path: root/cpukit (follow)
* 2002-03-27 Thomas.Doerfler@imd-systems.deJoel Sherrill2002-03-272-9/+46
| | | | | | | * PR144 * nfs/bootp_subr.c bootpc_init(): Performs a write to memory address 0 when called for the first time. This is done when trying to clear the variable "dhcp_hostname".
* 2002-03-27 Ilya Alexeev <ilya@continuum.ru>Joel Sherrill2002-03-274-13/+26
| | | | | | | | | | | | | * PR162 * net/if_ppp.c ppp_txdaemon(), net/if_pppvar.h pppstart(): Local variables must not be used in a device write routines. Now ppp_softc structure have own character for writing to device (sc_outchar). I think that converting local variables to static is not a right solution, because problems will occur in the case of two or more ppp instances. * net/ppp_tty.c pppstart(): Type of the ioffset variable must be u_long, otherwise in the case of the big output packet endless loop may occur.
* 2001-03-21 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-03-211-5/+0
| | | | * ChangeLog: Undo incorrect addition of entry.
* 2002-03-21 Ilya Alexeev <ilya@continuum.ru>Joel Sherrill2002-03-214-16/+48
| | | | | * net/if_ppp.c, net/ppp_tty.c: Initial preparations for multiple PPPD connections.
* 2002-03-21 Alexander Kukuta <kam@oktet.ru>Joel Sherrill2002-03-213-610/+389
| | | | | | | * src/bdbuf.c (avl_insert, avl_remove): Reimplemented from scratch to avoid using GPLed sources in RTEMS core. * src/bdbuf.c, include/rtems/bdbuf.h: Remove "binary tree" implementation which was used for debugging only.
* 2001-03-20 Till Straumann <strauman@SLAC.Stanford.EDU>Joel Sherrill2002-03-203-2/+35
| | | | | | | | | * PR158 * libc/rcmd.c, libc/rcmd.c: Enable the rcmd() library call by commenting out the parts that deal with signals. This enables RTEMS to 'rsh' command to a server connecting fd to remote stdio. The 'server-side' parts of this file which deal with authentication are disabled since they are not needed.
* 2002-03-20 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill2002-03-202-0/+11
| | | | * cpu_asm.S: Now compiles on 4600 and 4650.
* 2001-03-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-03-201-1/+1
| | | | | | * PR143 * lib/include/rtems/termiostypes.h: Removed unneeded volatile on "theBuf" since no byte is read more than once anyway.
* 2002-03-20 Chris Johns <ccj@acm.org>Joel Sherrill2002-03-202-0/+10
| | | | | * PR148. * monitor/mon-prmisc.c: Fixed to print task states correctly.
* 2002-03-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-205-5/+20
| | | | | | | | | | | | | Addressing PR 140. * src/dosfs/config.h.in: Removed. * src/dosfs/stamp-h2.in: Removed. * .cvsignore: Add config.h*, stamp-h*. * configure.ac: Remove AC_SRC_DIR(.../dosfs.h). Remove AM_CONFIG_HEADER(src/dosfs/config.h). Remove AM_CONFIG_HEADER(src/imfs/config.h). Add AM_CONFIG_HEADER(config.h). * src/dosfs/Makefile.am: INCLUDES = -I../.. . * src/imfs/Makefile.am: INCLUDES = -I../.. .
* 2002-03-13 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill2002-03-153-24/+42
| | | | | | * cpu_asm.S: Fixed a sneaky return from int w/ ints disabled bug. * rtems/score/cpu.h: Fixed register numbering in comments and made interrupt enable/disable more robust.
* 2002-03-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-153-40/+24
| | | | | | Reported and tracked as PR130. * src/dosfs/Makefile.am: Reworked, Disable dosfs for UNIX. * wrapup/Makefile.am: Disable dosfs for UNIX.
