for details.
PR 1793/doc
* .cvsignore, Makefile.am, README, configure.ac, index.html.in,
main.am, project.am, ada_user/.cvsignore, ada_user/ada_user.texi,
ada_user/example.texi, bsp_howto/.cvsignore,
bsp_howto/bsp_howto.texi, cpu_supplement/.cvsignore,
cpu_supplement/cpu_supplement.texi, cpu_supplement/preface.texi,
develenv/.cvsignore, develenv/develenv.texi, develenv/intro.texi,
filesystem/.cvsignore, filesystem/filesystem.texi,
filesystem/preface.texi, networking/.cvsignore,
networking/networking.texi, networking/preface.texi,
porting/.cvsignore, porting/porting.texi, porting/preface.texi,
posix1003.1/.cvsignore, posix1003.1/posix1003_1.texi,
posix_users/.cvsignore, posix_users/posix_users.texi,
posix_users/preface.texi, shell/.cvsignore, shell/preface.texi,
shell/shell.texi, started/.cvsignore, started/started.texi,
user/.cvsignore, user/c_user.texi, user/dirstat.texi,
user/example.texi, user/glossary.texi, user/preface.texi: Convert
from texi2www to texi2html.
* texi2html_init.in: New file.
* rtems_footer.html.in, rtems_header.html.in: Removed.
* ada_user/version.texi, bsp_howto/version.texi,
cpu_supplement/version.texi, develenv/version.texi,
filesystem/version.texi, networking/version.texi,
porting/version.texi, posix1003.1/version.texi,
posix_users/version.texi, shell/version.texi, started/version.texi,
user/version.texi: Update to match when files in directory where last
touched.
PR 1752/doc
* cpu_supplement/.cvsignore, cpu_supplement/Makefile.am,
cpu_supplement/cpu_supplement.texi: Remove TI C4x CPU Supplement
chapter.
* cpu_supplement/tic4x.t: Removed.
* Makefile.am, configure.ac, common/cpright.texi, common/rtems.texi.in,
cpu_supplement/.cvsignore, started/Makefile.am, started/binaries.t,
started/buildc.t, started/buildrt.t, started/intro.t,
started/nextstep.t, started/nt.t, started/require.t,
started/sample.t, started/started.texi, started/version.texi: Major
update which includes removal of references to specific tool versions
and patches.
* started/tversions.texi.in: Removed.
PR 1565/cpukit
* cpu_supplement/Makefile.am, cpu_supplement/cpu_supplement.texi: Merge
SPARC64 port.
* cpu_supplement/sparc64.t: New file.
* cpu_supplement/Makefile.am: Include main.am.
* cpu_supplement/arm.t: Update.
* cpu_supplement/preface.texi: Typo.
* cpu_supplement/general.t: Expanded abbreviation.
cpu_supplement/cpu_supplement.texi: Add shell for Atmel AVR chapter.
* cpu_supplement/avr.t: New file.
cpu_supplement/cpu_supplement.texi: Add Lattice Mico32 support.
* cpu_supplement/lm32.t: New file.
cpu_supplement/arm.t, cpu_supplement/bfin.t,
cpu_supplement/cpu_supplement.texi, cpu_supplement/i386.t,
cpu_supplement/m68k.t, cpu_supplement/mips.t,
cpu_supplement/powerpc.t, cpu_supplement/preface.texi,
cpu_supplement/sh.t: Remove duplicated text from each CPU specific
chapter. This text was necessary when each CPU was a separate manual
but now only needs to be one place and that is in an introductory
chapter.
* cpu_supplement/general.t: New file.
* cpu_supplement/arm.t, cpu_supplement/i386.t, cpu_supplement/m68k.t,
cpu_supplement/mips.t, cpu_supplement/powerpc.t, cpu_supplement/sh.t,
cpu_supplement/sparc.t, cpu_supplement/tic4x.t, porting/cpuinit.t,
user/conf.t, user/init.t: Move interrupt_stack_size field from CPU
Table to Configuration Table. Eliminate CPU Table from all ports.
