* configure.ac: Require autoconf-2.60.
* configure.ac, aclocal/multi.m4, aclocal/prog-cc.m4, aclocal/prog-ccas.m4
automake/compile.am: Adaptations to automake-1.10.
which included commits to RCS files with non-trunk default branches.
* libmisc/monitor/mon-command.c: Flush stdout after updating the
command line.
* libnetworking/net/route.c, librpc/src/rpc/auth_none.c,
librpc/src/rpc/auth_unix.c, librpc/src/rpc/authunix_prot.c,
librpc/src/rpc/rpc_callmsg.c, librpc/src/rpc/rpc_prot.c,
librpc/src/rpc/rtems_portmapper.c: Removed warnings.
* sapi/include/confdefs.h, sapi/src/posixapi.c, sapi/src/rtemsapi.c:
Add Classic API Barriers and commented out hooks to initialize .
* rtems/Makefile.am, rtems/preinstall.am, rtems/include/rtems.h,
rtems/include/rtems/rtems/attr.h, rtems/include/rtems/rtems/config.h,
rtems/inline/rtems/rtems/attr.inl, rtems/macros/rtems/rtems/attr.inl:
Add Classic API Barriers.
* rtems/include/rtems/rtems/barrier.h,
rtems/include/rtems/rtems/barriermp.h,
rtems/inline/rtems/rtems/barrier.inl,
rtems/macros/rtems/rtems/barrier.inl, rtems/src/barrier.c,
rtems/src/barriercreate.c, rtems/src/barrierdelete.c,
rtems/src/barrierident.c, rtems/src/barrierrelease.c,
rtems/src/barriertranslatereturncode.c, rtems/src/barrierwait.c:
New files.
score/include/rtems/score/coresem.h,
score/include/rtems/score/states.h,
score/inline/rtems/score/coresem.inl: Add SuperCore Barriers,
SpinLocks and a partial implementation of RWLocks.
* score/include/rtems/score/corebarrier.h,
score/include/rtems/score/corerwlock.h,
score/include/rtems/score/corespinlock.h,
score/inline/rtems/score/corebarrier.inl,
score/inline/rtems/score/corerwlock.inl,
score/inline/rtems/score/corespinlock.inl,
score/macros/rtems/score/corebarrier.inl,
score/macros/rtems/score/corerwlock.inl,
score/macros/rtems/score/corespinlock.inl, score/src/corebarrier.c,
score/src/corebarrierrelease.c, score/src/corebarrierwait.c,
score/src/corespinlock.c, score/src/corespinlockrelease.c,
score/src/corespinlockwait.c: New files.
* libmisc/cpuuse/cpuuse.c, libmisc/cpuuse/cpuuse.h: Promote CPU Usage
to first class citizen. Rename to start with rtems_ and include
documentation in user guide.
* libnetworking/rtems/rtems_malloc_mbuf.c: Removed warning by adding
prototype of malloc.
* libmisc/stackchk/check.c, libmisc/stackchk/internal.h,
libmisc/stackchk/stackchk.h: Move stack to first class citizen
status. Include it in User Manual and rename to start with rtems_.
* libmisc/mw-fb/mw_fb.c, libmisc/mw-fb/mw_fb.h, libmisc/mw-fb/mw_uid.c,
libmisc/mw-fb/mw_uid.h: Remove warning.
* cpu.c: Remove warning.
* libnetworking/netinet/in_cksum.c: Joel should have used int32_t not
uint32_t when removing warnings.
PR 1170/rtems
* rtems/src/timerserver.c: Timer Server created the TIME task with a
hard-coded hexadecimal number instead of using rtems_build_name. This
resulted in a byte-swapped name on some platforms.
* pppd/pppd.h: Fix the bug in name change. The UNTIMEOUT
macro did not use the ppp version.
* libnetworking/net/if_loop.c: Remove warning.
to 'pppuntimeout' to avoid name clash with [future]
bsdnet kernel routine.
* libcsupport/src/malloc.c, libnetworking/rtems/rtems_glue.c,
libnetworking/sys/mbuf.h: Remove warnings -- use uintptr_t or
properly sized integers.
* rtems/score/cpu.h: Revert change. It did not appear to correct all
warnings.
