This file is BSP-independent.
Update #3285.
The definition of _CPU_Trap_slot_template is BSP-independent. A
potential para-virtualization support may use <rtems/score/paravirt.h>.
Update #3285.
The following code
void f(void)
register int i;
gives a warning with GCC and -std=c++17
test.cc: In function ‘void f()’:
test.cc:3:15: warning: ISO C++1z does not allow ‘register’ storage class
specifier [-Wregister]
register int i;
and clang with -std=c++14
test.cc:3:3: warning: 'register' storage class specifier is deprecated
and incompatible with C++1z [-Wdeprecated-register]
register int i;
1 warning generated.
Remove the use of the register keyword at least in the public header
files for C++ compatibility.
Close #3397.
Update #3117.
Update #3182.
Update #3117.
Update #3182.
When it's a macro, a function declaration causes a compiler error due to the
macro being expanded.
Partial log showing error:
https://gist.github.com/AmaanC/ab3521141479aa6f61ea25f5d74ebb4d
Closes #3331
This change, excluding the #error directive, lets us make progress towards
compiling i386 targets with --enable-smp.
The #error directive needs to be there since the CPU_Interrupt_frame is used by
the SMP context switching code, and this placeholder struct, if used, would only
lead to more subtle bugs and errors. With the directive, the SMP context
switching code can be improved separately.
Updates #3331
Closes #3346.
Cannot read or write MSR when executing in user mode. This
is used when RTEMS_PARAVIRT is defined.
Provide alternate methods to disable/enable interrupts
Closes #3306.
Closes #3305.
Update #3285.
Update #3285.
Updates #3327.
Updates #3327.
Updates #3327.
Updates #3327.
Updates #3327.
Updates #3327.
Updates #3327.
Updates #3327.
Updates #3327.
Updates #3327.
Updates #3327.
Updates #3327.
Updates #3327.
Updates #3327.
Updates #3327.
Updates #3327.
Updates #3327.
Updates #3327.
Updates #3327.
Use _Thread_Dispatch_direct() for operations that block the executing
thread. This ensures that we get a fatal error
(INTERNAL_ERROR_BAD_THREAD_DISPATCH_DISABLE_LEVEL) if we try to block in
an invalid context, e.g. during system start or an interrupt handler.
Update #2843.
Rename PER_CPU_WATCHDOG_MONOTONIC to PER_CPU_WATCHDOG_TICKS. Add new
PER_CPU_WATCHDOG_MONOTONIC which is based on the system uptime (measured
by timecounter).
Close #3264.
Rename _Watchdog_Realtime_from_*() to _Watchdog_Ticks_from_*().
Update #3264.
Avoid unnecessary lock acquire/release operations. Get realtime via
timecounter only if necessary.
Update #3264.
At least with Binutils 2.30 and GCC 7.3 we need symbol definitions
without the leading underscore.
Fixed in Newlib 1658a57715de93d50983f34e75216101eb373993.
GCC 7.3 defines __USER_LABEL_PREFIX__ to nothing.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Update #3085.
Update #3254.
Update #3260.
Update #3254.
Update #3254.
Use a self-contained recursive mutex for API_Mutex_Control. The API
mutexes are protected against asynchronous thread cancellation.
Add dedicated mutexes for libatomic and TOD.
Close #2629.
Close #2630.