* 2001-03-15 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-03-156-120/+186
| | | | | | | * src/extension.c: Split to reduce minimum code size per PR134. * src/extensioncreate.c, src/extensiondelete.c, src/extensionident.c: New files. src/Makefile.am: Modified to reflect above.
* 2002-03-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-152-1/+5
| | | | * rtems/score/m68k.h: m68k_swap_u32 fix typo.
* 2002-03-05 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill2002-03-087-50/+296
| | | | | | | | | | | | * cpu_asm.S: Added support for the debug exception vector, cleaned up the exception processing & exception return stuff. Re-added EPC in the task context structure so the gdb stub will know where a thread is executing. Should've left it there in the first place... * idtcpu.h: Added support for the debug exception vector. * cpu.c: Added ___exceptionTaskStack to hold a pointer to the stack frame in an interrupt so context switch code can get the userspace EPC when scheduling. * rtems/score/cpu.h: Re-added EPC to the task context.
* 2002-03-06 Victor V. Vengerov <vvv@oktet.ru>Joel Sherrill2002-03-062-0/+39
| | | | | | * rtems/score/m68k.h [M68K_COLDFIRE_ARCH] (CPU_swap_u16, CPU_swap_u32): Generic implementation of endian swap primitives added for Coldfire family.
* 2002-03-01 Eric Norum <eric.norum@usask.ca>Joel Sherrill2002-03-012-7/+15
| | | | | | * src/pthreadonce.c: Task is not preemptable while running a pthread_once init function. This is slightly less heavy handed than disabling dispatching and seems better than consuming a mutex.
* 2002-03-01 Eric Norum <eric.norum@usask.ca>Joel Sherrill2002-03-011-10/+9
| | | | | | * libc/gxx_wrappers.c: Task is not preemptable while running a pthread_once init function. This is slightly less heavy handed than disabling dispatching and seems better than consuming a mutex.
* 2002-02-27 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill2002-03-018-142/+307
| | | | | | | | | | | | | | | | * cpu_asm.S: Fixed exception return address, modified FP context switch so FPU is properly enabled and also doesn't screw up the exception FP handling. * idtcpu.h: Added C0_TAR, the MIPS target address register used for returning from exceptions. * iregdef.h: Added R_TAR to the stack frame so the target address can be saved on a per-exception basis. The new entry is past the end of the frame gdb cares about, so doesn't affect gdb or cpu.h stuff. * rtems/score/cpu.h: added an #ifdef so cpu_asm.S can include it to obtain FPU defines without systax errors generated by the C defintions. * cpu.c: Improved interrupt level saves & restores.
* 2001-03-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-03-012-0/+5
| | | | * src/imfs/.cvsignore: Added stamp-h1.in
* 2002-02-28 Victor V. Vengerov <vvv@oktet.ru>Joel Sherrill2002-02-2827-2/+6664
| | | | | | | | | | | | | | | | | * DOS filesystem including FAT12, FAT16, and FAT32 support submitted. * src/dosfs, src/dosfs/Makefile.am, src/dosfs/stamp-h2.in, src/dosfs/config.h.in, src/dosfs/dosfs.h, src/dosfs/fat.c, src/dosfs/fat.h, src/dosfs/fat_fat_operations.c, src/dosfs/fat_fat_operations.h, src/dosfs/fat_file.c, src/dosfs/fat_file.h, src/dosfs/msdos.h, src/dosfs/msdos_create.c, src/dosfs/msdos_dir.c, src/dosfs/msdos_eval.c, src/dosfs/msdos_file.c, src/dosfs/msdos_free.c, src/dosfs/msdos_fsunmount.c, src/dosfs/msdos_handlers_dir.c, src/dosfs/msdos_handlers_file.c, src/dosfs/msdos_init.c, src/dosfs/msdos_initsupp.c, src/dosfs/msdos_misc.c, src/dosfs/msdos_mknod.c, src/dosfs/msdos_node_type.c, src/dosfs/.cvsignore: New files. * configure.ac, src/Makefile.am, wrapup/Makefile.am: Modified to reflect addition.
