path: root/doc/configure.ac (follow)
* doc: Support texi2any and texi2htmlJoel Sherrill2013-02-261-0/+11
| | | | | | | | | | | This was tested with texi2html-1.82-5.1.el6.noarch and a locally built texinfo 5.0. These are completely different implementations and require different invocations. The Makefile dependencies appear to work but are likely not perfect at this point. The key point is that the autoconf probe detects which to use and responds accordingly with preference given to texi2any.
* Require automake-1.12.2.Ralf Corsépius2012-07-191-1/+1
* Require autoconf-2.69.Ralf Corsépius2012-07-191-1/+1
* 2011-12-06 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-12-061-2/+3
| | | | | | | | | | | | | | | | | | | | | | | PR 1793/doc * .cvsignore, Makefile.am, README, configure.ac, index.html.in, main.am, project.am, ada_user/.cvsignore, ada_user/ada_user.texi, ada_user/example.texi, bsp_howto/.cvsignore, bsp_howto/bsp_howto.texi, cpu_supplement/.cvsignore, cpu_supplement/cpu_supplement.texi, cpu_supplement/preface.texi, develenv/.cvsignore, develenv/develenv.texi, develenv/intro.texi, filesystem/.cvsignore, filesystem/filesystem.texi, filesystem/preface.texi, networking/.cvsignore, networking/networking.texi, networking/preface.texi, porting/.cvsignore, porting/porting.texi, porting/preface.texi, posix1003.1/.cvsignore, posix1003.1/posix1003_1.texi, posix_users/.cvsignore, posix_users/posix_users.texi, posix_users/preface.texi, shell/.cvsignore, shell/preface.texi, shell/shell.texi, started/.cvsignore, started/started.texi, user/.cvsignore, user/c_user.texi, user/dirstat.texi, user/example.texi, user/glossary.texi, user/preface.texi: Convert from texi2www to texi2html. * texi2html_init.in: New file. * rtems_footer.html.in, rtems_header.html.in: Removed.
* 2011-03-04 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-03-041-1/+1
| | | | * configure.ac: Rename RTEMS_API into _RTEMS_API.
* 2011-02-02 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-021-2/+2
| | | | * configure.ac: Require autoconf-2.68, automake-1.11.1.
* 2010-12-14 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-12-141-45/+1
| | | | | | | | | | | * Makefile.am, configure.ac, common/cpright.texi, common/rtems.texi.in, cpu_supplement/.cvsignore, started/Makefile.am, started/binaries.t, started/buildc.t, started/buildrt.t, started/intro.t, started/nextstep.t, started/nt.t, started/require.t, started/sample.t, started/started.texi, started/version.texi: Major update which includes removal of references to specific tool versions and patches. * started/tversions.texi.in: Removed.
* 2010-06-17 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-06-171-1/+0
| | | | | | | | | | | | | | * Makefile.am, configure.ac, index.html.in, develenv/direct.t, posix_users/gen_size_report, started/nextstep.t, started_ada/buildada.t, user/conf.t, user/object.t: Remove ITRON API. * itron3.0/.cvsignore, itron3.0/Makefile.am, itron3.0/config.t, itron3.0/eventflags.t, itron3.0/fixedblock.t, itron3.0/gen_all, itron3.0/gen_section, itron3.0/gen_status_shell, itron3.0/interrupt.t, itron3.0/itron.texi, itron3.0/mailbox.t, itron3.0/memorypool.t, itron3.0/msgbuffer.t, itron3.0/network.t, itron3.0/preface.texi, itron3.0/rendezvous.t, itron3.0/semaphore.t, itron3.0/stamp-vti, itron3.0/status.t, itron3.0/task.t, itron3.0/tasksync.t, itron3.0/time.t, itron3.0/version.texi: Removed.
* 2008-02-20 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-02-201-0/+1
| | | | | | | | | * Makefile.am, configure.ac, index.html.in: Add initial version of RTEMS Shell Manual. This is largely a starting point but has most of the required structure. * shell/.cvsignore, shell/Makefile.am, shell/file.t, shell/general.t, shell/memory.t, shell/network.t, shell/preface.texi, shell/rtems.t, shell/shell.texi: New files.
