path: root/doc/networking (follow)
* Reformatted ASCII slightly to avoid line wrap.Joel Sherrill2000-05-281-3/+4
* Minor corrections from Nick Simon <Nick.SIMON@syntegra.bt.co.uk>.Joel Sherrill2000-05-251-2/+2
| | | | | | - char * nameserver[3] appears twice, second occurrence should be ntpserver - in sect 3.3.3 ...ifcontig should be ifconfig
* Numerous changes based on comments from Stephan Wilms <Stephan.Wilms@CWA.de>Joel Sherrill2000-05-041-1/+1
| | | | | | including a new section in the Getting Started called "Where to Go From Here", lots of index entries added, and more configuration table information.
* Patch rtemsdoc-4.5.0-rc-3.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill2000-05-011-16/+16
| | | | | | | | | | | | | | | | | | | | | | | | | It addresses: * .cvsignore (only minor changes to yours, as they were pretty clean, most changes result from my mkcvsignore script being overly pedantic sorting entries alphabetically.) * timing.t handling and time<BSP>_.texi handling in supplements * network.t handling in bsp_howto * RTEMS_DATE and RTEMS_UPDATE handling in configure.in. [It actually is a hack, as we could apply automake's version.texi handling instead - I know think to understand what automake does with it.] * avoid using temporary files; Therefore a new tool called bmenu2, derived from bemenu, is introduced, which reads a single file from stdin and writes to stdio. To apply: cd rtemsdoc patch -p1 < rtemsdoc-4.5.0-rc-3.diff cvs rm -f bsp_howto/network.t cvs add tools/bmenu/bmenu2.c ./bootstrap BTW: word-replace now is unused. It could be removed if you like to.
* New files. First attempt.Joel Sherrill2000-04-271-0/+26
* Patches rtemsdoc-4.5.0-rc.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-04-261-1/+1
| | | | | | | | | | | | | that addresses the following: The patch below should * fix the *pdf cleanup handling * fix dependencies between pdf-documents and texi-files It also contains an attempt to let networking/schedule.t use states.pdf instead of ascii graphics, but though each pdf image looks nice, it comes out weirdly distorted in the main pdf document.
* Patch rtemsdoc-4.5.0-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-04-267-118/+73
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | which contains the bulk of converting the documentation tree to automake and GNU conventions. Comments follow: This is the automake port of rtemsdoc. To apply: cvs co rtemsdoc cd rtemsdoc sh cvs-rm.sh patch -p0 < rtemsdoc-4.5.0-rc-0.diff sh cvs-add.sh [Attention: cvs-rm.sh and cvs-add.sh directly modify cvs] Known bugs: 1) src2html is not supported (yet? - Is this supposed to work?) 2) all *.pdf images now are generated on-the-fly, but not yet deleted during "make distclean" 3) All supplements, including the templated ones, get build and installed. 4) Building outside of the source tree is completely untested and very likely does not work. 5) Make [ps|pdf] are not (yet) supported, make [dvi|info] are supported by automake's default texinfo rules. Fixing 2, 3 and 5 is almost trivial and needs to be done. 4) is a matter of testing and tool-properties, for now it is simply untested. General issues: * gif vs jpg vs png. I would recommend to replace all images with pngs to avoid potential copyright issues (gif) or lack in quality (jpg, jpg is good for real world photographs, but extremely poor on artificial images, graphs). * pdf images do net get placed correctly in pdf-documents. * texinfo: We now use a local copy of texinfo-4.0's texinfo.tex in texinfo/texinfo.tex for generating infos. However pdftex's system-wide texinfo.tex and pdftexinfo.tex are used for generating *.dvi, *.ps, *.pdf. * .cvsignore files still missing. * I have renamed the supplements filename not to use c_<supplement>, because automake seems to have problems with it. Notes: * Again, I recommend not to put any generated files into CVS. Here, this comprises some *texi, all *.pdf and many *.html pages. Ie. I recommend to run make maintainer-clean before checking in any files. * To get building started, this should be sufficient: ./bootstrap ./configure cd tools; make; cd .. make info * To make a public tarball: [cvs co ; ./bootstrap] ./configure cd tools; make; cd .. make info [make clean] make dist => This generates a rtems-<version>.tar.gz in the toplevel directory. => Building the tools only is required after a "cvs co", but not in a distribution tarball.
* Added instructions on running ttcp from Eric Norum <eric@cls.usask.ca>.Joel Sherrill2000-03-241-0/+37
* Documentation to reflect patch from Eric Norum <eric@cls.usask.ca> toJoel Sherrill2000-01-211-2/+11
| | | | | the network initialization enhancement request by Jake Janovetz <janovetz@tempest.ece.uiuc.edu>.
* Changed copyright date to 1999.Joel Sherrill1999-11-168-8/+8
* Added information about the NTP servier field and included a copyJoel Sherrill1999-11-112-3/+69
| | | | of the C definition of the configuration structure.
* Fixed line too long problems.Joel Sherrill1999-10-251-1/+2
* Swapped SO_SNDWAKEUP and SO_RCVWAKEUP in many places since they wereJoel Sherrill1999-10-251-11/+10
| | | | backwards.
* Cleaned up to install dvi, use native texi2dvi, etc..Joel Sherrill1999-10-111-6/+7
* Switched back to jpg for networkflow because netscape 4.71 for linuxJoel Sherrill1999-10-071-1/+1
| | | | did not display the png properly.
* Regenerated.Joel Sherrill1999-10-071-0/+0
* Enabled table of contents generation so the left hand side of the PDFJoel Sherrill1999-10-071-1/+1
| | | | viewer can have section headings.
* Now includes figures.Joel Sherrill1999-10-071-12/+5
* Updated.Joel Sherrill1999-10-071-0/+0
* COpy the images to the html install point.Joel Sherrill1999-10-071-2/+6
| | | | Added stanza to generate pdf files from eps ones.
* Renamed and generated pdf.Joel Sherrill1999-10-073-1/+1
* New file -- converted from networkflow.epsJoel Sherrill1999-10-071-0/+0
* Added convert stanza to generate pdf version of figures from eps.Joel Sherrill1999-10-061-0/+3
* Renamed networking figure to networkflow and added PCIreg.pdf.Joel Sherrill1999-10-064-0/+1343
* Turned this image back off because it works for PS but not PDF.Joel Sherrill1999-10-061-2/+2
* Changing names to avoid the name of the document.Joel Sherrill1999-10-064-1347/+6
* Enabled PCI register figure and renamed them to avoid _ in name to avoidJoel Sherrill1999-10-063-12/+4
| | | | tool problems.
* Numerous minor changes required to transition to the latest versionJoel Sherrill1999-10-013-10/+10
| | | | | of texinfo and TeX. This version of the tools can produce PDF with figures included.
* Added documentation on "two new SOL_SOCKET level options for setsockopt andJoel Sherrill1999-07-032-4/+68
| | | | | getsockopt: SO_SNDWAKEUP and SO_RCVWAKEUP" from Ian Lance Taylor <ian@airs.com>.
* Removed concept of distribution level.Joel Sherrill1999-07-031-1/+0
* Comments from Eric Norum taken into account.Joel Sherrill1999-04-191-2/+14
* First cut at addition of information on macros that need to be defined.Joel Sherrill1999-04-191-0/+29
* Added DEC21140 document from Emmanuel Raguet <raguet@crf.canon.fr>.Joel Sherrill1999-04-083-6/+14
* First attempt to build.Joel Sherrill1999-04-081-264/+305
* New files.Joel Sherrill1999-04-084-0/+500
* New fileJoel Sherrill1999-04-081-0/+264
* Added Network Servers Chapter including Jake Janovetz's ftpd server.Joel Sherrill1999-04-023-2/+7
* New file. Text from Jake Janovetz.Joel Sherrill1999-04-012-1/+122
* Patch from Eric Norum to account for new routine that improvedJoel Sherrill1999-03-231-9/+22
| | | | parsing of interface names.
* Added information on debug modes that can be enabled in the network stack.Joel Sherrill1999-02-091-0/+45
* Changed the name of a section.Joel Sherrill1999-02-091-1/+1
* Updated socket informationJoel Sherrill1998-12-171-1/+2
* Incorporated Jeff's suggestions.Joel Sherrill1998-12-171-25/+28
* Document from Ian Lance Taylor <ian@airs.com> on the tap function.Joel Sherrill1998-12-101-0/+28
* Changed BOOTP -> BOOTP/DHCP.Joel Sherrill1998-11-192-11/+12
* Changed version string.Joel Sherrill1998-11-192-2/+2
| | | | | | Added much new stuff to the POSIX User's Guide. New chapters stuff shrunk.
* Applied updates from remote work while doing class.Joel Sherrill1998-11-191-1/+1
* Clarifed description of driver name.Joel Sherrill1998-10-271-1/+4
* Added some fields and changed last KA9Q reference to FreeBSD.Joel Sherrill1998-10-121-1/+12
* Fixed back so it would build.Joel Sherrill1998-09-101-0/+2
