* | Patches rtemsdoc-4.5.0-rc.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-04-26 | 1 | -1/+1 |
| | | | | | | | | | | | | | that addresses the following: The patch below should * fix the *pdf cleanup handling * fix dependencies between pdf-documents and texi-files It also contains an attempt to let networking/schedule.t use states.pdf instead of ascii graphics, but though each pdf image looks nice, it comes out weirdly distorted in the main pdf document. | ||||
* | Patch rtemsdoc-4.5.0-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-04-26 | 7 | -118/+73 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | which contains the bulk of converting the documentation tree to automake and GNU conventions. Comments follow: This is the automake port of rtemsdoc. To apply: cvs co rtemsdoc cd rtemsdoc sh cvs-rm.sh patch -p0 < rtemsdoc-4.5.0-rc-0.diff sh cvs-add.sh [Attention: cvs-rm.sh and cvs-add.sh directly modify cvs] Known bugs: 1) src2html is not supported (yet? - Is this supposed to work?) 2) all *.pdf images now are generated on-the-fly, but not yet deleted during "make distclean" 3) All supplements, including the templated ones, get build and installed. 4) Building outside of the source tree is completely untested and very likely does not work. 5) Make [ps|pdf] are not (yet) supported, make [dvi|info] are supported by automake's default texinfo rules. Fixing 2, 3 and 5 is almost trivial and needs to be done. 4) is a matter of testing and tool-properties, for now it is simply untested. General issues: * gif vs jpg vs png. I would recommend to replace all images with pngs to avoid potential copyright issues (gif) or lack in quality (jpg, jpg is good for real world photographs, but extremely poor on artificial images, graphs). * pdf images do net get placed correctly in pdf-documents. * texinfo: We now use a local copy of texinfo-4.0's texinfo.tex in texinfo/texinfo.tex for generating infos. However pdftex's system-wide texinfo.tex and pdftexinfo.tex are used for generating *.dvi, *.ps, *.pdf. * .cvsignore files still missing. * I have renamed the supplements filename not to use c_<supplement>, because automake seems to have problems with it. Notes: * Again, I recommend not to put any generated files into CVS. Here, this comprises some *texi, all *.pdf and many *.html pages. Ie. I recommend to run make maintainer-clean before checking in any files. * To get building started, this should be sufficient: ./bootstrap ./configure cd tools; make; cd .. make info * To make a public tarball: [cvs co ; ./bootstrap] ./configure cd tools; make; cd .. make info [make clean] make dist => This generates a rtems-<version>.tar.gz in the toplevel directory. => Building the tools only is required after a "cvs co", but not in a distribution tarball. | ||||
* | Added instructions on running ttcp from Eric Norum <eric@cls.usask.ca>. | Joel Sherrill | 2000-03-24 | 1 | -0/+37 |
* | Documentation to reflect patch from Eric Norum <eric@cls.usask.ca> to | Joel Sherrill | 2000-01-21 | 1 | -2/+11 |
| | | | | | the network initialization enhancement request by Jake Janovetz <janovetz@tempest.ece.uiuc.edu>. | ||||
* | Changed copyright date to 1999. | Joel Sherrill | 1999-11-16 | 8 | -8/+8 |
* | Added information about the NTP servier field and included a copy | Joel Sherrill | 1999-11-11 | 2 | -3/+69 |
| | | | | of the C definition of the configuration structure. | ||||
* | Fixed line too long problems. | Joel Sherrill | 1999-10-25 | 1 | -1/+2 |
* | Swapped SO_SNDWAKEUP and SO_RCVWAKEUP in many places since they were | Joel Sherrill | 1999-10-25 | 1 | -11/+10 |
| | | | | backwards. | ||||
* | Cleaned up to install dvi, use native texi2dvi, etc.. | Joel Sherrill | 1999-10-11 | 1 | -6/+7 |
* | Switched back to jpg for networkflow because netscape 4.71 for linux | Joel Sherrill | 1999-10-07 | 1 | -1/+1 |
| | | | | did not display the png properly. | ||||
* | Regenerated. | Joel Sherrill | 1999-10-07 | 1 | -0/+0 |
* | Enabled table of contents generation so the left hand side of the PDF | Joel Sherrill | 1999-10-07 | 1 | -1/+1 |
