* | Added FPSP support for MC68040 | Joel Sherrill | 1997-04-16 | 1 | -2/+19 |
* | added support for tracking thread cpu usage. | Joel Sherrill | 1997-04-09 | 1 | -0/+2 |
* | enhanced printf statements | Joel Sherrill | 1997-04-09 | 1 | -4/+4 |
* | corrected spacing. | Joel Sherrill | 1997-04-09 | 1 | -8/+8 |
* | added SYSTEM_STATE_SHUTDOWN | Joel Sherrill | 1997-04-09 | 1 | -0/+1 |
* | added initialization of variable to eliminate warning. | Joel Sherrill | 1997-04-07 | 1 | -1/+1 |
* | added "ifndef" to avoid redefinition warning. | Joel Sherrill | 1997-04-07 | 4 | -0/+8 |
* | added "return" to eliminate warning. | Joel Sherrill | 1997-04-07 | 1 | -0/+2 |
* | added "ifndef" to avoid redefinition warning | Joel Sherrill | 1997-04-07 | 8 | -0/+16 |
* | commented out sccs_id to eliminate warning. | Joel Sherrill | 1997-04-07 | 2 | -6/+12 |
* | Replaced warning message for cpus which do not have hardware support | Joel Sherrill | 1997-04-07 | 1 | -2/+3 |
| | | | | | for an interrupt stack. Hopefully this will encourage someone to implement software stack switching on the m68k. | ||||
* | changed signed int to unsigned to eliminate warning | Joel Sherrill | 1997-04-07 | 1 | -1/+1 |
* | added "ifndef" for ASM to avoid redefinition warnings. | Joel Sherrill | 1997-04-07 | 1 | -0/+2 |
* | This set of changes is the build of what was required to convert to | Joel Sherrill | 1997-04-01 | 1 | -2/+2 |
| | | | | | | | | | | | | | | | | | | | | GNU autoconf. This is the first large step in allowing an RTEMS user to perform a one-tree build (per crossgcc FAQ) including RTEMS in the build process. With this change RTEMS is configured in built in the same style as the GNU tools, yet retains the basic structure of its traditional Makefiles (ala Tony Bennett). Jiri Gaisler (jgais@wd.estec.esa.nl) deserves (and received) a big thank you for doing this. There are still issues to be resolved but as of this commit, all target which can be built on a linux host have been using a modified version of the source Jiri submitted. This source was merged and most targets built in the tree before this commit. There are some issues which remain to be resolved but they are primarily related to host OS dependencies, script issues, the use of gawk for hack_specs, and the dependence on gcc snapshots. These will be resolved. | ||||
* | modified _Chain_Insert_unprotected to have the form required to be used | Joel Sherrill | 1997-03-11 | 1 | -2/+2 |
| | | | | as the sole statement in an if or else statement | ||||
* | initialized a stack variable to avoid a warning. | Joel Sherrill | 1997-03-10 | 1 | -1/+1 |
* | Modified calls to _Thread_Change_priority to take a third argument. The new | Joel Sherrill | 1997-03-08 | 3 | -11/+41 |
| | | | | | | | | | argument indicates whether the task is to be placed at the head or tail of its priority fifo when it is lowering its own priority. POSIX normally follows the RTEMS API conventions but GNAT expects that all lowering of a task's priority by the task itself will result in being placed at the head of the priority FIFO. Normally, this would only occur as the result of lose of inherited priority. | ||||
* | Removed definitions which are now in targopts.h. This eliminates the | Joel Sherrill | 1997-01-29 | 1 | -8/+4 |
| | | | | | need for the "sed'ing" of this file. This should be a significant win when addressing non-unix host and non-gnu toolsets. | ||||
* | added type to macro to eliminate warning for untyped use of a register. | Joel Sherrill | 1997-01-29 | 1 | -1/+1 |
* | Added include of targopts.h. | Joel Sherrill | 1997-01-29 | 13 | -7/+20 |
* | fixed comments on vanilla 68000 SW interrupt stack (or the lack thereof) | Joel Sherrill | 1997-01-15 | 1 | -1/+2 |
* | added some casts to reduce warnings reported by users with Microtec C++ | Joel Sherrill | 1997-01-08 | 4 | -28/+35 |
