Ralf Corsepius <ralf.corsepius@rtems.org>
* libcsupport/src/gxx_wrapper.c: Reflect GCC-4.0's gthr-rtems.h.
* librpc/include/rpc/clnt.h, librpc/src/rpc/authunix_prot.c,
librpc/src/rpc/clnt_tcp.c, librpc/src/rpc/pmap_prot2.c,
librpc/src/rpc/pmap_rmt.c, librpc/src/rpc/rtems_portmapper.c,
librpc/src/rpc/svc_simple.c: Fix warnings.
* librpc/include/rpc/auth_des.h, librpc/include/rpc/xdr.h,
librpc/src/rpc/auth_des.c, librpc/src/rpc/auth_unix.c,
librpc/src/rpc/rpc_prot.c, librpc/src/xdr/xdr.c:
Misc. ansi-fications, misc. updates from FreeBSD.
* libnetworking/libc/res_debug.c: Added const to eliminate warnings.
* rtems/score/cpu.h: Remove warnings.
* librpc/include/rpc/xdr.h: Remove questionable comments.
* librpc/include/rpc/auth.h: Remove __P, ansi-fy.
* librpc/src/rpc/auth_none.c: Reflect changes above.
Partial update from FreeBSD.
* posix/include/rtems/posix/cond.h,
file posix/include/rtems/posix/mutex.h: Cosmetics.
* librpc/include/rpc/svc.h, librpc/include/rpc/xdr.h:
Remove __P(xx).
* libchip/Makefile.am, libnetworking/pppd/Makefile.am,
libnetworking/rtems_servers/Makefile.am,
libnetworking/rtems_telnetd/Makefile.am,
librdbg/Makefile.am, optman/Makefile.am, support/Makefile.am:
Eliminate CFLAGS_OPTIMIZE_V.
* httpd/Makefile.am, itron/Makefile.am, libblock/Makefile.am,
libcsupport/Makefile.am, libfs/Makefile.am, libmisc/Makefile.am,
libnetworking/Makefile.am, librpc/Makefile.am, posix/Makefile.am,
rtems/Makefile.am, sapi/Makefile.am, score/Makefile.am:
* Makefile.am: Eliminate CFLAGS_OPTIMIZE_V.
* aclocal/rtems-flags.m4: Remove (Unused).
* aclocal/prog-ccas.m4: Remove $(GCCSPECS).
* rtems/src/eventsurrender.c: Remove bogus type casts.
* sapi/Makefile.am: Eliminate *_FILES.
* aclocal/env-rtemscpu.m4: Remove CFLAGS_OPTIMIZE_V.
Remove CPU_CFLAGS.
* aclocal/prog-cc.m4: Don't invoke _RTEMS_FLAGS to set up
RTEMS_CFLAGS.
* automake/compile.am: AM_CFLAGS = RTEMS_CFLAGS.
Remove CPPFLAGS, CFLAGS, CPU_CFLAGS, CFLAGS_OPTIMIZE.
Cleanup comments.
* aclocal/env-rtemscpu.m4: Remove CFLAGS_DEBUG_V.
* aclocal/prog-cc.m4: Remove RTEMS_USE_GCC.
* automake/compile.am: Cleanup comments. Remove ASFLAGS.
* libnetworking/pppd/Makefile.am,
libnetworking/rtems_telnetd/Makefile.am:
Remove build-variant support.
* automake/compile.am, httpd/Makefile.am, itron/Makefile.am,
libblock/Makefile.am, libcsupport/Makefile.am, libfs/Makefile.am,
libmisc/Makefile.am, libnetworking/Makefile.am, librpc/Makefile.am,
posix/Makefile.am, rtems/Makefile.am, sapi/Makefile.am,
score/Makefile.am, wrapup/Makefile.am:
* Makefile.am: Remove build-variant support.
* httpd/rtems_webserver.h: Add doxygen preamble.
Add C++ guards.
* httpd/Makefile.am: Remove -DOS="RTEMS".
* score/include/rtems/score/chain.h:
Use uint32_t instead of unsigned32.
* score/src/chain.c: Remove superfluous type cast.
PR 733/rtems
* rtems/score/cpu.h: Remove output arg from inline asm in
_CPU_ISR_Disable.
