path: root/doc/new_chapters (follow)
* gen_section: Update for use with new SMP chapters.Joel Sherrill2014-03-111-2/+19
* RTEMS: Delete ChangeLog files.Gedare Bloom2013-03-081-119/+0
| | | | | | | | | This commit deletes all RTEMS ChangeLog files. These files have been abandoned since converting to git version control. The historical data may be recovered by checking out any commit before this one. Most of the contents of these ChangeLog files can also be found in the git log. Two external ChangeLog files, ChangeLog.slac and ChangeLog.zlib, remain.
* doc: Update to build info format with texinfo 4.13 and 5.0Joel Sherrill2013-02-261-3/+4
| | | | | Texinfo 5.0 is a complete reimplementation and has stricter interpretations of the texinfo language.
* Remove CVS Id Strings (manual edits after script)Joel Sherrill2012-05-112-6/+0
| | | | | | These modifications were required by hand after running the script. In some cases, the file names did not match patterns. In others, the format of the file did not match any common patterns.
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-114-12/+0
* Revert: Remove CVS IdsJoel Sherrill2012-05-071-0/+3
* Remove CVS-Ids.Ralf Corsépius2012-05-041-3/+0
* Remove all .cvsignore files.Joel Sherrill2012-02-011-24/+0
* 2011-12-06 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-12-063-13/+7
| | | | | PR 1793/doc * .cvsignore, new_chapters.texi: Convert from texi2www to texi2html.
* 2011-12-05 Joel Sherrill <joel.sherrilL@OARcorp.com>Joel Sherrill2011-12-052-2/+7
| | | | | * version.texi: Update to match when files in directory where last touched.
* New.Ralf Corsepius2010-06-112-0/+8
* Remove EDITION (Unused)Ralf Corsepius2010-06-112-3/+0
* 2007-06-21 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-06-212-3/+7
| | | | | * new_chapters.texi: Print table of contents in front of manual where it should be when you print.
* Fix typo.Joel Sherrill2007-05-171-2/+2
* 2007-05-15 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2007-05-154-308/+13
| | | | | | | | | | | * Makefile.am, gen_section: Integrate Rate Monotonic Statistics and Period Usage into Rate Monotonic Manager. Added the following directives: rtems_rate_monotonic_get_statistics, rtems_rate_monotonic_reset_statistics, rtems_rate_montonic_reset_all_statistics, rtems_rate_montonic_report_statistics, and rtems_object_get_name. Obsoleted the rtems/rtmonuse.h file as a public interface. * rtmonuse.t: Removed.
* 2006-10-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2006-10-261-0/+9
| | | | | | | * ada_user/.cvsignore, bsp_howto/.cvsignore, cpu_supplement/.cvsignore, develenv/.cvsignore, filesystem/.cvsignore, itron3.0/.cvsignore, networking/.cvsignore, new_chapters/.cvsignore, porting/.cvsignore, posix1003.1/.cvsignore, relnotes/.cvsignore: Add missing files.
* 2006-09-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2006-09-144-163/+2
| | | | | | | | | * new_chapters/Makefile.am, new_chapters/gen_section, new_chapters/new_chapters.texi, user/Makefile.am, user/c_user.texi, user/dirstat.texi: Promote CPU Usage to first class citizen. Rename to start with rtems_ and include documentation in user guide. * user/cpuuse.t: New file. * new_chapters/cpuuse.t: Removed.
* 2006-09-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2006-09-132-201/+2
| | | | | | | | * new_chapters/Makefile.am, user/Makefile.am, user/c_user.texi, user/dirstat.texi, user/task.t: Move stack to first class citizen status. Include it in User Manual and rename to start with rtems_. * user/stackchk.t: New file. * new_chapters/stackchk.t: Removed.
* Remove obsolete entries.Ralf Corsepius2006-01-191-4/+0
* Provoke cvs complaints on generated docs.Ralf Corsepius2006-01-191-10/+0
* 2006-01-19 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2006-01-193-63/+6
| | | | | * base.t: Remove. * Makefile.am: Remove base.t.
* 2006-01-19 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2006-01-193-9/+8
| | | | | | * eventlog.t: Remove. * new_chapters.texi: Remove eventlog. * Makefile.am: Remove eventlog.
* RemoveRalf Corsepius2006-01-191-1265/+0
| | | | | | * dumpcontrol.t: Remove. * new_chapters.texi: Remove dumpcontrol. * Makefile.am: Remove dumpcontrol.
