* | 2007-09-06 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2007-09-06 | 1 | -35/+32 |
| | | | | * shttpd/compat_rtems.c: Style clean up. | ||||
* | changes | Ralf Corsepius | 2007-07-30 | 1 | -6/+4 |
* | 2007-07-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-07-30 | 1 | -0/+30 |
| | | | | | | * shttpd/log.c: Add preliminary version of SPLIT_SNPRINTF to work-around bug m68k/coldfire -fomit-frame-pointer bug http://gcc.gnu.org/bugzilla/show_bug.cgi?id=32307. | ||||
* | Don't build most of my_* wrappers for rtems. | Ralf Corsepius | 2007-07-24 | 1 | -0/+9 |
* | Don't build my_stat for rtems. | Ralf Corsepius | 2007-07-24 | 1 | -2/+2 |
* | Prefix all non-public symbols with _shttp_. | Ralf Corsepius | 2007-07-24 | 1 | -0/+37 |
* | 2007-07-12 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2007-07-12 | 2 | -5/+9 |
| | | | | | * shttpd/compat_rtems.c, shttpd/compat_rtems.h: Add port to listen on to shttpd initialization. | ||||
* | 2007-06-12 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-06-12 | 2 | -0/+12 |
| | | | | | * shttpd/defs.h: Eliminate my_strncasecmp. * shttpd/string.c: Eliminate my_strncasecmp. | ||||
* | Eliminate my_strlcpy. | Ralf Corsepius | 2007-06-12 | 2 | -0/+9 |
* | Eliminate my_strdup, my_strndup. | Ralf Corsepius | 2007-06-12 | 2 | -0/+15 |
* | 2007-06-12 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-06-12 | 1 | -1/+1 |
| | | | | | * shttpd/Makefile.am: Add -DHAVE_MD5 to use md5 routines from libmd.a. | ||||
* | Remove. | Ralf Corsepius | 2007-06-11 | 2 | -1/+0 |
* | Regenerate. | Ralf Corsepius | 2007-06-11 | 1 | -1/+1 |
* | 2007-06-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-06-11 | 1 | -1/+1 |
| | | | | * shttpd/Makefile.am: Conditionally build on LIBNETWORKING. | ||||
* | 2007-06-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-06-11 | 1 | -0/+5 |
| | | | | | * shttpd/compat_rtems.h: Include <arpa/inet.h>. Add config.h support. | ||||
* | 2007-06-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-06-11 | 1 | -0/+1 |
| | | | | * shttpd/compat_rtems.h: Define closesocket. | ||||
* | New. | Ralf Corsepius | 2007-06-11 | 1 | -0/+2 |
| | | | | * shttpd/compat_rtems.h: Add IS_DIRSEP_CHAR. | ||||
* | Use size_t for stack sizes. | Ralf Corsepius | 2007-06-11 | 2 | -2/+2 |
* | New. | Ralf Corsepius | 2007-06-11 | 1 | -0/+39 |
* | 2007-06-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-06-11 | 1 | -0/+31 |
| | | | | * shttpd/Makefile.am: New. | ||||
* | Remove (Renamed to Makefile.shttpd) | Ralf Corsepius | 2007-06-11 | 1 | -50/+0 |
* | Rename shttpd's Makefile | Ralf Corsepius | 2007-06-11 | 1 | -0/+50 |
* | Import from shttpd-1.37. | Ralf Corsepius | 2007-06-11 | 34 | -0/+7814 |