* 2007-08-02 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-08-021-2/+0
| | | | | | | | | | | | | | | | | | | * Makefile.am, configure.ac, develenv/direct.t: Remove RDBG. * rgdb_specs/.cvsignore, rgdb_specs/Makefile.am, rgdb_specs/comm.t, rgdb_specs/conclusion.t, rgdb_specs/daemon.t, rgdb_specs/gdbinternals.t, rgdb_specs/interfacing.t, rgdb_specs/intro.t, rgdb_specs/layers.eps, rgdb_specs/layers.jpg, rgdb_specs/layers.txt, rgdb_specs/objectives.t, rgdb_specs/process.eps, rgdb_specs/process.jpg, rgdb_specs/process.txt, rgdb_specs/revision.t, rgdb_specs/rgdb_specs.texi, rgdb_specs/seqbreak.eps, rgdb_specs/seqbreak.jpg, rgdb_specs/seqbreak.txt, rgdb_specs/seqdetach.eps, rgdb_specs/seqdetach.jpg, rgdb_specs/seqdetach.txt, rgdb_specs/seqinit.eps, rgdb_specs/seqinit.jpg, rgdb_specs/seqinit.txt, rtems_gdb/.cvsignore, rtems_gdb/Makefile.am, rtems_gdb/commands.t, rtems_gdb/example.t, rtems_gdb/intro.t, rtems_gdb/rtems_gdb.texi, rtems_gdb/started.t, rtems_gdb/swarch.t, rtems_gdb/trouble.t: Removed.
* 2007-01-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2007-01-151-2/+2
| | | | | * configure.ac: Reflect having moved setup.def. Eliminate gcc3*.
* Reflect having moved setup.def.Ralf Corsepius2007-01-151-9/+9
| | | | Eliminate gcc3*.
* 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2006-12-021-1/+1
| | | | * configure.ac: New BUG-REPORT address.
* 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2006-10-171-2/+2
| | | | * configure.ac: Require autoconf-2.60. Require automake-1.10.
* 2006-08-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2006-08-271-1/+0
| | | | | | | | | | * Makefile.am, configure.ac, develenv/direct.t: Remove gnu_docs. Now included with RPMs. * gnu_docs/.cvsignore, gnu_docs/ChangeLog, gnu_docs/Makefile.am, gnu_docs/Tool_Doc_Instructions, gnu_docs/gen_docs, gnu_docs/gnu_footer.html, gnu_docs/gnu_header.html, gnu_docs/index.html, gnu_docs/mk_install_dir, gnu_docs/refcard.html, gnu_docs/rtems_tools_index.html: Removed.
* 2006-08-23 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2006-08-231-1/+0
| | | | | | | | | | * Makefile.am, configure.ac, index.html.in: FAQ should now be completely in the Wiki. * FAQ/.cvsignore, FAQ/FAQ.texi, FAQ/Makefile.am, FAQ/basic.t, FAQ/bsp.t, FAQ/build45.t, FAQ/concepts.t, FAQ/debug.t, FAQ/endoftime.t, FAQ/entry, FAQ/freesw.t, FAQ/hwdebugaids.t, FAQ/projects.t, FAQ/stamp-vti, FAQ/tools.t, FAQ/version.texi, common/timemac.texi, common/timetbl.t, common/timing.t: Removed.
