* analog.t, bsp_howto.texi, discrete.t, nvmem.t, target.t: Merge from
branch.
* adaintr.t, ata.t, target.t: Reconcile differences between CVS trunk
and 4.6 branch.
* ide-ctrl.t: Merger from 4.6-branch.
* makefiles.t, support.t: Updated to reflect use of automake in
addition to autoconf.
* bsp_howto.texi: Set @setfilename bsp_howto.info.
* stamp-vti: Remove from CVS.
Add stamp-vti.
Re-sort.
* ata.t, ide-ctrl.t: New file.
* .cvsignore: Added new .texi files.
* Makefile.am:: Added new files to generate.
* bsp_howto.texi: Added new chapters.
relative srcdir issue
Ralf's comments:
tree.
per sub-package.
Advantages (IMHO).
other *spec.ins
should not have changed.
To Apply:
cvs rm -f scripts/config.sub
cvs rm -f scripts/install-sh
cvs rm -f scripts/missing
cvs add scripts/*/*.add
cvs add scripts/*/README
Ralf's comments follow:
* Enhanced versioning:
- Abandoning setup.texi.in
files (stamp-vti)).
* Fixing info dir support
* Avoid using temporary files
are very close to it.
It addresses:
and writes to stdio.
cd rtemsdoc
cvs rm -f bsp_howto/network.t
cvs add tools/bmenu/bmenu2.c
./bootstrap
cvs co rtemsdoc
cd rtemsdoc
sh cvs-rm.sh
sh cvs-add.sh
Known bugs:
during "make distclean"
installed.
likely does not work.
untested.
General issues:
images, graphs).
./bootstrap
./configure
cd tools; make; cd ..
make info
* To make a public tarball:
[cvs co ; ./bootstrap]
./configure
make info
[make clean]
make dist
distribution tarball.
bunch of stuff to avoid line wrappings.
pdf version of figures.
figures included.
Johns <ccj@acm.org> suggested this.
Added much new stuff to the POSIX User's Guide.
New chapters stuff shrunk.
chapter.
Cleaned up sections in the target dependent info file.
First draft of chapters up to and include Makefiles written.
