* | 2007-06-21 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-06-21 | 2 | -15/+85 |
| | | | | | | * cpu.c: Merge patch from Till Straumann which would work except gcc core dumps with an ICE when may_alias is used in this code. I filed a GCC PR and reduced optimization to -O0 and it does run again. | ||||
* | 2007-06-21 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-06-21 | 2 | -19/+14 |
| | | | | | | * libnetworking/rtems/rtems_syscall.c: Remove RTEMS versions of send() and recv(). We already had the BSD versions and these conflict sometimes when linking. | ||||
* | 2007-06-21 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-06-21 | 4 | -0/+29 |
| | | | | | * libnetworking/rtems/mkrootfs.h, libnetworking/rtems/rtems_bsdnet.h, libnetworking/rtems/rtems_bsdnet_internal.h: Add extern __cplusplus. | ||||
* | 2007-06-20 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-06-20 | 2 | -14/+23 |
| | | | | | * sapi/include/confdefs.h: Do not instantiate initialization thas/thread pointer tables for an API that is not configured. | ||||
* | 2007-06-20 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-06-20 | 3 | -1/+58 |
| | | | | | * libcsupport/Makefile.am: * libcsupport/src/open_dev_console.c: New file. | ||||
* | 2007-06-20 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2007-06-20 | 2 | -0/+7 |
| | | | | | * score/src/corerwlock.c: Make sure structure is fully initialized. When reused, some fields will not be zero like at initialization. | ||||
* | 2007-06-20 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2007-06-20 | 2 | -0/+10 |
| | | | | | * sapi/include/confdefs.h: POSIX threads use twice the minimum stack size. Account for this. | ||||
* | 2007-06-13 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-06-13 | 2 | -0/+10 |
| | | | | * configure.ac: Add NDEBUG as a command line compilation option. | ||||
* | 2007-06-12 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-06-12 | 2 | -0/+6 |
| | | | | * libmd/.cvsignore: New file. | ||||
* | 2007-06-12 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-06-12 | 3 | -0/+17 |
| | | | | | * shttpd/defs.h: Eliminate my_strncasecmp. * shttpd/string.c: Eliminate my_strncasecmp. | ||||
* | 2007-06-12 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-06-12 | 1 | -0/+1 |
| | | | | * wrapup/Makefile.am: Pickup ../libmd/libmd.a. | ||||
* | Pickup ../libmd/libmd.a. | Ralf Corsepius | 2007-06-12 | 1 | -1/+1 |
* | 2007-06-12 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-06-12 | 2 | -8/+2 |
| | | | | * pppd/Makefile.am: Reflect moving out md*. | ||||
* | Remove (moved to libmd) | Ralf Corsepius | 2007-06-12 | 4 | -725/+0 |
* | 2007-06-12 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-06-12 | 1 | -0/+2 |
| | | | | | * pppd/md4.h, pppd/md4.c, pppd/md5.c, pppd/md5.h: Remove (moved to libmd). | ||||
| | | | | | * libmd/Makefile.am, libmd/md4.c, libmd/md4.h, libmd/md5.c, libmd/md5.h, libmd/preinstall.am: New (moved out from pppd). | ||||
* | New (moved out from pppd). | Ralf Corsepius | 2007-06-12 | 6 | -0/+747 |
* | Regenerate. | Ralf Corsepius | 2007-06-12 | 1 | -1/+0 |
* | 2007-06-12 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-06-12 | 3 | -0/+6 |
| | | | | * configure.ac, Makefile.am: Add libmd. | ||||
* | 2007-06-12 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-06-12 | 1 | -0/+5 |
| | | | | | * shttpd/defs.h: Eliminate my_strlcpy. * shttpd/string.c: Eliminate my_strlcpy. | ||||
* | Eliminate my_strlcpy. | Ralf Corsepius | 2007-06-12 | 2 | -0/+9 |
| | | | | | * shttpd/defs.h: Eliminate my_strdup, my_strndup. * shttpd/string.c: Eliminate my_strdup, my_strndup. | ||||
* | Eliminate my_strdup, my_strndup. | Ralf Corsepius | 2007-06-12 | 2 | -0/+15 |
* | 2007-06-12 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-06-12 | 2 | -1/+6 |
| | | | | | * shttpd/Makefile.am: Add -DHAVE_MD5 to use md5 routines from libmd.a. | ||||
