path: root/cpukit (follow)
* 2001-03-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-04-022-9/+14
| | | | | * Per PR126, configuration structures now match docs. * include/rtems/rtems/config.h: Use public data types.
* 2002-03-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-012-9/+13
| | | | * libc/rcmd.c: Replace __rtems w/ __rtems__.
* 2001-03-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-03-296-77/+73
| | | | | | | | | | | * Per PR147 addressed problems when reseting and inserting a timer into a timer chain that did not honor time passage since the last time the timer server was scheduled and the new insertion. * include/rtems/rtems/timer.h, src/timerreset.c, src/timerserver.c, src/timerserverfireafter.c, src/timerserverfirewhen.c: Broke up the "reset server" routine into a set of very specific routines that allowed the server to be unscheduled, timer chains to be "synchronized" with the current time before inserting a new timer.
* 2002-03-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-292-32/+10
| | | | | | | | * cpu.c: Replace NO_TABLE_MOVE-support by external function (code moved to libcpu/sparc/tbr/tbr.c). * cpu.h: Replace NO_TABLE_MOVE-support by external function (code moved to libcpu/sparc/tbr/tbr.h). * sparc.h: Add sparc_init_tbr (implemented in libcpu/sparc/tbr/tbr.c).
* 2001-03-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-03-282-6/+29
| | | | | | | * PR132 requested some tinkering ot lower memory. * include/confdefs.h: Lowered footprint of device driver table and statically configure user extensions. Now if no static extensions are configured, then the table is not instantiated.
* 2001-03-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-03-282-0/+7
| | | | * cpu.c: Define fix_syscall_errno() to nothing so MP links.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-283-4/+9
| | | | | | * src/dosfs/fat_file.c: Remove bsp.h. fat_file_write(.. const char*buf ..). * src/dosfs/fat_file.h: fat_file_write(.. const char*buf ..).
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-2851-51/+153
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-284-4/+11
| | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * src/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-2810-10/+16
| | | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * include/rpc/Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * include/rpcsvc/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * src/rpc/PSD.doc/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/rpc/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/xdr/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-2819-19/+25
| | | | | | | | | | | | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * arpa/Makefile.am: Remove AUTOMAKE_OPTIONS. * kern/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * lib/Makefile.am: Remove AUTOMAKE_OPTIONS. * libc/Makefile.am: Remove AUTOMAKE_OPTIONS. * machine/Makefile.am: Remove AUTOMAKE_OPTIONS. * net/Makefile.am: Remove AUTOMAKE_OPTIONS. * netinet/Makefile.am: Remove AUTOMAKE_OPTIONS. * nfs/Makefile.am: Remove AUTOMAKE_OPTIONS. * pppd/Makefile.am: Remove AUTOMAKE_OPTIONS. * rtems/Makefile.am: Remove AUTOMAKE_OPTIONS. * rtems_servers/Makefile.am: Remove AUTOMAKE_OPTIONS. * rtems_telnetd/Makefile.am: Remove AUTOMAKE_OPTIONS. * rtems_webserver/Makefile.am: Remove AUTOMAKE_OPTIONS. * sys/Makefile.am: Remove AUTOMAKE_OPTIONS. * vm/Makefile.am: Remove AUTOMAKE_OPTIONS. * wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-2814-14/+21
| | | | | | | | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. * cpuuse/Makefile.am: Remove AUTOMAKE_OPTIONS. * devnull/Makefile.am: Remove AUTOMAKE_OPTIONS. * dummy/Makefile.am: Remove AUTOMAKE_OPTIONS. * dumpbuf/Makefile.am: Remove AUTOMAKE_OPTIONS. * monitor/Makefile.am: Remove AUTOMAKE_OPTIONS. * mw-fb/Makefile.am: Remove AUTOMAKE_OPTIONS. * rootfs/Makefile.am: Remove AUTOMAKE_OPTIONS. * rtmonuse/Makefile.am: Remove AUTOMAKE_OPTIONS. * shell/Makefile.am: Remove AUTOMAKE_OPTIONS. * stackchk/Makefile.am: Remove AUTOMAKE_OPTIONS. * untar/Makefile.am: Remove AUTOMAKE_OPTIONS. * wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-287-7/+13
| | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * src/dosfs/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/imfs/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-282-3/+2
| | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * libc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-285-5/+11
| | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-287-6/+9
| | | | | | | | | * cpu/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * inline/Makefile.am: Remove AUTOMAKE_OPTIONS. * macros/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-2812-10/+16
| | | | | | | | * Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * inline/Makefile.am: Remove AUTOMAKE_OPTIONS. * macros/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/Makefile.am: Remove AUTOMAKE_OPTIONS.
| | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * src/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * inline/Makefile.am: Remove AUTOMAKE_OPTIONS. * macros/Makefile.am: Remove AUTOMAKE_OPTIONS.
| | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * inline/Makefile.am: Remove AUTOMAKE_OPTIONS. * macros/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2002-03-27 Thomas.Doerfler@imd-systems.deJoel Sherrill2002-03-272-9/+46
| | | | | | | * PR144 * nfs/bootp_subr.c bootpc_init(): Performs a write to memory address 0 when called for the first time. This is done when trying to clear the variable "dhcp_hostname".
* 2002-03-27 Ilya Alexeev <ilya@continuum.ru>Joel Sherrill2002-03-274-13/+26
| | | | | | | | | | | | | * PR162 * net/if_ppp.c ppp_txdaemon(), net/if_pppvar.h pppstart(): Local variables must not be used in a device write routines. Now ppp_softc structure have own character for writing to device (sc_outchar). I think that converting local variables to static is not a right solution, because problems will occur in the case of two or more ppp instances. * net/ppp_tty.c pppstart(): Type of the ioffset variable must be u_long, otherwise in the case of the big output packet endless loop may occur.
* 2001-03-21 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-03-211-5/+0
| | | | * ChangeLog: Undo incorrect addition of entry.
* 2002-03-21 Ilya Alexeev <ilya@continuum.ru>Joel Sherrill2002-03-214-16/+48
| | | | | * net/if_ppp.c, net/ppp_tty.c: Initial preparations for multiple PPPD connections.
* 2002-03-21 Alexander Kukuta <kam@oktet.ru>Joel Sherrill2002-03-213-610/+389
| | | | | | | * src/bdbuf.c (avl_insert, avl_remove): Reimplemented from scratch to avoid using GPLed sources in RTEMS core. * src/bdbuf.c, include/rtems/bdbuf.h: Remove "binary tree" implementation which was used for debugging only.
* 2001-03-20 Till Straumann <strauman@SLAC.Stanford.EDU>Joel Sherrill2002-03-203-2/+35
| | | | | | | | | * PR158 * libc/rcmd.c, libc/rcmd.c: Enable the rcmd() library call by commenting out the parts that deal with signals. This enables RTEMS to 'rsh' command to a server connecting fd to remote stdio. The 'server-side' parts of this file which deal with authentication are disabled since they are not needed.
* 2002-03-20 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill2002-03-202-0/+11
| | | | * cpu_asm.S: Now compiles on 4600 and 4650.
* 2001-03-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-03-201-1/+1
| | | | | | * PR143 * lib/include/rtems/termiostypes.h: Removed unneeded volatile on "theBuf" since no byte is read more than once anyway.
* 2002-03-20 Chris Johns <ccj@acm.org>Joel Sherrill2002-03-202-0/+10
| | | | | * PR148. * monitor/mon-prmisc.c: Fixed to print task states correctly.
* 2002-03-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-205-5/+20
| | | | | | | | | | | | | Addressing PR 140. * src/dosfs/config.h.in: Removed. * src/dosfs/stamp-h2.in: Removed. * .cvsignore: Add config.h*, stamp-h*. * configure.ac: Remove AC_SRC_DIR(.../dosfs.h). Remove AM_CONFIG_HEADER(src/dosfs/config.h). Remove AM_CONFIG_HEADER(src/imfs/config.h). Add AM_CONFIG_HEADER(config.h). * src/dosfs/Makefile.am: INCLUDES = -I../.. . * src/imfs/Makefile.am: INCLUDES = -I../.. .
* 2002-03-13 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill2002-03-153-24/+42
| | | | | | * cpu_asm.S: Fixed a sneaky return from int w/ ints disabled bug. * rtems/score/cpu.h: Fixed register numbering in comments and made interrupt enable/disable more robust.
* 2002-03-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-153-40/+24
| | | | | | Reported and tracked as PR130. * src/dosfs/Makefile.am: Reworked, Disable dosfs for UNIX. * wrapup/Makefile.am: Disable dosfs for UNIX.
* 2001-03-15 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-03-156-120/+186
| | | | | | | * src/extension.c: Split to reduce minimum code size per PR134. * src/extensioncreate.c, src/extensiondelete.c, src/extensionident.c: New files. src/Makefile.am: Modified to reflect above.
* 2002-03-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-152-1/+5
| | | | * rtems/score/m68k.h: m68k_swap_u32 fix typo.
* 2002-03-05 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill2002-03-087-50/+296
| | | | | | | | | | | | * cpu_asm.S: Added support for the debug exception vector, cleaned up the exception processing & exception return stuff. Re-added EPC in the task context structure so the gdb stub will know where a thread is executing. Should've left it there in the first place... * idtcpu.h: Added support for the debug exception vector. * cpu.c: Added ___exceptionTaskStack to hold a pointer to the stack frame in an interrupt so context switch code can get the userspace EPC when scheduling. * rtems/score/cpu.h: Re-added EPC to the task context.
* 2002-03-06 Victor V. Vengerov <vvv@oktet.ru>Joel Sherrill2002-03-062-0/+39
| | | | | | * rtems/score/m68k.h [M68K_COLDFIRE_ARCH] (CPU_swap_u16, CPU_swap_u32): Generic implementation of endian swap primitives added for Coldfire family.
* 2002-03-01 Eric Norum <eric.norum@usask.ca>Joel Sherrill2002-03-012-7/+15
| | | | | | * src/pthreadonce.c: Task is not preemptable while running a pthread_once init function. This is slightly less heavy handed than disabling dispatching and seems better than consuming a mutex.
* 2002-03-01 Eric Norum <eric.norum@usask.ca>Joel Sherrill2002-03-011-10/+9
| | | | | | * libc/gxx_wrappers.c: Task is not preemptable while running a pthread_once init function. This is slightly less heavy handed than disabling dispatching and seems better than consuming a mutex.
* 2002-02-27 Greg Menke <gregory.menke@gsfc.nasa.gov>Joel Sherrill2002-03-018-142/+307
| | | | | | | | | | | | | | | | * cpu_asm.S: Fixed exception return address, modified FP context switch so FPU is properly enabled and also doesn't screw up the exception FP handling. * idtcpu.h: Added C0_TAR, the MIPS target address register used for returning from exceptions. * iregdef.h: Added R_TAR to the stack frame so the target address can be saved on a per-exception basis. The new entry is past the end of the frame gdb cares about, so doesn't affect gdb or cpu.h stuff. * rtems/score/cpu.h: added an #ifdef so cpu_asm.S can include it to obtain FPU defines without systax errors generated by the C defintions. * cpu.c: Improved interrupt level saves & restores.
* 2001-03-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-03-012-0/+5
| | | | * src/imfs/.cvsignore: Added stamp-h1.in
* 2002-02-28 Victor V. Vengerov <vvv@oktet.ru>Joel Sherrill2002-02-2827-2/+6664
| | | | | | | | | | | | | | | | | * DOS filesystem including FAT12, FAT16, and FAT32 support submitted. * src/dosfs, src/dosfs/Makefile.am, src/dosfs/stamp-h2.in, src/dosfs/config.h.in, src/dosfs/dosfs.h, src/dosfs/fat.c, src/dosfs/fat.h, src/dosfs/fat_fat_operations.c, src/dosfs/fat_fat_operations.h, src/dosfs/fat_file.c, src/dosfs/fat_file.h, src/dosfs/msdos.h, src/dosfs/msdos_create.c, src/dosfs/msdos_dir.c, src/dosfs/msdos_eval.c, src/dosfs/msdos_file.c, src/dosfs/msdos_free.c, src/dosfs/msdos_fsunmount.c, src/dosfs/msdos_handlers_dir.c, src/dosfs/msdos_handlers_file.c, src/dosfs/msdos_init.c, src/dosfs/msdos_initsupp.c, src/dosfs/msdos_misc.c, src/dosfs/msdos_mknod.c, src/dosfs/msdos_node_type.c, src/dosfs/.cvsignore: New files. * configure.ac, src/Makefile.am, wrapup/Makefile.am: Modified to reflect addition.
* 2002-02-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-2817-0/+3798
| | | | | | | | | | * Submitted by Victor V. Vengerov <vvv@oktet.ru> and merged into the RTEMS source. * ChangeLog, Makefile.am, README, configure.ac, include/Makefile.am, include/rtems/bdbuf.h, include/rtems/blkdev.h, include/rtems/diskdevs.h, include/rtems/ramdisk.h, include/rtems/.cvsignore, include/.cvsignore, src/Makefile.am, src/bdbuf.c, src/blkdev.c, src/diskdevs.c, src/ramdisk.c, src/.cvsignore, .cvsignore: New files.
* 2002-02-27 Ilya Alexeev <ilya@continuum.ru>Joel Sherrill2002-02-276-10/+47
| | | | | | * net/if_ppp.c, pppd/auth.c, pppd/chat.c, pppd/pppd.h, pppd/sys-rtems.c: Add server with pap-authorization capabilities as well as eliminate some warnings.
* 2002-02-27 Eric Norum <eric.norum@usask.ca>Joel Sherrill2002-02-272-1/+10
| | | | | | * net/radix.c: Properly handle fetching the default route when there is no route. This was a bug in the original FreeBSD code and this fix is from an updated version of their code.
* 2001-02-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-272-1/+5
| | | | * rtems/score/cpu.h: Fix conditional to match current GCC.
* 2002-02-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-02-132-8/+4
| | | | * configure.ac: Fix the test to determine cpu context size.
* 2002-02-08 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-084-205/+216
| | | | | * iregdef.h, rtems/score/cpu.h: Reordered register in the exception stack frame to better match gdb's expectations.
* 2001-02-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-055-16/+230
| | | | | | | | | * cpu_asm.S: Enhanced to save/restore more registers on exceptions. * rtems/score/cpu.h (CPU_Interrupt_frame): Enhanced to list every register individually and document when it is saved. * idtcpu.h: Added constants for the coprocessor 1 registers revision and status.
* 2001-02-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-052-0/+5
| | | | * .cvsignore: Added stamp-h.in.
* 2001-02-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-054-0/+16
| | | | * rtems/Makefile.am, rtems/score/Makefile.am: Removed again.
* 2001-02-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-042-1/+6
| | | | | * rtems/score/cpu.h: IDLE task should not be FP. This was a mistake in the previous patch that has now been confirmed.
