path: root/doc/bsp_howto (follow)
* Changed version string.Joel Sherrill1998-11-191-0/+284
| | | | | | Added much new stuff to the POSIX User's Guide. New chapters stuff shrunk.
* Applied updates from remote work while doing class.Joel Sherrill1998-11-1913-312/+1828
* Corrections from Jennifer and Jeff plus additions to the initializationJoel Sherrill1998-10-215-87/+285
| | | | chapter.
* Spell checked.Joel Sherrill1998-10-203-3/+3
* Added much text to the linkcmds chapter.Joel Sherrill1998-10-203-44/+68
| | | | Cleaned up sections in the target dependent info file.
* Links between chapters up to Linker Script in place.Joel Sherrill1998-10-203-45/+119
| | | | First draft of chapters up to and include Makefiles written.
* Significant additions.Joel Sherrill1998-10-201-45/+156
* Renamed the target dependent code chapter.Joel Sherrill1998-10-201-2/+2
* Added some links between chapters.Joel Sherrill1998-10-201-9/+8
* Spacing changed.Joel Sherrill1998-10-201-3/+2
* Added new chapters.Joel Sherrill1998-10-201-15/+55
* Added multiple chapters and reordered them somewhat.Joel Sherrill1998-10-201-2/+16
* New files.Joel Sherrill1998-10-207-0/+84
* Added numerous comments to the linker script.Joel Sherrill1998-10-201-243/+271
| | | | Now this chapter has no two column stuff in it.
* Changed reference to KA9Q driver.Joel Sherrill1998-10-151-51/+27
| | | | Cleaned up description of the make/custom file.
* Cleaned up where Geoffroy had this in 2-column format.Joel Sherrill1998-10-151-14/+33
* Added more to the list of chapters.Joel Sherrill1998-10-151-9/+30
* Redid sections to have right depth.Joel Sherrill1998-10-153-41/+40
* Removed bsp structure as chapter and renamed some other chapters.Joel Sherrill1998-10-151-4/+2
* Removed bspstruct.t.Joel Sherrill1998-10-151-11/+7
| | | | Commented lines which installed files.
* Cleaned up bad line wrap which was only a long sequence of ???Joel Sherrill1998-10-151-1/+1
* Merged bsp structure into target dependent files chapter.Joel Sherrill1998-10-152-48/+64
* Changed section numbers.Joel Sherrill1998-10-1211-93/+86
* Added author credit.Joel Sherrill1998-08-281-0/+5
* Added CVS Ids.Joel Sherrill1998-08-289-0/+72
* Added top level file and cleaned up chapter namesJoel Sherrill1998-08-287-6/+127
* Undid renaming.Joel Sherrill1998-08-281-0/+0
* Renamed intro to preface.Joel Sherrill1998-08-281-0/+0
* Base filesJoel Sherrill1998-08-2810-25/+1151
* New fileJoel Sherrill1998-08-281-0/+94
