMS_DATE and RTEMS_UPDATE handling in configure.in. [It actually is a hack, as we could apply automake's version.texi handling instead - I know think to understand what automake does with it.] * avoid using temporary files; Therefore a new tool called bmenu2, derived from bemenu, is introduced, which reads a single file from stdin and writes to stdio. To apply: cd rtemsdoc patch -p1 < rtemsdoc-4.5.0-rc-3.diff cvs rm -f bsp_howto/network.t cvs add tools/bmenu/bmenu2.c ./bootstrap BTW: word-replace now is unused. It could be removed if you like to.
* New files. First attempt.Joel Sherrill2000-04-271-0/+17
* Patch rtemsdoc-4.5.0-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-04-262-53/+21
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | which contains the bulk of converting the documentation tree to automake and GNU conventions. Comments follow: This is the automake port of rtemsdoc. To apply: cvs co rtemsdoc cd rtemsdoc sh cvs-rm.sh patch -p0 < rtemsdoc-4.5.0-rc-0.diff sh cvs-add.sh [Attention: cvs-rm.sh and cvs-add.sh directly modify cvs] Known bugs: 1) src2html is not supported (yet? - Is this supposed to work?) 2) all *.pdf images now are generated on-the-fly, but not yet deleted during "make distclean" 3) All supplements, including the templated ones, get build and installed. 4) Building outside of the source tree is completely untested and very likely does not work. 5) Make [ps|pdf] are not (yet) supported, make [dvi|info] are supported by automake's default texinfo rules. Fixing 2, 3 and 5 is almost trivial and needs to be done. 4) is a matter of testing and tool-properties, for now it is simply untested. General issues: * gif vs jpg vs png. I would recommend to replace all images with pngs to avoid potential copyright issues (gif) or lack in quality (jpg, jpg is good for real world photographs, but extremely poor on artificial images, graphs). * pdf images do net get placed correctly in pdf-documents. * texinfo: We now use a local copy of texinfo-4.0's texinfo.tex in texinfo/texinfo.tex for generating infos. However pdftex's system-wide texinfo.tex and pdftexinfo.tex are used for generating *.dvi, *.ps, *.pdf. * .cvsignore files still missing. * I have renamed the supplements filename not to use c_<supplement>, because automake seems to have problems with it. Notes: * Again, I recommend not to put any generated files into CVS. Here, this comprises some *texi, all *.pdf and many *.html pages. Ie. I recommend to run make maintainer-clean before checking in any files. * To get building started, this should be sufficient: ./bootstrap ./configure cd tools; make; cd .. make info * To make a public tarball: [cvs co ; ./bootstrap] ./configure cd tools; make; cd .. make info [make clean] make dist => This generates a rtems-<version>.tar.gz in the toplevel directory. => Building the tools only is required after a "cvs co", but not in a distribution tarball.
* Changed copyright date to 1999.Joel Sherrill1999-11-166-6/+6
* Cleaned up to install dvi, use native texi2dvi, etc..Joel Sherrill1999-10-111-3/+4
* Remove $(PROJECT).pdf not *.pdf. We were accidentally removing theJoel Sherrill1999-10-071-1/+1
| | | | pdf version of figures.
* Numerous minor changes required to transition to the latest versionJoel Sherrill1999-10-012-3/+8
| | | | | of texinfo and TeX. This version of the tools can produce PDF with figures included.
* Removed concept of distribution level.Joel Sherrill1999-07-031-1/+0
* Version changed.Joel Sherrill1998-10-271-8/+0
* Making the stanza right and improving the way the isntall directories are builtJoel Sherrill1998-03-301-15/+7