Delete references to CPU Table in all forms.
cpu_supplement/sparc.t, cpu_supplement/tic4x.t, user/conf.t: Moved
most of the remaining CPU Table fields to the Configuration Table.
This included pretasking_hook, predriver_hook, postdriver_hook,
idle_task, do_zero_of_workspace, extra_mpci_receive_server_stack,
stack_allocate_hook, and stack_free_hook. As a side-effect of this
effort some multiprocessing code was made conditional and some style
clean up occurred.
* cpu_supplement/powerpc.t: Eliminate PowerPC specific elements from
the CPU Table. They have been replaced with variables named bsp_XXX
as needed.
* cpu_supplement/sh.t: Eliminate the clicks_per_microsecond field in
the SuperH CPU Table and define another mechanism for drivers to
obtain this information.
* cpu_supplement/i386.t, cpu_supplement/m68k.t: Pick up changes missed
earlier.
* cpu_supplement/mips.t: Eliminate the clicks_per_microsecond field in
the MIPS CPU Table and define another mechanism for drivers to obtain
this information.
* cpu_supplement/i386.t: Eliminate the interrupt_table_segment and
interrupt_table_offset fields in the i386 CPU Table since they are
never read.
* cpu_supplement/m68k.t: Eliminate the interrupt_vector_table field in
the m68k CPU Table since it is never read.
* ada_user/ada_user.texi, bsp_howto/bsp_howto.texi,
cpu_supplement/cpu_supplement.texi, develenv/develenv.texi,
filesystem/filesystem.texi, itron3.0/itron.texi,
networking/networking.texi, porting/porting.texi,
posix1003.1/posix1003_1.texi, posix_users/posix_users.texi,
rgdb_specs/rgdb_specs.texi, rtems_gdb/rtems_gdb.texi,
started/started.texi, started_ada/started_ada.texi, user/c_user.texi:
Print table of contents in front of manual where it should be when
you print.
* ada_user/.cvsignore, bsp_howto/.cvsignore, cpu_supplement/.cvsignore,
develenv/.cvsignore, filesystem/.cvsignore, itron3.0/.cvsignore,
networking/.cvsignore, new_chapters/.cvsignore, porting/.cvsignore,
posix1003.1/.cvsignore, relnotes/.cvsignore: Add missing files.
* ada_user/Makefile.am, ada_user/ada_user.texi,
cpu_supplement/Makefile.am, cpu_supplement/cpu_supplement.texi,
cpu_supplement/sparc.t: Add Blackfin CPU supplement chapter and get
everything building from previous breakages.
* cpu_supplement/bfin.t: New file.
* cpu_supplement/cpu_supplement.texi: New file.
* Makefile.am, configure.ac, FAQ/stamp-vti, FAQ/version.texi,
common/cpright.texi: Merging CPU Supplements into a single document.
As part of this removed the obsolete and impossible to maintain size
and timing information.
cpu_supplement/preface.texi, cpu_supplement/sh.t,
cpu_supplement/sparc.t, cpu_supplement/tic4x.t: New files.
