* score/include/rtems/score/chain.h:
Use uint32_t instead of unsigned32.
* score/src/chain.c: Remove superfluous type cast.
PR 733/rtems
* rtems/score/cpu.h: Remove output arg from inline asm in
_CPU_ISR_Disable.
* score/include/rtems/system.h: Don't define NULL, include
<stddef.h>.
* cpu_asm.S: Collected PR 601 changes for commit to cvshead
for rtems-4.7
* libcsupport/src/mallocfreespace.c, rtems/Makefile.am,
rtems/include/rtems/rtems/region.h, score/Makefile.am,
score/include/rtems/score/heap.h, score/src/heapgetinfo.c: Add
capability to return information about just the free blocks in a
region or heap. Also changed the semantics of free space available
to be the largest block of memory that can be allocated.
* rtems/src/regiongetfreeinfo.c, score/src/heapgetfreeinfo.c: New files.
: score/include/rtems/score/object.h,
score/src/objectinitializeinformation.c: Remove warning.
* score/include/rtems/score/object.h, score/src/objectclearname.c,
score/src/objectcopynamestring.c: Fixing warning led to making
changes to multiple prototypes for object support routines.
* rtems/old-exceptions/cpu.h: Make compile in assembly.
* rtems/score/types.h: Use __rtems_score_types_h as preprocessor
guard.
* asm.h: Add doxygen preamble.
* rtems/score/m68k.h: Use (defined(__mc68020__) && !defined(__mcpu32__))
instead of defined(__mc68020__) to reflect GCC-3.4's expectations.
* posix/src/mqueueunlink.c, posix/src/semunlink.c,
score/inline/rtems/score/object.inl,
score/macros/rtems/score/object.inl: _Objects_Is_local_id() should be
avoided in single CPU configurations but always available in the
Objects Handlers API.
* rtems/score/cpu.h: Add doxygen preamble.
* rtems/score/types.h: Add doxygen preamble.
* rtems/score/unix.h: Add doxygen preamble.
* rtems/score/sparc.h: Add doxygen preamble.
* rtems/score/sh.h: Add doxygen preamble.
* rtems/score/sh_io.h: Add doxygen preamble.
* rtems/score/powerpc.h: Add doxygen preamble.
* rtems/score/ppc.h: Add doxygen preamble.
* rtems/score/cpu_asm.h: Add doxygen preamble.
* rtems/score/or32.h: Add doxygen preamble.
* rtems/score/mips.h: Add doxygen preamble.
* rtems/score/m68k.h: Add doxygen preamble.
* rtems/score/i386.h: Add doxygen preamble.
* rtems/score/idtr.h: Add doxygen preamble.
* rtems/score/interrupts.h: Add doxygen preamble.
* rtems/score/registers.h: Add doxygen preamble.
* rtems/score/h8300.h: Add doxygen preamble.
* rtems/score/c4x.h: Add doxygen preamble.
* rtems/score/avr.h: Add doxygen preamble.
* rtems/score/arm.h: Add doxygen preamble.
* score/src/coresemsurrender.c, score/src/objectnametoid.c: All
_Objects_Is_Local... should only be called if multiprocessing is
enabled.
* score/include/rtems/score/object.h, score/src/object.c,
score/src/objectallocatebyindex.c, score/src/objectcomparenameraw.c,
score/src/objectinitializeinformation.c: Fix bugs in previous commit.
Now compiles.
* score/cpu/no_cpu/rtems/score/cpu.h, score/include/rtems/debug.h,
score/include/rtems/seterr.h, score/include/rtems/system.h,
score/include/rtems/score/address.h,
score/include/rtems/score/apiext.h,
score/include/rtems/score/apimutex.h,
score/include/rtems/score/bitfield.h,
score/include/rtems/score/chain.h,
score/include/rtems/score/context.h,
score/include/rtems/score/copyrt.h,
score/include/rtems/score/coresem.h,
score/include/rtems/score/heap.h, score/include/rtems/score/interr.h,
score/include/rtems/score/isr.h, score/include/rtems/score/mpci.h,
score/include/rtems/score/mppkt.h,
score/include/rtems/score/objectmp.h,
score/include/rtems/score/stack.h,
score/include/rtems/score/states.h,
score/include/rtems/score/sysstate.h,
score/include/rtems/score/threadmp.h,
score/include/rtems/score/threadq.h, score/include/rtems/score/tod.h,
score/include/rtems/score/tqdata.h,
score/include/rtems/score/userext.h,
score/include/rtems/score/watchdog.h,
score/include/rtems/score/wkspace.h,
score/inline/rtems/score/address.inl,
score/inline/rtems/score/chain.inl,
score/inline/rtems/score/coremsg.inl,
score/inline/rtems/score/coremutex.inl,
score/inline/rtems/score/coresem.inl,
score/inline/rtems/score/heap.inl, score/inline/rtems/score/isr.inl,
score/inline/rtems/score/mppkt.inl,
score/inline/rtems/score/objectmp.inl,
score/inline/rtems/score/priority.inl,
score/inline/rtems/score/stack.inl,
score/inline/rtems/score/states.inl,
score/inline/rtems/score/sysstate.inl,
score/inline/rtems/score/thread.inl,
score/inline/rtems/score/threadmp.inl,
score/inline/rtems/score/tod.inl,
score/inline/rtems/score/tqdata.inl,
score/inline/rtems/score/userext.inl,
score/inline/rtems/score/watchdog.inl,
score/inline/rtems/score/wkspace.inl: Add Doxygen comments -- working
modifications which are not complete and may have broken code.
Committing so work and testing can proceed.
* score/Doxyfile, score/mainpage.h: New files.
score/macros/rtems/score/object.inl: Add first cut of optional
16 bit object Id as space reduction for small systems (TinyRTEMS).
* rtems/score/types.h: s/no_cpu/avr/g.
Use POSIX types from rtems/stdint.h.
* score/src/coremsg.c: Eliminate unsigned32.
* score/include/rtems/system.h: Set __RTEMS_REVISION__ to 99.
* librpc/include/rpc/xdr.h: Use elipsis in xdrproc_t prototype.
* configure.ac, libmisc/cpuuse/README, libmisc/stackchk/README,
librpc/src/xdr/xdr_float.c, score/cpu/Makefile.am,
score/include/rtems/score/mppkt.h: i960 obsoleted and all references
removed.
* rtems/score/cpu.h: i960 obsoleted and all references removed.
* rtems/new-exceptions/cpu.h, rtems/old-exceptions/cpu.h: i960
* score/cpu/i960/.cvsignore, score/cpu/i960/ChangeLog,
score/cpu/i960/Makefile.am, score/cpu/i960/asm.h,
score/cpu/i960/cpu.c, score/cpu/i960/cpu_asm.S,
score/cpu/i960/rtems/score/cpu.h, score/cpu/i960/rtems/score/i960.h,
score/cpu/i960/rtems/score/types.h: Removed.
* configure.ac: Add score/cpu/avr/Makefile.am.
* score/cpu/Makefile.am: Add avr.
PR 671/bsps
* rtems/score/cpu.h: Fixed bug in _CPU_ISR_Set_level, where input param
was always ignored.
PR 609/rtems
* score/src/threaddispatch.c: Close race condition between
_Thread_Dispatch and _Thread_Tickle_timeslice.
PR 654/rtems
* score/src/threadinitialize.c: Initialize the per thread watchdog
timer. When the thread control block is reused, we cannot depend on
it being zeroed.
* cpu_asm.S: Remove use of C++ style comments and make this compile
again.