* 2002-02-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-2817-0/+3798
| | | | | | | | | | * Submitted by Victor V. Vengerov <vvv@oktet.ru> and merged into the RTEMS source. * ChangeLog, Makefile.am, README, configure.ac, include/Makefile.am, include/rtems/bdbuf.h, include/rtems/blkdev.h, include/rtems/diskdevs.h, include/rtems/ramdisk.h, include/rtems/.cvsignore, include/.cvsignore, src/Makefile.am, src/bdbuf.c, src/blkdev.c, src/diskdevs.c, src/ramdisk.c, src/.cvsignore, .cvsignore: New files.
* 2002-02-27 Ilya Alexeev <ilya@continuum.ru>Joel Sherrill2002-02-276-10/+47
| | | | | | * net/if_ppp.c, pppd/auth.c, pppd/chat.c, pppd/pppd.h, pppd/sys-rtems.c: Add server with pap-authorization capabilities as well as eliminate some warnings.
* 2002-02-27 Eric Norum <eric.norum@usask.ca>Joel Sherrill2002-02-272-1/+10
| | | | | | * net/radix.c: Properly handle fetching the default route when there is no route. This was a bug in the original FreeBSD code and this fix is from an updated version of their code.
* 2001-02-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-272-1/+5
| | | | * rtems/score/cpu.h: Fix conditional to match current GCC.
* 2002-02-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-02-132-8/+4
| | | | * configure.ac: Fix the test to determine cpu context size.
* 2002-02-08 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-084-205/+216
| | | | | * iregdef.h, rtems/score/cpu.h: Reordered register in the exception stack frame to better match gdb's expectations.
* 2001-02-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-055-16/+230
| | | | | | | | | * cpu_asm.S: Enhanced to save/restore more registers on exceptions. * rtems/score/cpu.h (CPU_Interrupt_frame): Enhanced to list every register individually and document when it is saved. * idtcpu.h: Added constants for the coprocessor 1 registers revision and status.
* 2001-02-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-052-0/+5
| | | | * .cvsignore: Added stamp-h.in.
* 2001-02-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-054-0/+16
| | | | * rtems/Makefile.am, rtems/score/Makefile.am: Removed again.
* 2001-02-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-042-1/+6
| | | | | * rtems/score/cpu.h: IDLE task should not be FP. This was a mistake in the previous patch that has now been confirmed.
* 2001-02-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-042-3/+6
| | | | | * configure.ac: Removed references to rtems/Makefile and rtems/score/Makefile.
* 2001-02-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-015-294/+274
| | | | | | * rtems.ads, rtems.adb: Formatting cleaned up. Task based timer directives added. This is Timer_Initiate_Server, Timer_Server_Fire_After, and Timer_Server_Fire_When.
* 2001-02-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-011-0/+4
| | | | * ChangeLog: New file.
* 2001-02-01 Mike Siers <mikes@poliac.com>Joel Sherrill2002-02-012-1/+14
| | | | | | * pppd/rtemspppd.c (rtems_pppd_disconnect): Modified to avoid bringing the link down too fast. NOTE: Mike reports successfully running at 56K baud on a direct link.
* 2001-02-01 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill2002-02-014-148/+244
| | | | | | | | | * cpu.c: Enhancements and fixes for modifying the SR when changing the interrupt level. * cpu_asm.S: Fixed handling of FP enable bit so it is properly managed on a per-task basis, improved handling of interrupt levels, and made deferred FP contexts work on the MIPS. * rtems/score/cpu.h: Modified to support above changes.
* 2002-01-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-02-012-11/+26
| | | | * Makefile.am: Reflect 2002-01-23 changes.
* 2001-01-31 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-012-0/+26
| | | | | * include/rtems/rtems/timer.h: Missed merging these modifications in previous merge of new timer functionality.
