Return error for unknown/unsupported ioctl command.
(Change merged from freeBSD).
* libnetworking/kern/kern_sysctl.c: Change int to int32_t.
* libnetworking/net/if_loop.c: Add cast to long.
These plus a patch to machine/param.h let the h8300 build multilib.
which included commits to RCS files with non-trunk default branches.
fixed wrong calculation of 1000baseTx autonegotiation
result.
* cpu.c, rtems/score/sh.h: Recognize sh2e variant so multilibs will all
compile.
* .cvsignore: New file.
* rtems/score/cpu.h: Because gcc implicitly uses floating point turn on
floating point for all threads if there is a hardware FPU.
* rtems/score/cpu.h, rtems/score/cpu_asm.h, rtems/score/nios2.h,
rtems/score/types.h: New files.
* configure.ac, librpc/src/xdr/xdr_float.c, score/cpu/Makefile.am: New
port to Altera NIOS II.
* ChangeLog, Makefile.am, cpu.c, cpu_asm.S, irq.c, preinstall.am,
rtems/asm.h: New files.
read ANER and include partner's autoneg
capability when determining active link parameters.
* libnetworking/machine/in_cksum.h: Replaced PPC and
i386 assembly algorithms (must not assume carry bit is preserved
across multiple asms). Added packet header as a 'm' input
operand for all CPU variants. Added carry bit to clobber list.
Checked inline assembly; added early-clobber '&' to output operands
of multi-instruction asms.
ioctl is reported.
PR 1124/rtems
* score/include/rtems/score/threadq.h, score/src/coremutexseize.c,
score/src/coremutexsurrender.c, score/src/threadqenqueue.c,
score/src/threadqenqueuefifo.c, score/src/threadqenqueuepriority.c:
The placement of the changing a thread's priority when using priority
ceiling should be on the successful transfer of the mutex -- not when
the thread tries to acquire. Plus the lack of a dispatch disable
point lead to the potential for a thread timing out and already
having inherited the ceiling priority.
* Makefile.am: Add ampolish3.
* ampolish3: New.
* aclocal/rtems-ampolish.m4: Reflect using in-sourcetree ampolish3.
* libnetworking/net/if_var.h: #include <sys/queue.h>.
Cosmetics from FreeBSD.
* libcsupport/include/rtems/cdefs.h: Partial update from freebsd.
* libcsupport/src/base_fs.c: Remove extra endif.
PR 1101/rtems
* libcsupport/src/base_fs.c, rtems/src/taskcreate.c, rtems/src/tasks.c,
score/src/coremutex.c: Remove dead code.
* cpu_asm.S: Reduce mask from 0xffc to 0x3fc so only the vector
bits are used when calculating the exception vector.
* libcsupport/include/rtems/libio.h: Add extern "C" {}.
* posix/src/mqueue.c: Remove duplicate #include <limits.h>.
PR 1088/rtems
* posix/src/ptimer.c: Add missing #include <limits.h>.
* cpu.c: Added __mips==32 to fix build problems on those targets
caused by the Bruce Robinson.
B.Robinson patch
* posix/Makefile.am, posix/preinstall.am,
posix/include/rtems/posix/timer.h, posix/src/ptimer.c,
posix/src/ptimer1.c, sapi/src/posixapi.c,
score/include/rtems/score/object.h:
* itron/src/trcv_mbf.c, posix/src/semopen.c,
rtems/src/taskvariableadd.c, score/macros/rtems/score/heap.inl: Fix
warnings.
* cpu.c, cpu_asm.S: Fixed ARM Data Abort handling.
Patch from Steven Johnson <sjohnson@sakuraindustries.com>
* aclocal/rtems-ampolish.m4: New.
* configure.ac: Use RTEMS_AMPOLISH3.
* aclocal/version.m4: Updated to rtems-4.6.99.3.