* ftpd/ftpd.c, libcsupport/include/sys/ioccom.h,
libcsupport/src/ioctl.c, libnetworking/kern/uipc_mbuf.c,
libnetworking/libc/inet_addr.c, libnetworking/net/ethernet.h,
libnetworking/net/if.c, libnetworking/net/if_ethersubr.c,
libnetworking/net/if_ppp.c, libnetworking/net/if_pppvar.h,
libnetworking/net/if_var.h, libnetworking/net/ppp_tty.c,
libnetworking/netinet/in_cksum.c, libnetworking/nfs/bootp_subr.c,
libnetworking/rtems/rtems_bsdnet_internal.h,
libnetworking/sys/mbuf.h, pppd/md4.c, pppd/pppd.h: Remove warnings
due to improper use of int which shows up on 16 bit targets. Added
ioctl_command_t since IOCTL command argument does not reliably fit
into 16 bits.
* libcsupport/include/sys/ioccom.h, libnetworking/kern/uipc_socket2.c,
libnetworking/net/ethernet.h, libnetworking/net/if.h,
libnetworking/net/if_ethersubr.c, libnetworking/net/if_ppp.c,
libnetworking/net/if_pppvar.h, libnetworking/net/ppp_tty.c,
libnetworking/net/pppcompress.c, libnetworking/net/slcompress.c,
libnetworking/netinet/in.h, libnetworking/netinet/ip_icmp.c,
libnetworking/netinet/tcp.h, libnetworking/netinet/tcp_seq.h,
libnetworking/sys/protosw.h, libnetworking/sys/socketvar.h: Remove
warnings. Most of the warnings were 16/32 bit integer sizing issues.
Some constants had L appended, some had casts add, some types were
changed to reflect a bit width requirement.
* libmisc/cpuuse/cpuuse.c, libmisc/monitor/mon-command.c,
libmisc/monitor/mon-driver.c, libmisc/monitor/mon-symbols.c,
libmisc/rtmonuse/rtmonuse.c, libmisc/stackchk/check.c,
libnetworking/libc/res_debug.c, telnetd/telnetd.c: Remove printf
format warnings.
* libcsupport/src/utsname.c, libnetworking/libc/res_debug.c,
libnetworking/net/if_media.h, libnetworking/rtems/rtems_mii_ioctl.c,
librpc/src/rpc/svc_simple.c: Remove printf format warnings.
* libmisc/capture/capture-cli.c: Remove printf format warnings.
* score/include/rtems/score/object.h: _Objects_Local_node is a uint16_t
so cast the _Objects_Local_node constant to 1.
* rtems/score/cpu.h: Correct inline assembly constraints.
* libfs/src/dosfs/fat.h, libfs/src/dosfs/msdos.h,
libfs/src/dosfs/msdos_create.c, libfs/src/dosfs/msdos_eval.c,
libfs/src/dosfs/msdos_file.c, libfs/src/dosfs/msdos_free.c,
libfs/src/dosfs/msdos_fsunmount.c, libfs/src/dosfs/msdos_init.c,
libfs/src/dosfs/msdos_misc.c, libfs/src/dosfs/msdos_mknod.c,
libfs/src/imfs/imfs_debug.c: Remove warnings.
Return error for unknown/unsupported ioctl command.
(Change merged from freeBSD).
* libnetworking/kern/kern_sysctl.c: Change int to int32_t.
* libnetworking/net/if_loop.c: Add cast to long.
These plus a patch to machine/param.h let the h8300 build multilib.
fixed wrong calculation of 1000baseTx autonegotiation
result.
* cpu.c, rtems/score/sh.h: Recognize sh2e variant so multilibs will all
compile.
* .cvsignore: New file.
* rtems/score/cpu.h: Because gcc implicitly uses floating point turn on
floating point for all threads if there is a hardware FPU.
* rtems/score/cpu.h, rtems/score/cpu_asm.h, rtems/score/nios2.h,
rtems/score/types.h: New files.
* configure.ac, librpc/src/xdr/xdr_float.c, score/cpu/Makefile.am: New
port to Altera NIOS II.
* ChangeLog, Makefile.am, cpu.c, cpu_asm.S, irq.c, preinstall.am,
rtems/asm.h: New files.