* posix/include/aio.h, posix/include/devctl.h,
posix/include/intr.h, posix/include/mqueue.h,
posix/include/sched.h, posix/include/semaphore.h,
posix/src/ptimer.c, posix/src/ptimer1.c:
Include <unistd.h> instead of <sys/features.h> to pick up
_POSIX_* defines (Mandated by POSIX).
* score/include/rtems/system.h: Don't define NULL, include
<stddef.h>.
* cpu_asm.S: Collected PR 601 changes for commit to cvshead
for rtems-4.7
* libnetworking/net/if_ethersubr.c,
libnetworking/net/radix.h,
libnetworking/netinet/if_ether.h,
libnetworking/netinet/igmp_var.h,
libnetworking/netinet/in_var.h,
libnetworking/netinet/tcp_timer.h,
libnetworking/netinet/udp_usrreq.c,
libnetworking/rtems/rtems_glue.c:
Misc. updates from FreeBSD and bugfixes tripped by GCC-4.0.0.
* libnetworking/kern/kern_sysctl.c,
libnetworking/sys/sysctl.h: Add SYSCTL_CHILDREN_SET
(Update from FreeBSD for GCC-4.0.0).
* libnetworking/kern/kern_sysctl.c, libnetworking/netinet/ip_mroute.c,
libnetworking/sys/socketvar.h: Remove warnings.
* libnetworking/net/radix.c, libnetworking/net/radix.h,
libnetworking/net/route.h, libnetworking/netinet/if_ether.h,
libnetworking/netinet/in_var.h, libnetworking/netinet/tcp_timer.h,
libnetworking/netinet/udp_usrreq.c, libnetworking/netinet/udp_var.h,
libnetworking/sys/callout.h, libnetworking/sys/socketvar.h,
libnetworking/sys/sysctl.h: Cosmetics from FreeBSD.
* libmisc/capture/capture-cli.h, libmisc/capture/capture.h,
libmisc/monitor/monitor.h, libmisc/rtmonuse/rtmonuse.h,
libmisc/shell/shell.h: Partial doxygenification.
* libmisc/capture/capture.h: Use INT32_C for constants.
* libcsupport/include/chain.h,
libcsupport/include/clockdrv.h,
libcsupport/include/console.h,
libcsupport/include/iosupp.h,
libcsupport/include/ringbuf.h,
libcsupport/include/rtc.h,
libcsupport/include/spurious.h,
libcsupport/include/timerdrv.h,
libcsupport/include/vmeintr.h,
libcsupport/include/motorola/mc68230.h,
libcsupport/include/motorola/mc68681.h,
libcsupport/include/rtems/assoc.h,
libcsupport/include/rtems/cdefs.h,
libcsupport/include/rtems/error.h,
libcsupport/include/rtems/libcsupport.h,
libcsupport/include/rtems/libio.h,
libcsupport/include/rtems/libio_.h,
libcsupport/include/rtems/termiostypes.h,
libcsupport/include/zilog/z8036.h,
libcsupport/include/zilog/z8530.h,
libcsupport/include/zilog/z8536.h: Add doxygen preamble.
* libcsupport/src/mallocfreespace.c, rtems/Makefile.am,
rtems/include/rtems/rtems/region.h, score/Makefile.am,
score/include/rtems/score/heap.h, score/src/heapgetinfo.c: Add
capability to return information about just the free blocks in a
region or heap. Also changed the semantics of free space available
to be the largest block of memory that can be allocated.
* rtems/src/regiongetfreeinfo.c, score/src/heapgetfreeinfo.c: New files.
: score/include/rtems/score/object.h,
score/src/objectinitializeinformation.c: Remove warning.
* score/include/rtems/score/object.h, score/src/objectclearname.c,
score/src/objectcopynamestring.c: Fixing warning led to making
changes to multiple prototypes for object support routines.
* rtems/old-exceptions/cpu.h: Make compile in assembly.
* libcsupport/src/ttyname_r.c: Remove warning for using _fstat.
* aclocal/enable-itron.m4, aclocal/check-itron.m4:
Allow building itron for unix.
* libnetworking/Makefile.am: Don't install bpfilter.h (Private
header).
* libblock/include/rtems/bdbuf.h,
libblock/include/rtems/blkdev.h,
libblock/include/rtems/diskdevs.h,
libblock/include/rtems/ide_part_table.h,
libblock/include/rtems/ramdisk.h:
