* src/objectextendinformation.c: Added include of string.h to
eliminate warning.
* cpu.c, rtems/score/cpu.h: Bug report from Peter Mueller
<peter.o.mueller@gmx.de> because of not correcting for the ISR
vector table now being allocated from the workspace.
* rtems/score/mips.h (mips_get_sr, mips_set_sr): Corrected
register constraints from "general" to "register".
* cpu_asm.S: Use SR_INTERRUPT_ENABLE_BITS instead of SR_XXX constants
to make it easier to conditionalize the code for various ISA levels.
* src/threadinitialize.c: Fix my bad hack of Ralf's fp_area
warning removal patch. :(
* src/threadinitialize.c: Removed warning.
* idtcpu.h: Commented out definition of "wait". It was stupid to
use such a common word as a macro.
* rtems/score/cpu.h (_CPU_ISR_Disable): Fixed for mips ISA 3.
* rtems/score/mips.h: Added include of <idtcpu.h>.
* rtems/score/mips.h (mips_enable_in_interrupt_mask): Corrected.
* cpu_asm.S: Modify to properly dereference _ISR_Vector_table
now that it is dynamically allocated.
* cpu_asm.S: Eliminated warning for duplicate definition of EXTERN.
* ChangeLog: Removed duplicate entry.
* src/isr.c: Allocate the _ISR_Vector_table all the time not just when
we are allocating an interrupt stack.
* cpu_asm.S (_ISR_Handler): Return to the address in the EPC register.
Previous code resulting in the interrupted immediately returning
to the caller of the routine it was inside.
* cpu.c (_CPU_Initialize): Do not initialize _ISR_Vector_table() here
because it has not been allocated yet.
* cpu.c: Do not read or write raw interrupt vector table if
we are on a CPU that does not have a %vbr register and the
BSP is configured as having the table in ROM.
* include/rtems/score/isr.h, src/isr.c: Allocate it from the
workspace rather than explicitly declaring it. This allows
the size to be a non-constant from the perspective of score/cpu.
* cpu.c: Removed duplicate declaration for _ISR_Vector_table.
* cpu_asm.S: Removed assembly language to vector ISR handler
on MIPS ISA I. Now call mips_vector_isr_handlers() in libcpu or BSP.
* rtems/score/cpu.h (CPU_INTERRUPT_NUMBER_OF_VECTORS): No
longer a constant -- get the real value from libcpu.
* cpu_asm.h: Removed.
* Makefile.am: Remove cpu_asm.h.
* rtems/score/mips64orion.h: Renamed mips.h.
* rtems/score/mips.h: New file, formerly mips64orion.h.
Header rewritten.
(mips_get_sr, mips_set_sr, mips_enable_in_interrupt_mask,
mips_disable_in_interrupt_mask): New macros.
* rtems/score/Makefile.am: Reflect renaming mips64orion.h.
* asm.h: Include <mips.h> not <mips64orion.h>. Now includes the
few defines that were in <cpu_asm.h>.
* cpu.c (_CPU_ISR_Get_level): Added MIPS ISA I version of this routine.
MIPS ISA 3 is still in assembly for now.
(_CPU_Thread_Idle_body): Rewrote in C.
* cpu_asm.S: Rewrote file header.
(FRAME,ENDFRAME) now in asm.h.
(_CPU_ISR_Get_level): Removed ISA I version and rewrote in C.
(_CPU_ISR_Set_level): Removed ISA I version and rewrote in C.
(_CPU_Context_switch): MIPS ISA I now manages preserves SR_IEC and
leaves other bits in SR alone on task switch.
(mips_enable_interrupts,mips_disable_interrupts,
mips_enable_global_interrupts,mips_disable_global_interrupts,
disable_int, enable_int): Removed.
(mips_get_sr): Rewritten as C macro.
(_CPU_Thread_Idle_body): Rewritten in C.
(init_exc_vecs): Rewritten in C as mips_install_isr_entries() and
placed in libcpu.
(exc_tlb_code, exc_xtlb_code, exc_cache_code, exc_norm_code): Moved
to libcpu/mips/shared/interrupts.
(general): Cleaned up comment blocks and #if 0 areas.
* idtcpu.h: Made ifdef report an error.
* iregdef.h: Removed warning.
* rtems/score/cpu.h (CPU_INTERRUPT_NUMBER_OF_VECTORS): Now a variable
number defined by libcpu.
(_CPU_ISR_Disable, _CPU_ISR_Enable): Rewritten to use new routines
to access SR.
(_CPU_ISR_Set_level): Rewritten as macro for ISA I.
(_CPU_Context_Initialize): Honor ISR level in task initialization.
(_CPU_Fatal_halt): Use new _CPU_ISR_Disable() macro.
* cpu.c: Added include of <rtems/rtems/cache.h> to eliminate warning.
* rtems/score/cpu.h: When mips ISA level is 1, registers in the
context should be 32 not 64 bits.
* macros/rtems/score/coresem.inl: Removed comments since convention
calls for comments to be in inline versin.
* macros/rtems/score/object.inl (Objects_Get_local_object): Fixed
style to use _ prefix on variable names and use parentheses.
* macros/rtems/score/object.inl (_Objects_Namespace_remove): Added.
* General effort to make things compile with macros not inlines
* inline/rtems/score/coremutex.inl: Added comment indicating
for macros there is another copy of
_CORE_mutex_Seize_interrupt_trylock() in src/coremutexseize.c.