* 2006-08-23 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2006-08-231-10/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * Makefile.am, configure.ac, FAQ/stamp-vti, FAQ/version.texi, common/cpright.texi: Merging CPU Supplements into a single document. As part of this removed the obsolete and impossible to maintain size and timing information. * cpu_supplement/.cvsignore, cpu_supplement/Makefile.am, cpu_supplement/arm.t, cpu_supplement/i386.t, cpu_supplement/m68k.t, cpu_supplement/mips.t, cpu_supplement/powerpc.t, cpu_supplement/preface.texi, cpu_supplement/sh.t, cpu_supplement/sparc.t, cpu_supplement/tic4x.t: New files. * supplements/.cvsignore, supplements/Makefile.am, supplements/supplement.am, supplements/arm/.cvsignore, supplements/arm/BSP_TIMES, supplements/arm/ChangeLog, supplements/arm/Makefile.am, supplements/arm/arm.texi, supplements/arm/bsp.t, supplements/arm/callconv.t, supplements/arm/cpumodel.t, supplements/arm/cputable.t, supplements/arm/fatalerr.t, supplements/arm/intr_NOTIMES.t, supplements/arm/memmodel.t, supplements/arm/preface.texi, supplements/arm/timeBSP.t, supplements/c4x/.cvsignore, supplements/c4x/BSP_TIMES, supplements/c4x/ChangeLog, supplements/c4x/Makefile.am, supplements/c4x/bsp.t, supplements/c4x/c4x.texi, supplements/c4x/callconv.t, supplements/c4x/cpumodel.t, supplements/c4x/cputable.t, supplements/c4x/fatalerr.t, supplements/c4x/intr_NOTIMES.t, supplements/c4x/memmodel.t, supplements/c4x/preface.texi, supplements/c4x/timeBSP.t, supplements/i386/.cvsignore, supplements/i386/ChangeLog, supplements/i386/FORCE386_TIMES, supplements/i386/Makefile.am, supplements/i386/bsp.t, supplements/i386/callconv.t, supplements/i386/cpumodel.t, supplements/i386/cputable.t, supplements/i386/fatalerr.t, supplements/i386/i386.texi, supplements/i386/intr_NOTIMES.t, supplements/i386/memmodel.t, supplements/i386/preface.texi, supplements/i386/timeFORCE386.t, supplements/m68k/.cvsignore, supplements/m68k/ChangeLog, supplements/m68k/MVME136_TIMES, supplements/m68k/Makefile.am, supplements/m68k/bsp.t, supplements/m68k/callconv.t, supplements/m68k/cpumodel.t, supplements/m68k/cputable.t, supplements/m68k/fatalerr.t, supplements/m68k/intr_NOTIMES.t, supplements/m68k/m68k.texi, supplements/m68k/memmodel.t, supplements/m68k/preface.texi, supplements/m68k/timeMVME136.t, supplements/m68k/timedata.t, supplements/mips/.cvsignore, supplements/mips/BSP_TIMES, supplements/mips/ChangeLog, supplements/mips/Makefile.am, supplements/mips/bsp.t, supplements/mips/callconv.t, supplements/mips/cpumodel.t, supplements/mips/cputable.t, supplements/mips/fatalerr.t, supplements/mips/intr_NOTIMES.t, supplements/mips/memmodel.t, supplements/mips/mips.texi, supplements/mips/preface.texi, supplements/mips/timeBSP.t, supplements/powerpc/.cvsignore, supplements/powerpc/ChangeLog, supplements/powerpc/DMV177_TIMES, supplements/powerpc/Makefile.am, supplements/powerpc/PSIM_TIMES, supplements/powerpc/bsp.t, supplements/powerpc/callconv.t, supplements/powerpc/cpumodel.t, supplements/powerpc/cputable.t, supplements/powerpc/fatalerr.t, supplements/powerpc/intr_NOTIMES.t, supplements/powerpc/memmodel.t, supplements/powerpc/powerpc.texi, supplements/powerpc/preface.texi, supplements/powerpc/timeDMV177.t, supplements/powerpc/timePSIM.t, supplements/sh/.cvsignore, supplements/sh/BSP_TIMES, supplements/sh/ChangeLog, supplements/sh/Makefile.am, supplements/sh/bsp.t, supplements/sh/callconv.t, supplements/sh/cpumodel.t, supplements/sh/cputable.t, supplements/sh/fatalerr.t, supplements/sh/intr_NOTIMES.t, supplements/sh/memmodel.t, supplements/sh/preface.texi, supplements/sh/sh.texi, supplements/sh/timeBSP.t, supplements/sparc/.cvsignore, supplements/sparc/ChangeLog, supplements/sparc/ERC32_TIMES, supplements/sparc/Makefile.am, supplements/sparc/bsp.t, supplements/sparc/callconv.t, supplements/sparc/cpumodel.t, supplements/sparc/cputable.t, supplements/sparc/fatalerr.t, supplements/sparc/intr_NOTIMES.t, supplements/sparc/memmodel.t, supplements/sparc/preface.texi, supplements/sparc/sparc.texi, supplements/sparc/timeERC32.t, supplements/template/.cvsignore, supplements/template/BSP_TIMES, supplements/template/ChangeLog, supplements/template/Makefile.am, supplements/template/bsp.t, supplements/template/callconv.t, supplements/template/cpumodel.t, supplements/template/cputable.t, supplements/template/fatalerr.t, supplements/template/intr_NOTIMES.t, supplements/template/memmodel.t, supplements/template/preface.texi, supplements/template/template.texi, supplements/template/timeBSP.t: Removed.