* supplements/.cvsignore, supplements/Makefile.am,
supplements/supplement.am, supplements/arm/.cvsignore,
supplements/arm/BSP_TIMES, supplements/arm/ChangeLog,
supplements/arm/Makefile.am, supplements/arm/arm.texi,
supplements/arm/bsp.t, supplements/arm/callconv.t,
supplements/arm/cpumodel.t, supplements/arm/cputable.t,
supplements/arm/fatalerr.t, supplements/arm/intr_NOTIMES.t,
supplements/arm/memmodel.t, supplements/arm/preface.texi,
supplements/arm/timeBSP.t, supplements/c4x/.cvsignore,
supplements/c4x/BSP_TIMES, supplements/c4x/ChangeLog,
supplements/c4x/Makefile.am, supplements/c4x/bsp.t,
supplements/c4x/c4x.texi, supplements/c4x/callconv.t,
supplements/c4x/cpumodel.t, supplements/c4x/cputable.t,
supplements/c4x/fatalerr.t, supplements/c4x/intr_NOTIMES.t,
supplements/c4x/memmodel.t, supplements/c4x/preface.texi,
supplements/c4x/timeBSP.t, supplements/i386/.cvsignore,
supplements/i386/ChangeLog, supplements/i386/FORCE386_TIMES,
supplements/i386/Makefile.am, supplements/i386/bsp.t,
supplements/i386/callconv.t, supplements/i386/cpumodel.t,
supplements/i386/cputable.t, supplements/i386/fatalerr.t,
supplements/i386/i386.texi, supplements/i386/intr_NOTIMES.t,
supplements/i386/memmodel.t, supplements/i386/preface.texi,
supplements/i386/timeFORCE386.t, supplements/m68k/.cvsignore,
supplements/m68k/ChangeLog, supplements/m68k/MVME136_TIMES,
supplements/m68k/Makefile.am, supplements/m68k/bsp.t,
supplements/m68k/callconv.t, supplements/m68k/cpumodel.t,
supplements/m68k/cputable.t, supplements/m68k/fatalerr.t,
supplements/m68k/intr_NOTIMES.t, supplements/m68k/m68k.texi,
supplements/m68k/memmodel.t, supplements/m68k/preface.texi,
supplements/m68k/timeMVME136.t, supplements/m68k/timedata.t,
supplements/mips/.cvsignore, supplements/mips/BSP_TIMES,
supplements/mips/ChangeLog, supplements/mips/Makefile.am,
supplements/mips/bsp.t, supplements/mips/callconv.t,
supplements/mips/cpumodel.t, supplements/mips/cputable.t,
supplements/mips/fatalerr.t, supplements/mips/intr_NOTIMES.t,
supplements/mips/memmodel.t, supplements/mips/mips.texi,
supplements/mips/preface.texi, supplements/mips/timeBSP.t,
supplements/powerpc/.cvsignore, supplements/powerpc/ChangeLog,
supplements/powerpc/DMV177_TIMES, supplements/powerpc/Makefile.am,
supplements/powerpc/PSIM_TIMES, supplements/powerpc/bsp.t,
supplements/powerpc/callconv.t, supplements/powerpc/cpumodel.t,
supplements/powerpc/cputable.t, supplements/powerpc/fatalerr.t,
supplements/powerpc/intr_NOTIMES.t, supplements/powerpc/memmodel.t,
supplements/powerpc/powerpc.texi, supplements/powerpc/preface.texi,
supplements/powerpc/timeDMV177.t, supplements/powerpc/timePSIM.t,
supplements/sh/.cvsignore, supplements/sh/BSP_TIMES,
supplements/sh/ChangeLog, supplements/sh/Makefile.am,
supplements/sh/bsp.t, supplements/sh/callconv.t,
supplements/sh/cpumodel.t, supplements/sh/cputable.t,
supplements/sh/fatalerr.t, supplements/sh/intr_NOTIMES.t,
supplements/sh/memmodel.t, supplements/sh/preface.texi,
supplements/sh/sh.texi, supplements/sh/timeBSP.t,
supplements/sparc/.cvsignore, supplements/sparc/ChangeLog,
supplements/sparc/ERC32_TIMES, supplements/sparc/Makefile.am,
supplements/sparc/bsp.t, supplements/sparc/callconv.t,
supplements/sparc/cpumodel.t, supplements/sparc/cputable.t,
supplements/sparc/fatalerr.t, supplements/sparc/intr_NOTIMES.t,
supplements/sparc/memmodel.t, supplements/sparc/preface.texi,
supplements/sparc/sparc.texi, supplements/sparc/timeERC32.t,
supplements/template/.cvsignore, supplements/template/BSP_TIMES,
supplements/template/ChangeLog, supplements/template/Makefile.am,
supplements/template/bsp.t, supplements/template/callconv.t,
supplements/template/cpumodel.t, supplements/template/cputable.t,
supplements/template/fatalerr.t, supplements/template/intr_NOTIMES.t,
supplements/template/memmodel.t, supplements/template/preface.texi,
supplements/template/template.texi, supplements/template/timeBSP.t: Removed.
