* sapi/include/confdefs.h,
score/include/rtems/score/schedulerpriority.h: Add comments.
score/include/rtems/score/schedulerpriority.h: C++ compatibility.
* libnetworking/lib/ftpfs.c: Workaround for some firewalls.
* sapi/include/confdefs.h, score/Makefile.am,
score/include/rtems/score/scheduler.h,
score/include/rtems/score/schedulerpriority.h,
score/inline/rtems/score/scheduler.inl,
score/inline/rtems/score/schedulerpriority.inl,
score/src/scheduler.c, score/src/schedulerpriority.c,
score/src/schedulerpriorityblock.c,
score/src/schedulerpriorityschedule.c,
score/src/schedulerpriorityunblock.c,
score/src/schedulerpriorityyield.c, score/src/threadchangepriority.c,
score/src/threadclose.c, score/src/threadinitialize.c,
score/src/threadsetpriority.c, score/src/threadsettransient.c:
Significant clean up on Scheduler Plugin Interface. Names were
shortened. Missing operations added. Many scheduler files had
unneeded includes removed. Made pointer to scheduler information in
Thread_Control and Scheduler_Control a void * pointer because the
thread and scheduler wrapper should be unaware of scheduler types AND
this is broken for user provided schedulers.
* score/src/schedulerpriorityallocate.c,
score/src/schedulerpriorityenqueue.c,
score/src/schedulerpriorityenqueuefirst.c,
score/src/schedulerpriorityextract.c,
score/src/schedulerpriorityfree.c,
score/src/schedulerpriorityupdate.c: New files.
* score/src/schedulerprioritythreadschedulerallocate.c,
score/src/schedulerprioritythreadschedulerfree.c,
score/src/schedulerprioritythreadschedulerupdate.c: Removed.
* sapi/include/confdefs.h, sapi/include/rtems/config.h,
score/src/schedulerprioritythreadschedulerupdate.c,
score/src/threadclearstate.c, score/src/threadclose.c,
score/src/threadinitialize.c, score/src/threadready.c,
score/src/threadresume.c, score/src/threadsetpriority.c,
score/src/threadsetstate.c, score/src/threadsuspend.c: Simplify the
pluggable scheduler interface. Its configuration made a table
of available schedulers and set a pointer to one of the.
This was heavy handed since you can only use one scheduler
in an application. This configuration mechanism resulted in a
scheduler pointer being passed around when you could put all
scheduler configuration in an initialized structure.
* libmisc/Makefile.am, libmisc/fb/mw_uid.c, libmisc/fb/mw_uid.h: Clean
up. Add Doxygen style comments. Add method to print uid structure.
* libmisc/fb/mw_print.c: New file.
* libblock/include/rtems/bdpart.h (rtems_bdpart_format):
Preserve previous API.
* libblock/src/bdpart-create.c, libblock/src/bdpart-read.c,
libblock/src/bdpart-write.c: Reflect changes above.
* libmisc/shell/fdisk.c: Reflect changes above.
* libcsupport/src/rtems_heap_extend.c: New file.
* libcsupport/Makefile.am: Reflect change from above.
* libcsupport/include/rtems/malloc.h: Declare rtems_heap_extend().
* score/include/rtems/score/heap.h: Documentation.
* rtems/powerpc/registers.h: Added FSL_EIS_ATBL, FSL_EIS_ATBL, and
FSL_EIS_SPEFSCR defines.
* score/src/wkspace.c: Removed NULL pointer check from
_Workspace_Free().
* libmisc/capture/capture.c, posix/src/keyfreememory.c,
posix/src/pthread.c, score/include/rtems/score/wkspace.h,
score/src/objectextendinformation.c,
score/src/objectnamespaceremove.c, score/src/objectsetname.c,
score/src/wkspace.c: Many places were checking for a NULL pointer
before calling _Workspace_Free. By moving the check into
_Workspace_Free, we eliminate a number of conditional paths and make
it harder to return a NULL pointer.
* rtems/powerpc/registers.h: Added MSR_UCLE, MSR_SPE, MSR_WE, and
MSR_UBLE defines.
* rtems/src/semtranslatereturncode.c,
score/include/rtems/score/coremutex.h: Returns tests to running
state.
* rtems/src/semtranslatereturncode.c, score/src/coremutexsurrender.c:
Now all conditionals have the correct sense and all tests pass.
* score/include/rtems/score/coremutex.h,
score/inline/rtems/score/coremutex.inl, score/src/apimutexallocate.c:
Fix direction of conditional and eliminate use of nesting is error
when POSIX is disabled.
score/src/coremutexsurrender.c,
score/src/objectinitializeinformation.c: Disable code not reachable
when POSIX is not enabled.
* score/include/rtems/score/context.h: Spacing.
* score/include/rtems/score/basedefs.h:
* rtems/score/cpu.h, rtems/score/sparc64.h:
* rtems/powerpc/registers.h, rtems/score/cpu.h:
* irq.c:
* cpu.c, rtems/score/cpu.h, rtems/score/m68k.h:
* context_init.c:
* context_init.c, cpu.c, varvects.h, rtems/score/cpu.h,
rtems/score/m32c.h:
* cpu.c, sse_test.c, rtems/score/cpu.h, rtems/score/i386.h,
rtems/score/interrupts.h:
* cpu.c, rtems/asm.h, rtems/score/cpu.h:
* rtems/score/cpu.h:
* avr/power.h: Revert previous patch.
* cpu.c, avr/interrupt.h, avr/power.h, rtems/score/cpu.h:
* cpu.c, rtems/score/cpu.h:
* cpu.c, irq.c, rtems/score/lm32.h:
* context.c, cpu.c, rtems/score/cpu.h, rtems/score/sh.h:
* cpu.c, rtems/score/mips.h:
* rtems/score/cpu.h, rtems/score/sparc.h:
* configure.ac: Remove extraneous spaces.
Eliminate unnamed union (Non c99-compliant).
* sapi/include/confdefs.h: Fix typo.
* include/rtems/btimer.h: New.
* Makefile.am: Add rtems/btimer.h
* libcsupport/include/timerdrv.h: Reflect having split out functions
to rtems/btimer.h.
* libfs/src/rfs/rtems-rfs-rtems.c: Fix bug where the eval path did
not close an inode.
* libmisc/shell/hexdump-display.c:
Eliminate bcopy, bzero, bcmp, index (Obsolete).
* libmisc/shell/hexdump-parse.c: Eliminate index (Obsolete).
* libmisc/shell/hexsyntax.c: Eliminate rindex (Obsolete).
* libmisc/shell/main_hexdump.c: Eliminate rindex (Obsolete).
* libmisc/shell/main_rm.c: Eliminate rindex (Obsolete).
PR 1733/cpukit
* score/src/isr.c: If target architecture does nto require stack
initialization, then do not perform adjustment.
* libcsupport/src/printk.c: Fix typo.
* libmisc/stringto/stringtounsignedchar.c,
libmisc/stringto/stringtounsignedint.c: Reformat range check.
* libmisc/Makefile.am: Add stringto/stringtolongdouble.c.
* libmisc/stringto/stringtolongdouble.c: New.
* libmisc/stringto/stringto.h: Rename header-guard.
Add rtems_string_to_long_double.
* libmisc/stringto/stringtoint.c: Reformat range check.
Add check for result==0.
* libmisc/stringto/stringtofloat.c: Reformat range check.
Add check for result = -HUGE_VALF.
