PR 430/rtems
* include/rtems/score/watchdog.h: _Watchdog_Ticks_since_boot should
be a VOLATILE variable.
* src/watchdoginsert.c: 'restart' algorithm needs to enforce
reloading the list head in case a TICK interrupt during ISR_Flash()
modified the list. This is achieved by a proper VOLATILE cast.
Also _Watchdog_Sync_count++ should be protected by _ISR_Disable
(prevent corruption in case ISR calls watchdoginsert)
* src/watchdogadjust.c: ISR protection added.
* src/watchdogtickle.c: ISR protection added.
NOTE: PowerPC BSPs using the new exception processing MUST BE UPDATED
to maintain _ISR_Nest_level. See also PR288 which provides fixes
for the affected BSPs distributed with RTEMS.
* cpu/Makefile.am: Add DIST_SUBDIRS = $(RTEMS_CPU).
PR 417/rtems
* src/coresemsurrender.c: Correct incorrect check for maximum_count
reported by Sergei Organov <osv@topconrd.ru>.
* src/threadloadenv.c: Removed warnings.
* src/objectmp.c: Removed warnings.
PR 356/bsps
* src/threadhandlerc: This patch makes RTEMS/PowerPC eabi compliant.
Let Thread_Handler verify that _init/_main are non-NULL
before calling them (gives the linker script/user more
freedom to handle special cases).
PR 349/bsps
* rtems/powerpc/registers.h: Add definitions for HID1 and DABR SPRs.
AMD a29k declared obsolete.
* cpu/Makefile.am: Removed reference.
* cpu/a29k/.cvsignore, cpu/a29k/ChangeLog, cpu/a29k/Makefile.am,
cpu/a29k/amd.ah, cpu/a29k/asm.h, cpu/a29k/configure.ac,
cpu/a29k/cpu.c, cpu/a29k/cpu_asm.S, cpu/a29k/pswmacro.ah,
cpu/a29k/register.ah, cpu/a29k/sig.S, cpu/a29k/rtems/.cvsignore,
cpu/a29k/rtems/score/.cvsignore, cpu/a29k/rtems/score/a29k.h,
cpu/a29k/rtems/score/cpu.h, cpu/a29k/rtems/score/cpu_asm.h,
cpu/a29k/rtems/score/types.h: Removed.
PR 347/rtems
* rtems/powerpc/registers.h (PPC_Set_decrementer): Correct inline
assembly so it correctly generates on newer gcc's.
* cpu_asm.c: Rework logic that decides when to call
_Thread_Dispatch. Analysis by Sergei Organov <osv@javad.ru>
determined that _ISR_Signals_to_thread_executing was not being
honored and/or cleared properly.
* irq.c: Rework logic that decides when to call
* m68360.h: Correct the order of fields in the ethernet structure
to account for the typo in MC68360UM (page 7-248).
* src/objectmp.c: Corrected use of name parameter to reflect that it
is actually the name not a pointer to the name.
* rtems/score/cpu.h: Per PR315, eliminate warning for structure
alignment requests that are too large.
Makefile.am: Don't create $ARCH.
* configure.ac: Require autoconf-2.57 + automake-1.7.2.
* Makefile.am: Eliminate C_O_FILES, S_O_FILES, libscorecpu_a_OBJECTS.
Makefile.am: Fix macro-file installation.
Makefile.am: Move include/rtems/score/cpuopts.h to STD_H_FILES.
* inline/Makefile.am: Remove.
* macros/Makefile.am: Remove.
* src/Makefile.am: Remove.
* Makefile.am: Merge-in removed Makefile.ams.
* include/rtems/score/object.h, include/rtems/score/tod.h:
Added casts to eliminate warnings on 16 bit targets like the h8300.
* configure.ac: Fix package name.
* macros/rtems/score/object.inl: Keep consistent with inline version.
* configure.ac: Generate unixsize.h on the fly, filter out
autoconf-2.53 PACKAGE crap.
* rtems/score/.cvsignore: unixsize*
* rtems/score/cpu.h: Add prototype of H8BD_Install_IRQ to eliminate
warning.
* rtems/new-exceptions/cpu.h: Remove sections on
CPU_INLINE_ENABLE_DISPATCH and CPU_UNROLL_ENQUEUE_PRIORITY.
* rtems/old-exceptions/cpu.h: Remove sections on
* rtems/score/cpu.h: Insert sections on
* idtcpu.h: Removed warning.
* cpu.c: Removed warning.
* idtcpu.h: Removed warnings.
* cpu.c: Removed warnings.
* rtems/score/cpu.h: Removed warning.
* src/heapgetinfo.c: Fixed comment.
* src/mpci.c: Removed warning.
* rtems/new-exceptions/cpu.h: Removed warnings.
* src/threadhandler.c: Prototype _init() and _main() if they are needed
to avoid a warning.
* idtcpu.h: Removed warning by turning extra token at the end of
an endif into a comment.
* configure.ac: Add nostdinc to AM_INIT_AUTOMAKE.
* rtems/score/sh.h: Fix typo in comment (Starus->Status).
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* rtems/score/cpu.h: Fix u16 and u32 swap routines.
* rtems/score/cpu.h (_CPU_Initialize_vectors) Define to NULL
since it is not used.
* score/include/Makefile.am: Remove cpuopt.h generation.
* configure.ac: Correct package name.
Don't build ada if POSIX is disabled.
Generate cpuopt.h on the fly, filter out autoconf-2.53 PACKAGE crap.
* cpu_asm.S: More PR267 tinkering which eliminates some conditional
compilation.
* macros/rtems/score/coremsg.inl: Add <string.h> to remove warning.
* src/threadidlebody.c: Add return 0 to avoid warning.
* cpu_asm.S: Per PR267, the _ISR_Handler() function never was modifying
_ISR_Nest_level, and _Watchdog_Insert() requires this variable
to be modified to determine if an interrupt may have modified
the watchdog chain. Prior to modifying _ISR_Handler(), I had
a test that would fail if _ISR_Flash was not commented out in
_Watchdog_Insert(). After this modification was made, my test
ran flawlessly.
* cpu_asm.S: Clarified some comments, removed code that forced
SR_IEP on when returning from an interrupt.
