* | Incorporated Jeff's suggestions. | Joel Sherrill | 1998-12-17 | 11 | -33/+78 |
* | Changed version string. | Joel Sherrill | 1998-11-19 | 1 | -0/+284 |
| | | | | | | Added much new stuff to the POSIX User's Guide. New chapters stuff shrunk. | ||||
* | Applied updates from remote work while doing class. | Joel Sherrill | 1998-11-19 | 13 | -312/+1828 |
* | Corrections from Jennifer and Jeff plus additions to the initialization | Joel Sherrill | 1998-10-21 | 5 | -87/+285 |
| | | | | chapter. | ||||
* | Spell checked. | Joel Sherrill | 1998-10-20 | 3 | -3/+3 |
* | Added much text to the linkcmds chapter. | Joel Sherrill | 1998-10-20 | 3 | -44/+68 |
| | | | | Cleaned up sections in the target dependent info file. | ||||
* | Links between chapters up to Linker Script in place. | Joel Sherrill | 1998-10-20 | 3 | -45/+119 |
| | | | | First draft of chapters up to and include Makefiles written. | ||||
* | Significant additions. | Joel Sherrill | 1998-10-20 | 1 | -45/+156 |
* | Renamed the target dependent code chapter. | Joel Sherrill | 1998-10-20 | 1 | -2/+2 |
* | Added some links between chapters. | Joel Sherrill | 1998-10-20 | 1 | -9/+8 |
* | Spacing changed. | Joel Sherrill | 1998-10-20 | 1 | -3/+2 |
* | Added new chapters. | Joel Sherrill | 1998-10-20 | 1 | -15/+55 |
* | Added multiple chapters and reordered them somewhat. | Joel Sherrill | 1998-10-20 | 1 | -2/+16 |
* | New files. | Joel Sherrill | 1998-10-20 | 7 | -0/+84 |
* | Added numerous comments to the linker script. | Joel Sherrill | 1998-10-20 | 1 | -243/+271 |
| | | | | Now this chapter has no two column stuff in it. | ||||
* | Changed reference to KA9Q driver. | Joel Sherrill | 1998-10-15 | 1 | -51/+27 |
| | | | | Cleaned up description of the make/custom file. | ||||
* | Cleaned up where Geoffroy had this in 2-column format. | Joel Sherrill | 1998-10-15 | 1 | -14/+33 |
* | Added more to the list of chapters. | Joel Sherrill | 1998-10-15 | 1 | -9/+30 |
* | Redid sections to have right depth. | Joel Sherrill | 1998-10-15 | 3 | -41/+40 |
* | Removed bsp structure as chapter and renamed some other chapters. | Joel Sherrill | 1998-10-15 | 1 | -4/+2 |
* | Removed bspstruct.t. | Joel Sherrill | 1998-10-15 | 1 | -11/+7 |
| | | | | Commented lines which installed files. | ||||
* | Cleaned up bad line wrap which was only a long sequence of ??? | Joel Sherrill | 1998-10-15 | 1 | -1/+1 |
* | Merged bsp structure into target dependent files chapter. | Joel Sherrill | 1998-10-15 | 2 | -48/+64 |
* | Changed section numbers. | Joel Sherrill | 1998-10-12 | 11 | -93/+86 |
* | Added author credit. | Joel Sherrill | 1998-08-28 | 1 | -0/+5 |
* | Added CVS Ids. | Joel Sherrill | 1998-08-28 | 9 | -0/+72 |
* | Added top level file and cleaned up chapter names | Joel Sherrill | 1998-08-28 | 7 | -6/+127 |
* | Undid renaming. | Joel Sherrill | 1998-08-28 | 1 | -0/+0 |
* | Renamed intro to preface. | Joel Sherrill | 1998-08-28 | 1 | -0/+0 |
* | Base files | Joel Sherrill | 1998-08-28 | 10 | -25/+1151 |
* | New file | Joel Sherrill | 1998-08-28 | 1 | -0/+94 |
