* | 2010-03-22 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-03-18 | 1 | -8/+6 |
| | | | | | | | | | | * ChangeLog.zlib, FAQ, Makefile.am, README, adler32.c, compress.c, crc32.c, deflate.c, deflate.h, infback.c, inffast.c, inflate.c, inflate.h, inftrees.c, inftrees.h, trees.c, uncompr.c, zconf.h, zlib.3, zlib.h, zutil.c, zutil.h: Update to zlib 1.2.4. * gzclose.c, gzguts.h, gzlib.c, gzread.c, gzwrite.c, doc/algorithm.txt: New files. * algorithm.txt, gzio.c: Removed. | ||||
* | Stop using old-style function definitions. | Ralf Corsepius | 2008-09-02 | 1 | -5/+5 |
* | Upgrade to zlib-1.2.3. | Ralf Corsepius | 2008-09-01 | 1 | -1/+1 |
* | Reformat CVS Ids | Ralf Corsepius | 2005-10-28 | 1 | -1/+1 |
* | Import of zlib-1.2.2.2.tar.gz | Ralf Corsepius | 2005-10-28 | 1 | -0/+61 |