* 2001-01-31 Mike Siers <mikes@poliac.com>Joel Sherrill2002-02-012-0/+28
| | | | * pppd/rtemsdialer.h: New file missed in previous commit.
* 2001-01-31 Mike Siers <mikes@poliac.com>Joel Sherrill2002-01-311-0/+9
| | | | | | | | | | | * Nice Update of PPPD support which eliminates the requiremetn that drivers be in the termios TASK_DRIVEN mode. Mike did significant testing and reports that it seems to be more stable and handle larger packets better. This patch replaces the termios tasks with more general pppd network driver tasks. The functions pppinput() and pppstart() get called from the interrupt service routine. * libc/termios.c: Added PPCDISC.
* 2001-01-31 Mike Siers <mikes@poliac.com>Joel Sherrill2002-01-3133-149/+11711
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * Nice Update of PPPD support which eliminates the requiremetn that drivers be in the termios TASK_DRIVEN mode. Mike did significant testing and reports that it seems to be more stable and handle larger packets better. This patch replaces the termios tasks with more general pppd network driver tasks. The functions pppinput() and pppstart() get called from the interrupt service routine. * Makefile.am, configure.ac, net/Makefile.am, net/bpf.h, net/ethernet.h, net/if.c, net/if.h, net/if_arp.h, net/if_dl.h, net/if_ethersubr.c, net/if_llc.h, net/if_loop.c, net/if_ppp.h, net/if_pppvar.h, net/if_types.h, net/netisr.h, net/ppp-comp.h, net/ppp_defs.h, net/pppcompress.h, net/radix.c, net/radix.h, net/raw_cb.c, net/raw_cb.h, net/raw_usrreq.c, net/route.c, net/route.h, net/rtsock.c, pppd/Makefile.am, pppd/README, pppd/STATUS, pppd/auth.c, pppd/cbcp.c, pppd/ccp.c, pppd/ccp.h, pppd/chap.c, pppd/chap.h, pppd/chap_ms.c, pppd/chap_ms.h, pppd/chat.c, pppd/demand.c, pppd/fsm.c, pppd/fsm.h, pppd/ipcp.c, pppd/ipcp.h, pppd/ipxcp.c, pppd/ipxcp.h, pppd/lcp.c, pppd/lcp.h, pppd/magic.c, pppd/magic.h, pppd/options.c, pppd/patchlevel.h, pppd/pathnames.h, pppd/pppd.8, pppd/pppd.h, pppd/rtemsmain.c, pppd/rtemspppd.c, pppd/rtemspppd.h, pppd/sys-rtems.c, pppd/upap.c, pppd/upap.h, pppd/utils.c, pppd/example/README, pppd/example/netconfig.h, wrapup/Makefile.am: Modified. * net/bsd-comp.c, net/if_ppp.c, net/ppp-deflate.c, net/ppp.h, net/ppp_tty.c, net/pppcompress.c, net/zlib.c, net/zlib.h: New file. * modem/, modem/.cvsignore, modem/Makefile.am, modem/ppp.c, modem/ppp.h, modem/ppp_tty.c, modem/pppcompress.c: Subdirectory removed.
* 2002-01-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-313-26/+31
* 2002-01-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-313-29/+31
| | | | | | | * rtems/Makefile.am: Removed. * rtems/score/Makefile.am: Removed. * configure.ac: Reflect changes above. * Makefile.am: Reflect changes above.
* 2001-01-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-302-3/+20
| | | | * Makefile.am: Corrected so .h files from rtems/score/ are installed.
* 2002-01-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-3014-104/+180
* 2002-01-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-3012-67/+150
* 2002-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-302-1/+4
| | | | * shell/shell.c: Remove #undef __STRICT_ANSI__.
* 2002-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-309-56/+103
* 2002-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-302-8/+21
| | | | * Makefile.am: Reflect changes from 2002-01-23.
