This adds the set of functions necessary to allow more generic handling
of machine exceptions. This initial patch offers the ability to
manipulate a CPU_Exception_frame and resume execution using that
exception information with or without thread dispatch. These functions
are gated behind the RTEMS_EXCEPTION_EXTENSIONS configuration option.
Using 32bit types like uint32_t for pointers creates issues on 64 bit
architectures like AArch64. Replaced occurrences of these with
uintptr_t, which will work for both 32 and 64 bit architectures. Added
hex_decode_addr function to rtems-debugger.
Move a code block to the new function _Thread_Scheduler_withdraw_nodes()
to ease code review.
Mention that resetting the processor usage time of tasks has no impact
on the period status and statistics.
Remove no longer relevant RTEMS_NOT_DEFINED error status.
Update #4528.
Update #4524.
The rate monotonic period statistics were affected by
rtems_cpu_usage_reset(). The logic to detect and work around a CPU
usage reset was broken.
The Thread_Contol::cpu_time_used is changed to contain the processor
time used throughout the entire lifetime of the thread. The new member
Thread_Contol::cpu_time_used_at_last_reset is added to contain the
processor time used at the time of the last reset through
rtems_cpu_usage_reset(). This decouples the resets of the CPU usage and
the rate monotonic period statistics.
Update #4528.
Update #4524.
This reworks the existing MicroBlaze architecture port and BSP to
achieve basic functionality using the latest RTEMS APIs.
Add a stack allocator hook specifically for allocation of IDLE thread stacks.
This allows the user to decide if IDLE thread stacks are statically allocated
or handled by the same custom allocator mechanism as other thread stacks.
Closes #4524.
Do not use a direct thread dispatch in
_Thread_queue_Surrender_priority_ceiling() since it may be used in condition
variables using POSIX mutexes.
Close #4526.
Updates #2452.
Commit 18c8a270c296addff87f96b8c248f27eba31c24f removed
_Thread_queue_Do_nothing_extract() so we have to check for a non-NULL
queue in all configurations.
Set the postponed jobs count to zero in rtems_rate_monotonic_cancel() so that
rtems_rate_monotonic_get_status() returns a consistent status for inactive
periods.
Update #4511.
The schedule operation is only called by rtems_task_mode(). It is
called if preempt mode of the executing thread changes from disabled to
enabled. Since the EDF SMP scheduler does not support the disabled
preemption mode, the schedule operation is never called.
Write the documentation from scratch.
Clarify group description.
Update #3706.
Define the group in the header file which is used by <rtems/confdefs.h>.
Update #3706.
Update #3706.
Update #3706.
Update #3706.
Update #3706.
All other architectures use uint32_t for interrupt levels and there is
no reason not to do so on AArch64.
Context validation for AArch64 was ported from the ARM implementation
without a reinterpretation of the actual requirements. The spcontext01
test just happened to pass because the set of scratch registers in ARM
is a subset of the scratch registers in AArch64.
Replace the boolen return value with the new enum
Thread_queue_Deadlock_status. This improves the code readability.
Improve documentation. Shorten function names.
For uniprocessor configurations, this patch removes dead code in the
_Thread_queue_Surrender() and _Thread_queue_Surrender_priority_ceiling()
functions.
Dead code is removed from _Thread_queue_Surrender_sticky().
This function was unused. It was a relict of the thread queue rework done
during the SMP support development. In an early stage, the extract operation
was called with a NULL thread queue. However, this is no longer the case. The
extract operation is only called if we have a non-NULL thread queue.
Reflect renamed specification item.
Adjust parameter names to match with the declaration. This avoid using
a name reserved by the C standard: "time".
Close #4035.
Close #2548.
Move a code block to its own new function
_Thread_Initialize_scheduler_and_wait_nodes(). Add comments.
This adds SMP support for AArch64 in cpukit and for the ZynqMP BSPs.
Close #3250.
Close #4081.
The T_now_tick() is a fall back time measurement using the CPU counter
in case no Clock Driver is configured. Some CPU counter may overflow
during the test execution. Accumulate the elapsed time to reduce the
chance of CPU counter overflows.
If SMP support is enabled and the system has exactly one processor, then
it may use an uniprocessor scheduler. The ask for help, reconsider help
request, and withdraw node operations can be NULL in this case, since
they are only used if a thread has at least one helping scheduler node.
At least two schedulers are required to get a helping node and each
scheduler involved must own at least one processor. This is not
possible on a system with exactly one processor.
Issue the new fatal SMP error
SMP_FATAL_SCHEDULER_REQUIRES_EXACTLY_ONE_PROCESSOR if the system starts
with not exactly one processor and an uniprocessor scheduler is
configured.
The uniprocessor schedulers do not support systems with more than more
processors. So they rivially support thread pinning and thus the
SMP_FATAL_SCHEDULER_PIN_OR_UNPIN_NOT_SUPPORTED cannot happen.
Add a second default implementation for SMP schedulers which do not
support thread pinning.
Change license to BSD-2-Clause according to file history and re-licensing
agreement.
Update #3053.
Rename SCHEDULER_OPERATION_DEFAULT_GET_SET_AFFINITY in
SCHEDULER_DEFAULT_SET_AFFINITY_OPERATION. Add Doxygen comment.
Rename SCHEDULER_OPERATION_DEFAULT_ASK_FOR_HELP in
SCHEDULER_DEFAULT_SMP_OPERATIONS. Add a Doxygen comment.
psxdevctl is supposed to return the value in errno. Before, it was
returning -1 and setting errno. Changed the tests to reflect these
changes. Added code from RRADE's posix_devctl.c.
Closes #4506
Correct the description of the ``count`` parameter of
rtems_message_queue_flush().
Update #4508.
Move the definition of the top-level Classic API implementation group to
an implementation header file.