| | | | | viewer can have section headings. | ||||
* | Now includes figures. | Joel Sherrill | 1999-10-07 | 1 | -12/+5 |
* | Updated. | Joel Sherrill | 1999-10-07 | 1 | -0/+0 |
* | COpy the images to the html install point. | Joel Sherrill | 1999-10-07 | 1 | -2/+6 |
| | | | | Added stanza to generate pdf files from eps ones. | ||||
* | Renamed and generated pdf. | Joel Sherrill | 1999-10-07 | 3 | -1/+1 |
* | New file -- converted from networkflow.eps | Joel Sherrill | 1999-10-07 | 1 | -0/+0 |
* | Added convert stanza to generate pdf version of figures from eps. | Joel Sherrill | 1999-10-06 | 1 | -0/+3 |
* | Renamed networking figure to networkflow and added PCIreg.pdf. | Joel Sherrill | 1999-10-06 | 4 | -0/+1343 |
* | Turned this image back off because it works for PS but not PDF. | Joel Sherrill | 1999-10-06 | 1 | -2/+2 |
* | Changing names to avoid the name of the document. | Joel Sherrill | 1999-10-06 | 4 | -1347/+6 |
* | Enabled PCI register figure and renamed them to avoid _ in name to avoid | Joel Sherrill | 1999-10-06 | 3 | -12/+4 |
| | | | | tool problems. | ||||
* | Numerous minor changes required to transition to the latest version | Joel Sherrill | 1999-10-01 | 3 | -10/+10 |
| | | | | | of texinfo and TeX. This version of the tools can produce PDF with figures included. | ||||
* | Added documentation on "two new SOL_SOCKET level options for setsockopt and | Joel Sherrill | 1999-07-03 | 2 | -4/+68 |
| | | | | | getsockopt: SO_SNDWAKEUP and SO_RCVWAKEUP" from Ian Lance Taylor <ian@airs.com>. | ||||
* | Removed concept of distribution level. | Joel Sherrill | 1999-07-03 | 1 | -1/+0 |
* | Comments from Eric Norum taken into account. | Joel Sherrill | 1999-04-19 | 1 | -2/+14 |
* | First cut at addition of information on macros that need to be defined. | Joel Sherrill | 1999-04-19 | 1 | -0/+29 |
* | Added DEC21140 document from Emmanuel Raguet <raguet@crf.canon.fr>. | Joel Sherrill | 1999-04-08 | 3 | -6/+14 |
* | First attempt to build. | Joel Sherrill | 1999-04-08 | 1 | -264/+305 |
* | New files. | Joel Sherrill | 1999-04-08 | 4 | -0/+500 |
* | New file | Joel Sherrill | 1999-04-08 | 1 | -0/+264 |
* | Added Network Servers Chapter including Jake Janovetz's ftpd server. | Joel Sherrill | 1999-04-02 | 3 | -2/+7 |
* | New file. Text from Jake Janovetz. | Joel Sherrill | 1999-04-01 | 2 | -1/+122 |
* | Patch from Eric Norum to account for new routine that improved | Joel Sherrill | 1999-03-23 | 1 | -9/+22 |
| | | | | parsing of interface names. | ||||
* | Added information on debug modes that can be enabled in the network stack. | Joel Sherrill | 1999-02-09 | 1 | -0/+45 |
* | Changed the name of a section. | Joel Sherrill | 1999-02-09 | 1 | -1/+1 |
* | Updated socket information | Joel Sherrill | 1998-12-17 | 1 | -1/+2 |
* | Incorporated Jeff's suggestions. | Joel Sherrill | 1998-12-17 | 1 | -25/+28 |
* | Document from Ian Lance Taylor <ian@airs.com> on the tap function. | Joel Sherrill | 1998-12-10 | 1 | -0/+28 |
* | Changed BOOTP -> BOOTP/DHCP. | Joel Sherrill | 1998-11-19 | 2 | -11/+12 |
* | Changed version string. | Joel Sherrill | 1998-11-19 | 2 | -2/+2 |
| | | | | | | Added much new stuff to the POSIX User's Guide. New chapters stuff shrunk. | ||||
* | Applied updates from remote work while doing class. | Joel Sherrill | 1998-11-19 | 1 | -1/+1 |
* | Clarifed description of driver name. | Joel Sherrill | 1998-10-27 | 1 | -1/+4 |
* | Added some fields and changed last KA9Q reference to FreeBSD. | Joel Sherrill | 1998-10-12 | 1 | -1/+12 |
* | Fixed back so it would build. | Joel Sherrill | 1998-09-10 | 1 | -0/+2 |
* | Added references. | Joel Sherrill | 1998-09-10 | 1 | -0/+33 |
* | Removed chapter names from automatically generated node names. | Joel Sherrill | 1998-09-08 | 2 | -3/+5 |
* | Fixed include file path. | Joel Sherrill | 1998-09-08 | 1 | -1/+1 |
* | Patch from Eric Norum | Joel Sherrill | 1998-08-21 | 1 | -10/+9 |
* | Update from Eric Norum. | Joel Sherrill | 1998-08-21 | 1 | -4/+23 |
