* Per PR147 addressed problems when reseting and inserting a timer
into a timer chain that did not honor time passage since the last
time the timer server was scheduled and the new insertion.
* include/rtems/rtems/timer.h, src/timerreset.c, src/timerserver.c,
src/timerserverfireafter.c, src/timerserverfirewhen.c: Broke up
the "reset server" routine into a set of very specific routines
that allowed the server to be unscheduled, timer chains to be
"synchronized" with the current time before inserting a new timer.
* cpu.c: Replace NO_TABLE_MOVE-support by external function
(code moved to libcpu/sparc/tbr/tbr.c).
* cpu.h: Replace NO_TABLE_MOVE-support by external function
(code moved to libcpu/sparc/tbr/tbr.h).
* sparc.h: Add sparc_init_tbr (implemented in libcpu/sparc/tbr/tbr.c).
* PR132 requested some tinkering ot lower memory.
* include/confdefs.h: Lowered footprint of device driver table
and statically configure user extensions. Now if no static
extensions are configured, then the table is not instantiated.
* cpu.c: Define fix_syscall_errno() to nothing so MP links.
* src/dosfs/fat_file.c: Remove bsp.h.
fat_file_write(.. const char*buf ..).
* src/dosfs/fat_file.h: fat_file_write(.. const char*buf ..).
* include/rpc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* include/rpcsvc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/rpc/PSD.doc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/rpc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/xdr/Makefile.am: Remove AUTOMAKE_OPTIONS.
* arpa/Makefile.am: Remove AUTOMAKE_OPTIONS.
* kern/Makefile.am: Remove AUTOMAKE_OPTIONS.
* lib/Makefile.am: Remove AUTOMAKE_OPTIONS.
* libc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* machine/Makefile.am: Remove AUTOMAKE_OPTIONS.
* net/Makefile.am: Remove AUTOMAKE_OPTIONS.
* netinet/Makefile.am: Remove AUTOMAKE_OPTIONS.
* nfs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* pppd/Makefile.am: Remove AUTOMAKE_OPTIONS.
* rtems_servers/Makefile.am: Remove AUTOMAKE_OPTIONS.
* rtems_telnetd/Makefile.am: Remove AUTOMAKE_OPTIONS.
* rtems_webserver/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sys/Makefile.am: Remove AUTOMAKE_OPTIONS.
* vm/Makefile.am: Remove AUTOMAKE_OPTIONS.
* devnull/Makefile.am: Remove AUTOMAKE_OPTIONS.
* dummy/Makefile.am: Remove AUTOMAKE_OPTIONS.
* dumpbuf/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mw-fb/Makefile.am: Remove AUTOMAKE_OPTIONS.
* rootfs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shell/Makefile.am: Remove AUTOMAKE_OPTIONS.
* untar/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/dosfs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/imfs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* cpu/Makefile.am: Remove AUTOMAKE_OPTIONS.
* inline/Makefile.am: Remove AUTOMAKE_OPTIONS.
* macros/Makefile.am: Remove AUTOMAKE_OPTIONS.
* PR144
* nfs/bootp_subr.c bootpc_init(): Performs a write to memory address
0 when called for the first time. This is done when trying to clear
the variable "dhcp_hostname".
* PR162
* net/if_ppp.c ppp_txdaemon(), net/if_pppvar.h pppstart(): Local
variables must not be used in a device write routines. Now
ppp_softc structure have own character for writing to device
(sc_outchar). I think that converting local variables to static
is not a right solution, because problems will occur in the case
of two or more ppp instances.
* net/ppp_tty.c pppstart(): Type of the ioffset variable must be
u_long, otherwise in the case of the big output packet endless
loop may occur.
* ChangeLog: Undo incorrect addition of entry.
* net/if_ppp.c, net/ppp_tty.c: Initial preparations for multiple
PPPD connections.
* src/bdbuf.c (avl_insert, avl_remove): Reimplemented from scratch
to avoid using GPLed sources in RTEMS core.
* src/bdbuf.c, include/rtems/bdbuf.h: Remove "binary tree"
implementation which was used for debugging only.
* PR158
* libc/rcmd.c, libc/rcmd.c: Enable the rcmd() library call by
commenting out the parts that deal with signals. This enables
RTEMS to 'rsh' command to a server connecting fd to remote stdio.
The 'server-side' parts of this file which deal with authentication
are disabled since they are not needed.
* cpu_asm.S: Now compiles on 4600 and 4650.
* PR143
* lib/include/rtems/termiostypes.h: Removed unneeded volatile on
"theBuf" since no byte is read more than once anyway.
* PR148.
* monitor/mon-prmisc.c: Fixed to print task states correctly.
Addressing PR 140.
* src/dosfs/config.h.in: Removed.
* src/dosfs/stamp-h2.in: Removed.
* .cvsignore: Add config.h*, stamp-h*.
* configure.ac: Remove AC_SRC_DIR(.../dosfs.h).
Remove AM_CONFIG_HEADER(src/dosfs/config.h).
Remove AM_CONFIG_HEADER(src/imfs/config.h).
Add AM_CONFIG_HEADER(config.h).
* src/dosfs/Makefile.am: INCLUDES = -I../.. .
* src/imfs/Makefile.am: INCLUDES = -I../.. .
* cpu_asm.S: Fixed a sneaky return from int w/ ints disabled bug.