* src/coremutexseize.c: Added body of
_CORE_mutex_Seize_interrupt_trylock() for macro case.
* macros/rtems/score/coremutex.inl: Added prototype for
_CORE_mutex_Seize_interrupt_trylock() since there is a real
body when macros are enabled.
* macros/rtems/score/coresem.inl: Added macro implementation of
_CORE_semaphore_Seize_isr_disable.
* macros/score/Makefile.am: Fixed typos.
* rtems/score/address.inl: Correct macro implementation of
_Addresses_Is_aligned() so it would compile.
* macros/rtems/score/coremsg.inl: Added closing parentheses.
* cpu_asm.S: Changed "_CPU_Ccontext_switch_restore: typo to
correct name of _CPU_Context_switch_restore. Added dummy
version of exc_utlb_code() so applications would link.
* src/heapallocate.c: Do not allow the size to overflow when
adjusting it. A test allocated a stack of -1 (~0). This
actually resulted in a stack being allocated but with a
size of 0xb. The allocator did not test the size to see if
it rolled through 0 and so allowed the allocation to happen, the
thread to get created. The task crashed as you would expect.
* cpu_asm.S: Fix for CPUs with FPU revision B or C.
* cpu.c, rtems/cpu/sparc.h: Make floating point optional based
on gcc arguments. Do not initialize FP context if there is
no FPU. Flush instruction cache after installing RTEMS trap handler.
* include/rtems/system.h: Use proper conditional (RTEMS_POSIX_API)
so prototypes for POSIX_MP_NOT_IMPLEMENTED(), POSIX_NOT_IMPLEMENTED(),
POSIX_BOTTOM_REACHED() are actually included.
* aclocal/canonicalize-tools.m4, aclocal/check-tool.m4,
aclocal/prog-cc.m4, aclocal/prog-cxx.m4: Replace AC_CHECK_TOOL
with an RTEMS specific but more restrictive autoconf macro.
Joel Sherrill <joel@OARcorp.com>
* This is a major reworking of the mips64orion port to use
gcc predefines as much as possible and a big push to multilib
the mips port. The mips64orion port was copied/renamed to mips
to be more like other GNU tools. Alan did most of the technical
work of determining how to map old macro names used by the mips64orion
port to standard compiler macro definitions. Joel did the merge
with CVS magic to keep individual file history and did the BSP
modifications. Details follow:
* Makefile.am: idtmon.h in mips64orion port not present.
* asm.h: MIPS64ORION replaced with MIPS. Frame setup macros added.
* cpu.c: Comments added.
* cpu_asm.S: Conditionals changed. MIPS ISA level 1 support added.
First attempt at exception/interrupt processing for ISA level 1
and minus any use of IDT/MON added.
* idtcpu.h: Conditionals changed to use gcc predefines.
* iregdef.h: Ditto.
* cpu_asm.h: No real change. Merger required commit.
* rtems/Makefile.am: Ditto.
* rtems/score/Makefile.am: Ditto.
* rtems/score/cpu.h: Change MIPS64ORION to MIPS.
* rtems/score/mips64orion.h: Change MIPS64ORION to MIPS. Convert
from using RTEMS_CPU_MODEL to gcc predefines to figre things out.
* shared/ppc.h: For multilibs, derive PPC_HAS_FPU from _SOFT_FLOAT.
* rtems/score/cpu.h: define CPU_Exception_frame for rdbg.
* m68302.h: Make buffer pointer in m302_SCC_bd volatile.
* src/heapgetinfo.c, include/rtems/score/heap.h, src/Makefile.am:
Added _Heap_Get_information() and information control block.
* src/heapgetinfo.c: New file.
* cpu_asm.S, rtems/score/cpu.h: Modified to better support
multilibing. These changes result in the code being able to
compile with the default gcc settings. It is not functional
in this configuration but does compile.
* rtems/score/c4x.h: Modified to properly multilib. This required
using only macros predefined by gcc.
* sim.h: These changes enable RTEMS to automatically generate
the ram_init file used by gdb with the BDM patches. The 332 has
on-board chip select lines (for RAM and FLASH) that must be
configured before use of these peripherals. These patches parse
data from start.c where the chip select lines are configured in
the runtime executable and automatically generates the gdb
initialization file using the same settings. A great time saver.
A similar file, ram_init_FW (flash writable), is also generated
that the flash programming tool uses.
* BSP/start/start.c: Must be modified to support above.
* BSP/start/ram_init.ld, BSP/start/ram_init.sed: New files.
* rtems/system.h: Switched a29k and hppa1.1 to using cpuopts.h not
targopts.h to reduce dependency on BSP.
* rtems/score/hppa.h: Switched to using cpuopts.h not
* rtems/score/a29k.h, rtems/score/cpu.h: Switched to using
cpuopts.h not targopts.h to reduce dependency on BSP.
* amd.ah, cpu.c, cpu_asm.S, register.ah, sig.S, rtems/score/cpu.h:
Updated and fixed minor things. Commented out offensive assembly
and made applications link.
* Makefile.am, cpu_asm.S, psmacro.ah, rtems/score/cpu.h:
First attempt to compile with GNU tools. Minor modifications
to compile enough to get to assembler errors.
* src/objectgetbyindex.c: Do not enable dispatching on an
error path it was not disabled on.
* rtems/score/i386.h: Corrected "#elsif" to be "#elif".
* Makefile.am: Use += to set up AM_CPPFLAGS.