* Remove.Ralf Corsepius2006-01-191-98/+0
| | | | | | * confspace.t: Remove. * new_chapters.texi: Remove confspace. * Makefile.am: Remove confspace.
* Remove.Ralf Corsepius2006-01-191-1351/+0
| | | | | | * adminiface.t: Remove. * new_chapters.texi: Remove adminiface. * Makefile.am: Remove adminiface.
* Remove.Ralf Corsepius2006-01-191-129/+0
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-122-1/+4
| | | | * Makefile.am: Cosmetics.
* 2003-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-112-2/+7
* 2003-11-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-262-0/+7
| | | | | * Makefile.am: Add *.info to CLEANFILES to accomodate automake-1.7f/1.8 breaking building infos.
* 2003-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-222-2/+5
| | | | * Makefile.am: Merger from rtems-4-6-branch.
* 2003-09-19 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-192-0/+5
| | | | * new_chapters.texi: Merge from branch.
* 2003-01-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-252-1/+5
| | | | * new_chapters.texi: Set @setfilename new_chapters.info.
* 2003-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-242-9/+13
| | | | * Makefile.am: Put GENERATED_FILES into $builddir.
* 2003-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-224-13/+15
| | | | | | | | * version.texi: Remove from CVS. * stamp-vti: Remove from CVS. * .cvsignore: Add version.texi. Add stamp-vti. Re-sort.
* 2003-01-21 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-01-213-4/+8
| | | | * stamp-vti, version.texi: Regenerated.
* 2002-11-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-11-133-4/+8
* 2002-10-24 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-10-243-4/+8
* 2002-07-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-302-4/+4
| | | | | * stamp-vti, verstion.texi: Regenerated.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-282-1/+4
| | | | * Makefile.am: Remove AUTOMAKE_OPTIONS.
* regeneratedJoel Sherrill2002-01-202-4/+6
* regeneratedJoel Sherrill2002-01-202-4/+4
* 2002-01-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-182-1/+6
| | | | * Makefile.am: include main.am, require automake-1.5.
* 2001-01-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-172-0/+6
| | | | * .cvsignore: Added rtems_header.html and rtems_footer.html.
* 2001-01-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-1715-17/+18
* Adding ChangeLogs.Joel Sherrill2000-08-251-0/+3
* Patch rtemsdoc-4.5.0-rc-13-cvs.diff.gz from Ralf CorsepiusJoel Sherrill2000-06-141-1/+0
| | | | | | | | <corsepiu@faw.uni-ulm.de> which: * should fix the building rtemsdoc outside of the sourcetree with relative srcdir issue * adds --enable-papersize=[letter|a4|]
* Patch rtems-rc-4.5.0-21.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-06-102-4/+6
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | which splits the current monolithic specs files into a sequence of subparts. These can be concatenated togather to make a the whole .spec file. This cleans up the maintenance problem of having "all languages" and a "C/C++ only" gccnewlib spec files. Plus it should make it easier to produce variants like the gdb-m68k-bdm which require special hackery. :) Ralf's comments: It addresses the way *.spec.in get composed inside of the source tree. Changes: * Each spec.in is broken into several files (*.add), one *.add file per sub-package. * Each Makefile.am composes spec.ins from the *.add files * Removal of redundant automake support files. * Default value for BuildRoot changed to /tmp/<spec-file-name> * %clean stage added to *specs Advantages (IMHO). * The *.add files are easier to adminstrate and more flexible in comparison to the former *.specs.ins. * gccnewlib_c_only.spec.in now is composed from the same sources as gccnewlib.spec.in (less errors) * If using the default BuildRoot --clean now deletes all files that were generated while building. Notes: * rtems.spec.in has not yet been adapted to the scheme used for the other *spec.ins * Except for cosmetical changes the internals of the *.spec files should not have changed. To Apply: cvs rm -f scripts/binutils/binutils.spec.in cvs rm -f scripts/gccnewlib/gccnewlib.spec.in cvs rm -f scripts/gccnewlib/gccnewlib_c_only.spec.in cvs rm -f scripts/gdb/gdb.spec.in cvs rm -f scripts/config.sub cvs rm -f scripts/config.guess cvs rm -f scripts/install-sh cvs rm -f scripts/mkinstalldirs cvs rm -f scripts/missing patch -p1 < rtems-rc-4.5.0-21.diff cvs add scripts/*/*.add cvs add scripts/*/README