* rtems/score/cpu.h: Fixed register numbering in comments and made
interrupt enable/disable more robust.
Reported and tracked as PR130.
* src/dosfs/Makefile.am: Reworked, Disable dosfs for UNIX.
* wrapup/Makefile.am: Disable dosfs for UNIX.
* src/extension.c: Split to reduce minimum code size per PR134.
* src/extensioncreate.c, src/extensiondelete.c, src/extensionident.c:
New files.
src/Makefile.am: Modified to reflect above.
* rtems/score/m68k.h: m68k_swap_u32 fix typo.
* cpu_asm.S: Added support for the debug exception vector, cleaned
up the exception processing & exception return stuff. Re-added
EPC in the task context structure so the gdb stub will know where
a thread is executing. Should've left it there in the first place...
* idtcpu.h: Added support for the debug exception vector.
* cpu.c: Added ___exceptionTaskStack to hold a pointer to the
stack frame in an interrupt so context switch code can get the
userspace EPC when scheduling.
* rtems/score/cpu.h: Re-added EPC to the task context.
* rtems/score/m68k.h [M68K_COLDFIRE_ARCH] (CPU_swap_u16, CPU_swap_u32):
Generic implementation of endian swap primitives added for Coldfire
family.
* src/pthreadonce.c: Task is not preemptable while running a
pthread_once init function. This is slightly less heavy handed
than disabling dispatching and seems better than consuming a mutex.
* libc/gxx_wrappers.c: Task is not preemptable while running a
* cpu_asm.S: Fixed exception return address, modified FP context
switch so FPU is properly enabled and also doesn't screw up the
exception FP handling.
* idtcpu.h: Added C0_TAR, the MIPS target address register used for
returning from exceptions.
* iregdef.h: Added R_TAR to the stack frame so the target address
can be saved on a per-exception basis. The new entry is past the
end of the frame gdb cares about, so doesn't affect gdb or cpu.h
stuff.
* rtems/score/cpu.h: added an #ifdef so cpu_asm.S can include it
to obtain FPU defines without systax errors generated by the C
defintions.
* cpu.c: Improved interrupt level saves & restores.
* src/imfs/.cvsignore: Added stamp-h1.in
* DOS filesystem including FAT12, FAT16, and FAT32 support submitted.
* src/dosfs, src/dosfs/Makefile.am, src/dosfs/stamp-h2.in,
src/dosfs/config.h.in, src/dosfs/dosfs.h, src/dosfs/fat.c,
src/dosfs/fat.h, src/dosfs/fat_fat_operations.c,
src/dosfs/fat_fat_operations.h, src/dosfs/fat_file.c,
src/dosfs/fat_file.h, src/dosfs/msdos.h, src/dosfs/msdos_create.c,
src/dosfs/msdos_dir.c, src/dosfs/msdos_eval.c, src/dosfs/msdos_file.c,
src/dosfs/msdos_free.c, src/dosfs/msdos_fsunmount.c,
src/dosfs/msdos_handlers_dir.c, src/dosfs/msdos_handlers_file.c,
src/dosfs/msdos_init.c, src/dosfs/msdos_initsupp.c,
src/dosfs/msdos_misc.c, src/dosfs/msdos_mknod.c,
src/dosfs/msdos_node_type.c, src/dosfs/.cvsignore: New files.
* configure.ac, src/Makefile.am, wrapup/Makefile.am: Modified to
reflect addition.
* Submitted by Victor V. Vengerov <vvv@oktet.ru> and merged
into the RTEMS source.
* ChangeLog, Makefile.am, README, configure.ac, include/Makefile.am,
include/rtems/bdbuf.h, include/rtems/blkdev.h, include/rtems/diskdevs.h,
include/rtems/ramdisk.h, include/rtems/.cvsignore, include/.cvsignore,
src/Makefile.am, src/bdbuf.c, src/blkdev.c, src/diskdevs.c,
src/ramdisk.c, src/.cvsignore, .cvsignore: New files.
* net/if_ppp.c, pppd/auth.c, pppd/chat.c, pppd/pppd.h,
pppd/sys-rtems.c: Add server with pap-authorization
capabilities as well as eliminate some warnings.
* net/radix.c: Properly handle fetching the default route when there
is no route. This was a bug in the original FreeBSD code and this
fix is from an updated version of their code.
* rtems/score/cpu.h: Fix conditional to match current GCC.
* configure.ac: Fix the test to determine cpu context size.
* iregdef.h, rtems/score/cpu.h: Reordered register in the
exception stack frame to better match gdb's expectations.
* cpu_asm.S: Enhanced to save/restore more registers on
exceptions.
* rtems/score/cpu.h (CPU_Interrupt_frame): Enhanced to list every
register individually and document when it is saved.
* idtcpu.h: Added constants for the coprocessor 1 registers
revision and status.
* .cvsignore: Added stamp-h.in.
* rtems/Makefile.am, rtems/score/Makefile.am: Removed again.
* rtems/score/cpu.h: IDLE task should not be FP. This was a mistake
in the previous patch that has now been confirmed.
* configure.ac: Removed references to rtems/Makefile and
* rtems.ads, rtems.adb: Formatting cleaned up. Task based timer
directives added. This is Timer_Initiate_Server,
Timer_Server_Fire_After, and Timer_Server_Fire_When.