* | 2007-06-12 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-06-12 | 2 | -0/+8 |
| | | | | * wrapup/Makefile.am: Add libmd.a. | ||||
* | 2007-06-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-06-12 | 1 | -0/+6 |
| | | | | | | * pppd/Makefile.am: Remove md5 and md4 from libpppd.a. Add pppd/libmd.a. * pppd/md4.c: Don't include pppd.h. | ||||
* | Remove md5 and md4 from libpppd.a. | Ralf Corsepius | 2007-06-12 | 1 | -1/+8 |
| | | | | Add pppd/libmd.a. | ||||
* | Don't include pppd.h. | Ralf Corsepius | 2007-06-12 | 1 | -1/+0 |
* | 2007-06-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-06-11 | 1 | -0/+4 |
| | | | | * shttpd/shttpd.ico, shttpd/resources.rc: Remove (Unused). | ||||
* | Remove. | Ralf Corsepius | 2007-06-11 | 2 | -1/+0 |
* | Regenerate. | Ralf Corsepius | 2007-06-11 | 1 | -1/+1 |
* | 2007-06-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-06-11 | 2 | -1/+2 |
| | | | | * shttpd/Makefile.am: Conditionally build on LIBNETWORKING. | ||||
* | 2007-06-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-06-11 | 2 | -0/+10 |
| | | | | | * shttpd/compat_rtems.h: Include <arpa/inet.h>. Add config.h support. | ||||
* | 2007-06-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-06-11 | 2 | -0/+5 |
| | | | | * shttpd/compat_rtems.h: Define closesocket. | ||||
* | New. | Ralf Corsepius | 2007-06-11 | 1 | -0/+2 |
* | 2007-06-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-06-11 | 2 | -0/+9 |
| | | | | * shttpd/compat_rtems.h: Add IS_DIRSEP_CHAR. | ||||
* | Use size_t for stack sizes. | Ralf Corsepius | 2007-06-11 | 2 | -2/+2 |
* | New. | Ralf Corsepius | 2007-06-11 | 1 | -0/+39 |
* | 2007-06-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-06-11 | 1 | -0/+2 |
| | | | | | * configure.ac, Makefile.am: Add shttpd. * shttpd/Makefile.am: New. | ||||
* | 2007-06-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-06-11 | 1 | -0/+31 |
* | Add shttpd. | Ralf Corsepius | 2007-06-11 | 2 | -0/+3 |
* | Remove (Renamed to Makefile.shttpd) | Ralf Corsepius | 2007-06-11 | 1 | -50/+0 |
* | Rename shttpd's Makefile | Ralf Corsepius | 2007-06-11 | 1 | -0/+50 |
* | 2007-06-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-06-11 | 1 | -0/+14 |
| | | | | | | | | | | | | | | * shttpd/auth.c, shttpd/cgi.c, shttpd/compat_rtems.c, shttpd/compat_rtems.h, shttpd/compat_unix.c, shttpd/compat_unix.h, shttpd/compat_win32.c, shttpd/compat_win32.h, shttpd/compat_wince.c, shttpd/compat_wince.h, shttpd/config.c, shttpd/defs.h, shttpd/io_cgi.c, shttpd/io_dir.c, shttpd/io_emb.c, shttpd/io_file.c, shttpd/io.h, shttpd/io_socket.c, shttpd/io_ssl.c, shttpd/llist.h, shttpd/log.c, shttpd/Makefile, shttpd/md5.c, shttpd/md5.h, shttpd/mime_type.c, shttpd/resources.rc, shttpd/shttpd.1, shttpd/shttpd.c, shttpd/shttpd.h, shttpd/shttpd.ico, shttpd/ssl.h, shttpd/standalone.c, shttpd/std_includes.h, shttpd/string.c: Import from shttpd-1.37.tar.gz. | ||||
* | This commit was generated by cvs2svn to compensate for changes in r15510, | Ralf Corsepius | 2007-06-11 | 34 | -0/+7814 |
|\ | | | | | which included commits to RCS files with non-trunk default branches. | ||||
| * | Import from shttpd-1.37. | Ralf Corsepius | 2007-06-11 | 34 | -0/+7814 |
* | 2007-06-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-06-11 | 2 | -3/+4 |
| | | | | * configure.ac: Remove "pad" from CPU_CONTEXT. | ||||
* | 2007-06-05 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-06-05 | 2 | -2/+6 |
| | | | | * score/src/coremsg.c: Formatting. | ||||
* | 2007-05-31 Alain Schaefer <alani@easc.ch> | Joel Sherrill | 2007-05-31 | 2 | -5/+12 |
| | | | | | | | * rtems/score/cpu.h: Modifiy inline assembly language constraints to use a data register as the CTL/STI instructions requires. This is not only more correct, it avoids GCC PR31787. | ||||
* | 2007-05-29 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-05-29 | 2 | -1/+5 |
| | | | | * score/include/rtems/score/copyrt.h: Update copyright notice. |