| | | | | compiler. | ||||
* | added type definitions for all supported task entry formats | Joel Sherrill | 1997-01-08 | 1 | -1/+6 |
* | Changes to reflect new revision of erc32 per Jiri Gaisler's suggestions. | Joel Sherrill | 1996-12-02 | 3 | -0/+25 |
| | | | | This is current as of sis 2.6. | ||||
* | Updates from Derrick Ostertag <ostertag@transition.com> to fix bug in | Joel Sherrill | 1996-12-02 | 1 | -8/+15 |
| | | | | interrupt handling. | ||||
* | Update from Chris Johns <cjohns@awa.com.au> to add better support for | Joel Sherrill | 1996-12-02 | 1 | -3/+19 |
| | | | | 68000 class CPUs. | ||||
* | added support for cpu time used field in tcb | Joel Sherrill | 1996-10-15 | 1 | -0/+16 |
* | added cpu time used field to tcb | Joel Sherrill | 1996-10-15 | 1 | -0/+1 |
* | fixed incorrect placement of CPU_STRUCTURE_ALIGNMENT macro. | Joel Sherrill | 1996-09-30 | 1 | -2/+2 |
* | loop to clear workspace memory changed to use sizeof rather than | Joel Sherrill | 1996-09-18 | 1 | -1/+1 |
| | | | | hardcoded 4 to be compatible with CPUs with 64-bit ints | ||||
* | corrected prototype of _Objects_Get_next | Joel Sherrill | 1996-09-18 | 1 | -1/+1 |
* | uses address object rather than direct pointer arithmetic | Joel Sherrill | 1996-09-18 | 1 | -2/+3 |
* | OBJECTS_NAME_ALIGNMENT definition changed to use sizeof rather than | Joel Sherrill | 1996-09-18 | 1 | -2/+2 |
* | MP_PACKET_MINIMUN_HETERO_CONVERSION definition changed to use sizeof | Joel Sherrill | 1996-09-18 | 1 | -1/+2 |
| | | | | rather than hardcoded 4 to be compatible with CPUs with 64-bit ints | ||||
* | modified declaration of CORE_message_queue_Buffer_control to avoid use | Joel Sherrill | 1996-09-18 | 1 | -11/+4 |
| | | | | of GNU C extension | ||||
* | corrected white space problems | Joel Sherrill | 1996-09-18 | 1 | -60/+62 |
| | | | | added CPU_STRUCTURE_ALIGNMENT to default context structures | ||||
* | new files submitted by Craig Lebakken (lebakken@minn.net) and Derrick Ostertag | Joel Sherrill | 1996-09-18 | 4 | -0/+1327 |
| | | | | (ostertag@transition.com). | ||||
* | Reversed logic in conditional to correctly distinguish between | Joel Sherrill | 1996-09-17 | 1 | -2/+2 |
| | | | | FIFO and priority disciplines. | ||||
* | added $Id$ to file headers | Joel Sherrill | 1996-09-11 | 15 | -8/+15 |
| | | | | cpu.h: added prototype for _CPU_ISR_Get_level() | ||||
* | new file for MIPS port by Craig Lebakken (lebakken@minn.net) and | Joel Sherrill | 1996-09-06 | 15 | -0/+5247 |
| | | | | Derrick Ostertag (ostertag@transition.com). | ||||
* | changed _TOD_Is_set from a function to a boolean variable | Joel Sherrill | 1996-09-06 | 4 | -24/+11 |
* | updates from Tony Bennett (tbennett@divnc.com) | Joel Sherrill | 1996-08-15 | 1 | -2/+4 |
* | _Thread_Start_multitasking: added code to initialize the floating point | Joel Sherrill | 1996-08-15 | 1 | -1/+25 |
| | | | | context of the first thread to execute. | ||||
* | removed count from Thread_queue_Control | Mark Johannes | 1996-08-13 | 1 | -1/+0 |
* | removed Thread_queue_Get_number_waiting | Mark Johannes | 1996-08-13 | 2 | -25/+0 |
* | fixed spacing | Joel Sherrill | 1996-08-13 | 1 | -2/+2 |
* | CORE_mutex_Status: added CORE_MUTEX_STATUS_CEILING_VIOLATED to enum | Mark Johannes | 1996-08-08 | 1 | -1/+2 |
* | _MPCI_Register_packet_processor: Changed prototype of fist parameter name to ↵ | Mark Johannes | 1996-08-08 | 1 | -1/+1 |
| | | | | the_class | ||||
* | _MPCI_Register_packet_processor: changes first parameter type to ↵ | Mark Johannes | 1996-08-08 | 1 | -1/+1 |
| | | | | MP_packet_Classes | ||||
* | _CORE_Mutex_seize: added checks for priority ceiling violation, also added | Mark Johannes | 1996-08-07 | 1 | -6/+24 |
| | | | | checks to ensure priority was not lowered. |
