* | Changing names to avoid the name of the document. | Joel Sherrill | 1999-10-06 | 4 | -1347/+6 | |
* | Enabled PCI register figure and renamed them to avoid _ in name to avoid | Joel Sherrill | 1999-10-06 | 3 | -12/+4 | |
| | | | | tool problems. | |||||
* | Numerous minor changes required to transition to the latest version | Joel Sherrill | 1999-10-01 | 3 | -10/+10 | |
| | | | | | of texinfo and TeX. This version of the tools can produce PDF with figures included. | |||||
* | Added documentation on "two new SOL_SOCKET level options for setsockopt and | Joel Sherrill | 1999-07-03 | 2 | -4/+68 | |
| | | | | | getsockopt: SO_SNDWAKEUP and SO_RCVWAKEUP" from Ian Lance Taylor <ian@airs.com>. | |||||
* | Removed concept of distribution level. | Joel Sherrill | 1999-07-03 | 1 | -1/+0 | |
* | Comments from Eric Norum taken into account. | Joel Sherrill | 1999-04-19 | 1 | -2/+14 | |
* | First cut at addition of information on macros that need to be defined. | Joel Sherrill | 1999-04-19 | 1 | -0/+29 | |
* | Added DEC21140 document from Emmanuel Raguet <raguet@crf.canon.fr>. | Joel Sherrill | 1999-04-08 | 3 | -6/+14 | |
* | First attempt to build. | Joel Sherrill | 1999-04-08 | 1 | -264/+305 | |
* | New files. | Joel Sherrill | 1999-04-08 | 4 | -0/+500 | |
* | New file | Joel Sherrill | 1999-04-08 | 1 | -0/+264 | |
* | Added Network Servers Chapter including Jake Janovetz's ftpd server. | Joel Sherrill | 1999-04-02 | 3 | -2/+7 | |
* | New file. Text from Jake Janovetz. | Joel Sherrill | 1999-04-01 | 2 | -1/+122 | |
* | Patch from Eric Norum to account for new routine that improved | Joel Sherrill | 1999-03-23 | 1 | -9/+22 | |
| | | | | parsing of interface names. | |||||
* | Added information on debug modes that can be enabled in the network stack. | Joel Sherrill | 1999-02-09 | 1 | -0/+45 | |
* | Changed the name of a section. | Joel Sherrill | 1999-02-09 | 1 | -1/+1 | |
* | Updated socket information | Joel Sherrill | 1998-12-17 | 1 | -1/+2 | |
* | Incorporated Jeff's suggestions. | Joel Sherrill | 1998-12-17 | 1 | -25/+28 | |
* | Document from Ian Lance Taylor <ian@airs.com> on the tap function. | Joel Sherrill | 1998-12-10 | 1 | -0/+28 | |
* | Changed BOOTP -> BOOTP/DHCP. | Joel Sherrill | 1998-11-19 | 2 | -11/+12 | |
* | Changed version string. | Joel Sherrill | 1998-11-19 | 2 | -2/+2 | |
| | | | | | | Added much new stuff to the POSIX User's Guide. New chapters stuff shrunk. | |||||
* | Applied updates from remote work while doing class. | Joel Sherrill | 1998-11-19 | 1 | -1/+1 | |
* | Clarifed description of driver name. | Joel Sherrill | 1998-10-27 | 1 | -1/+4 | |
* | Added some fields and changed last KA9Q reference to FreeBSD. | Joel Sherrill | 1998-10-12 | 1 | -1/+12 | |
* | Fixed back so it would build. | Joel Sherrill | 1998-09-10 | 1 | -0/+2 | |
* | Added references. | Joel Sherrill | 1998-09-10 | 1 | -0/+33 | |
* | Removed chapter names from automatically generated node names. | Joel Sherrill | 1998-09-08 | 2 | -3/+5 | |
* | Fixed include file path. | Joel Sherrill | 1998-09-08 | 1 | -1/+1 | |
* | Patch from Eric Norum | Joel Sherrill | 1998-08-21 | 1 | -10/+9 | |
* | Update from Eric Norum. | Joel Sherrill | 1998-08-21 | 1 | -4/+23 | |
* | First version produced. | Joel Sherrill | 1998-08-19 | 3 | -2/+3 | |
* | Renamed files ... just about to produce the first copy of the manual. | Joel Sherrill | 1998-08-19 | 5 | -21/+21 | |
* | Baseline | Joel Sherrill | 1998-08-19 | 9 | -0/+2321 | |
