The APIC timer is calibrated by running the i8254 PIT for a fraction of a
second (determined by PIT_CALIBRATE_DIVIDER) and counting how many times the
APIC counter has ticked. The calibration can be run multiple times (determined
by APIC_TIMER_NUM_CALIBRATIONS) and averaged out.
Updates #2898.
Updates #2898.
Updates #2898.
Updates #2898.
Use the CPU_SIZEOF_POINTER alignment instead. The internal alignment
requirement is defined by the use of Chain_Node (consisting of two
pointers) to manage the free chain of partitions.
It seems that previously the condition
CPU_PARTITION_ALIGNMENT >= sizeof(Chain_Node)
was true on all CPU ports. Now, we need an additional check.
Update #3482.
Update #3433.
Update #3433.
The CLINT and PLIC need some per-processor state.
Update #3433.
Update #3433.
Remove _CPU_ISR_install_raw_handler() and _CPU_ISR_install_vector()
functions. Applications can install an exception handler via the fatal
error handler to handle synchronous exceptions.
Handle interrupt exceptions via _RISCV_Interrupt_dispatch() which must
be provided by the BSP.
Update #3433.
Use the CPU_Interrupt_frame for the volatile context. Add non-volatile
registers and extra state on top of it.
Update #3433.
Update #3433.
Add RTEMS_PREDICT_TRUE() and RTEMS_PREDICT_FALSE() for static branch
prediction hints.
Close #3475.
Pass current processor control as first parameter to make dependency
more explicit.
Apparently the .word assembler directive is not the right thing on this
target.
On some architectures/simulators it is difficult to provoke an
exception with misaligned or illegal data loads. Use an illegal
instruction instead.
Update #3433.
This helps to reduce the use of architecture-specific defines throughout
the code base.
The context validation support functions _CPU_Context_validate() and
_CPU_Context_volatile_clobber() are used only by one test program
(spcontext01). Move the function declarations to the CPU port
implementation header file.
This change was added to the FreeBSD version of this function.
This was spotted by Coverity Scan.
Commit 8744498752ad4f0eaf9fb5640c6a0e0f2dc92fda broke the
_Scheduler_EDF_SMP_Set_affinity() implementation. We must test the
overall affinity against the online processors.
Update #3465.
This addition allows us to successfully run the sample hello.exe test.
Updates #2898.
Current state:
- Basic context initialization and switching code.
- Stubbed console (empty functions).
- Mostly functional linker script (may need tweaks if we ever want to move
away from the large code model (see: CPU_CFLAGS).
- Fully functional boot, by using FreeBSD's bootloader to load RTEMS's ELF for
UEFI-awareness.
In short, the current state with this commit lets us boot, go through the system
initialization functions, and then call user application's Init task too.
Updates #2898.
An address must be loaded to a register according to the code model.
Add LADDR define for use in assembler code.
Update #3433.
Update #3433.
See also RISC-V User-Level ISA V2.3, comment in section 8.2
"Load-Reserved/Store-Conditional Instructions".
Update #3433.
Update #3433.
Update #3433.
Update #3433.
Update #3433.
Update #3433.
Update #3433.
Update #3433.
Save/restore non-volatile registers in _CPU_Context_switch().
Save/restore volatile registers in _ISR_Handler().
Update #3433.
Update #3433.
Update #3433.
Update #3433.
Move SREG and LREG assembler defines to <rtems/score/asm.h>.
Update #3433.
Update #3433.
The mstatus register contains no thread-specific state which must be
saved/restored during a context switch. Machine interrupts (MIE) must
be enabled during a context switch.
Create separate CPU_Interrupt_frame structure.
Update #3433.
The RISC-V psABI
https://github.com/riscv/riscv-elf-psabi-doc/blob/master/riscv-elf.md
does not mention that this is a frame pointer.
Update #3433.
Update #3433.
Do not clear the complete thread context. Initialize only the necessary
members. The Context_Control::is_executing member must be preserved
across _CPU_Context_Initialize() calls.
Update #3433.
According to the RISC-V psABI
the stack alignment is 128 bits (16 bytes).
Update #3433.
The current ABI says that there is no stack red zone:
"Procedures must not rely upon the persistence of stack-allocated data
whose addresses lie below the stack pointer."
Update #3433.
The code sequence is derived from the ARM code
(see _ARMV4_Exception_interrupt).
Update #2751.
Update #3433.
Update #3433.
Remove <rtems/score/riscv-utility.h> include from <rtems/score/cpu.h>
(which is visible via <rtems.h> for example).
Update #3433.
Use the atomic read and clear operation to disable interrupts.
Do not write the complete mstatus. Instead, set only the MIE bit
depending on the level parameter.
Update #3433.
