* configure.ac, index.html.in, FAQ/basic.t, FAQ/basic.texi, FAQ/entry,
porting/cpumodels.t, started/buildc.t, started_ada/buildada.t,
user/preface.texi: i960 obsoleted.
* configure.ac: Add RTEMSRPMGROUP.
* common/rtems.texi.in: Add RTEMSRPMGROUP.
* started/binaries.t: Add RTEMSRPMGROUP.
* configure.ac: Add RTEMS_ENABLE_RPMPREFIX.
Add RTEMSRPMPREFIX.
* common/rtems.texi.in: Add RTEMSRPMPREFIX.
* configure.ac, index.html.in: mips64orion port removed as mips port
more completely covers the MIPS family.
* rtems_support.html.in: Removed.
* configure.ac: Merger from rtems-4-6-branch.
Purge hppa1.1.
* index.html.in: Purge hppa1.1.
* project.am: Merger from rtems-4-6-branch.
* rtems_support.html.in: Purge hppa1.1.
* Makefile.am, configure.ac: Remove src2html references.
* index.html.in: Update to reflect partial update of Development
Environment Guide.
* configure.ac: Add c4x.
* project.am: Add version.texi hack.
* configure.ac: Require autoconf-2.57.
Require automake-1.7.2.
Remove started/pictures/Makefile.
* started/Makefile.am: Merge-in pictures/Makefile.am
* started/pictures/Makefile.am: Remove.
* Makefile.am: Merge-in images/Makefile.am, common/Makefile.am.
* images/Makefile.am: Remove.
* common/Makefile.am: Remove.
* main.am: Append -I $(topsrc_dir) to AM_MAKEINFOFLAGS.
* configure.ac: Added supplements/arm/Makefile.
* bootstrap: Remove.
* VERSION: Remove.
* Makefile.am:
Remove bootstrap.
Add ACLOCAL_AMFLAGS.
* configure.ac: Add RTEMS_TOP.
* configure.ac: New mips supplement.
* .cvsignore: Reworked.
* Makefile.am: Remove texinfo/texinfo.tex
* bootstrap: Removed.
* configure.ac: Add pkgdocdir. Let htmldir be rooted at pkgdocdir.
* main.am: Remove TEXINFO_TEX.
* project.am: Let dvidir, psdir, pdfdir be rooted at pkgdocdir.
Remove commented out make-variables.
* .cvsignore: Add autom4te.cache, install-sh, mdate-sh, missing,
mkinstalldirs, texinfo.tex.
* Makefile.am: Add main.am to AUTOMAKE_FILES.
* configure.ac: Add AC_CONFIG_AUX_DIR([.]).
* project.am: Remove custom .texi and stamp-vti rules.
* main.am: Replace TEXI_COMMON with AM_MAKEINFOFLAGS.
* project.am: Reworked.
* main.am: New.
* configure.ac: New.
* configure.in: Removed.
* bootstrap: Sync with RTEMS's toplevel bootstrap.sh.
