* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 1 | -3/+0 |
* | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-01-17 | 1 | -1/+1 |
| | | | | | | | * SUPPORT, LICENSE: New files. * Numerous files touched as part of merging the 4.5 branch onto the mainline development trunk and ensuring that the script that cuts snapshots and releases works on the documentation. | ||||
* | Added fchdir(). | Joel Sherrill | 2000-06-30 | 1 | -0/+63 |
* | Fixed line too long. | Joel Sherrill | 1999-11-23 | 1 | -2/+2 |
* | Fixed spacing. | Joel Sherrill | 1999-11-16 | 1 | -5/+5 |
* | Changed copyright date to 1999. | Joel Sherrill | 1999-11-16 | 1 | -1/+1 |
* | Cleaned up spacing on function prototypes. | Joel Sherrill | 1999-10-28 | 1 | -56/+56 |
* | Added lstat(). | Joel Sherrill | 1999-10-28 | 1 | -3/+57 |
* | Generated concept and function index entries. | Joel Sherrill | 1999-10-11 | 1 | -226/+418 |
* | Numerous minor changes required to transition to the latest version | Joel Sherrill | 1999-10-01 | 1 | -2/+2 |
| | | | | | of texinfo and TeX. This version of the tools can produce PDF with figures included. | ||||
* | Added information on pathname evaluation. | Joel Sherrill | 1999-06-11 | 1 | -1/+14 |
* | Major update/merge of POSIX manual. | Joel Sherrill | 1998-11-19 | 1 | -0/+2088 |