* 2004-09-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-09-291-1/+0
| | | | | | * configure.ac, index.html.in, FAQ/basic.t, FAQ/basic.texi, FAQ/entry, porting/cpumodels.t, started/buildc.t, started_ada/buildada.t, user/preface.texi: i960 obsoleted.
* Fix typo in previous change.Ralf Corsepius2004-09-241-1/+1
* 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-09-241-1/+1
| | | | * configure.ac: Require automake > 1.9.
* 2004-02-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-011-0/+1
| | | | | | * configure.ac: Add RTEMSRPMGROUP. * common/rtems.texi.in: Add RTEMSRPMGROUP. * started/binaries.t: Add RTEMSRPMGROUP.
* 2004-02-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-011-0/+3
| | | | | | * configure.ac: Add RTEMS_ENABLE_RPMPREFIX. Add RTEMSRPMPREFIX. * common/rtems.texi.in: Add RTEMSRPMPREFIX.
* 2004-01-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-01-071-2/+0
| | | | | | * configure.ac, index.html.in: mips64orion port removed as mips port more completely covers the MIPS family. * rtems_support.html.in: Removed.
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-121-2/+2
| | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59.
* 2003-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-221-5/+58
| | | | | | | | | * Makefile.am: Merger from rtems-4-6-branch. * configure.ac: Merger from rtems-4-6-branch. Purge hppa1.1. * index.html.in: Purge hppa1.1. * project.am: Merger from rtems-4-6-branch. * rtems_support.html.in: Purge hppa1.1.
* 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-111-1/+1
| | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address.
* Merger from rtems-4-6-branchRalf Corsepius2003-08-071-8/+10
* 2003-02-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-02-181-1/+0
| | | | | | * Makefile.am, configure.ac: Remove src2html references. * index.html.in: Update to reflect partial update of Development Environment Guide.
* 2003-01-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-251-0/+1
| | | | | * configure.ac: Add c4x. * project.am: Add version.texi hack.
* 2003-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-221-3/+2
| | | | | | | | * configure.ac: Require autoconf-2.57. Require automake-1.7.2. Remove started/pictures/Makefile. * started/Makefile.am: Merge-in pictures/Makefile.am * started/pictures/Makefile.am: Remove.
* 2002-12-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-081-2/+0
| | | | | | | | * Makefile.am: Merge-in images/Makefile.am, common/Makefile.am. * images/Makefile.am: Remove. * common/Makefile.am: Remove. * configure.ac: Reflect changes above. * main.am: Append -I $(topsrc_dir) to AM_MAKEINFOFLAGS.
* 2002-07-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-311-0/+1
| | | | * configure.ac: Added supplements/arm/Makefile.
* 2002-04-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-081-3/+2
| | | | | | | | | * bootstrap: Remove. * VERSION: Remove. * Makefile.am: Remove bootstrap. Add ACLOCAL_AMFLAGS. * configure.ac: Add RTEMS_TOP.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-281-2/+2
* 2001-02-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-141-0/+1
| | | | * configure.ac: New mips supplement.
* 2002-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-221-1/+4
| | | | | | | | | | * .cvsignore: Reworked. * Makefile.am: Remove texinfo/texinfo.tex * bootstrap: Removed. * configure.ac: Add pkgdocdir. Let htmldir be rooted at pkgdocdir. * main.am: Remove TEXINFO_TEX. * project.am: Let dvidir, psdir, pdfdir be rooted at pkgdocdir. Remove commented out make-variables.
* 2002-01-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-201-1/+2
| | | | | | | | | * .cvsignore: Add autom4te.cache, install-sh, mdate-sh, missing, mkinstalldirs, texinfo.tex. * Makefile.am: Add main.am to AUTOMAKE_FILES. * configure.ac: Add AC_CONFIG_AUX_DIR([.]). * project.am: Remove custom .texi and stamp-vti rules. * main.am: Replace TEXI_COMMON with AM_MAKEINFOFLAGS.
* 2002-01-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-181-0/+171
* Makefile.am: Require automake-1.5. * project.am: Reworked. * main.am: New. * configure.ac: New. * configure.in: Removed. * bootstrap: Sync with RTEMS's toplevel bootstrap.sh.
