Simplify object name to identifier directives. Using
_RTEMS_Name_to_id() to implement the directives enables a tail call
optimization.
Change license to BSD-2-Clause according to file history.
Update #3053.
Prefer macros with a proper namespace.
Make sure that the esp is restored before the eflags register.
When the init task is initially restored, system interrupts are activated when the
eflags register is loaded.
If the esp register still points to an address in the interrupt stack
area (from early system initlization) the ISR might overwrite its own
stack.
Closes #4031
Due to an unmaintained toolchain (internal errors in GCC, no FSF GDB
integration) the Epiphany architecture was obsoleted in RTEMS 5.1.
Update #3941.
Update #3943.
Update #4018.
This introduces the CPU_USE_LIBC_INIT_FINI_ARRAY define for use by CPU
ports to determine which global constructor and destructor methods are
used instead of placing architecture defines where they shouldn't be.
Close #4018
- Defines CPU_Interrupt_frame in cpu_impl.h
- Updates isq_asm.S to save/restore registers in matching order to
interrupt frame
Uses similar flow in cpu_asm.S for i386 as for arm.
Create a GS segment in the GDT for each processor for storing TLS.
This makes the GDT in startAP.S obsolete as all processors now share the
same GDT, which is passed to each AP at startup.
The correct segment for each processor is calculated in cpu_asm.S.
Update #3335
Store the stack pointer of the exception context to the exception frame.
Close #3987.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Close #3949.
Update #3949.
This reverts commit 8e80876bdd54e36fb668eee655eec1dd588daf13
which broke several architectures.
The _ISR_Stack_area_begin and _ISR_Stack_area_end symbols are in
different sections. They must have the same alignment, otherwise the
following linker directive could separate them:
*(SORT_BY_ALIGNMENT (SORT_BY_NAME (.rtemsstack*)))
Update #3799.
Statically initialize the ARMv7-M vector table to allow a placement in
ROM with read-only MPU settings.
Change licence to BSD-2-Clause in some files.
Update #3904.
In uniprocessor and SMP configurations, the context switch extensions
were called during _Thread_Do_dispatch():
void _Thread_Do_dispatch( Per_CPU_Control *cpu_self, ISR_Level level )
Thread_Control *executing;
executing = cpu_self->executing;
do {
Thread_Control *heir;
heir = _Thread_Get_heir_and_make_it_executing( cpu_self );
_User_extensions_Thread_switch( executing, heir );
_Context_Switch( &executing->Registers, &heir->Registers );
} while ( cpu_self->dispatch_necessary );
In uniprocessor configurations, this is fine and the context switch
extensions are called for all thread switches except the very first
thread switch to the initialization thread. However, in SMP
configurations, the context switch may be invalidated and updated in the
low-level _Context_Switch() routine. See:
https://docs.rtems.org/branches/master/c-user/symmetric_multiprocessing_services.html#thread-dispatch-details
In case such an update happens, a thread will execute on the processor
which was not seen in the previous call of the context switch
extensions. This can confuse for example event record consumers which
use events generated by a context switch extension.
Fixing this is not straight forward. The context switch extensions call
must move after the low-level context switch. The problem here is that
we may end up in _Thread_Handler(). Adding the context switch
extensions call to _Thread_Handler() covers now also the thread switch
to the initialization thread. We also have to save the last executing
thread (ancestor) of the processor. Registers or the stack cannot be
used for this purpose. We have to add it to the per-processor
information. Existing extensions may be affected, since now context
switch extensions use the stack of the heir thread. The stack checker
is affected by this.
Calling the thread switch extensions in the low-level context switch is
difficult since at this point an intermediate stack is used which is
only large enough to enable servicing of interrupts.
Update #3885.
Update #3835.
If the non-preempt mode for threads is supported depends on the
scheduler implementation. Add
_Scheduler_Is_non_preempt_mode_supported() to indicate this.
Update #3876.
Test for the proper system condition instead of using the
rtems_configuration_is_smp_enabled() workaround.
Update #3876.
Move the unified workspace configuration constant out of the
configuration table.
Provide a default definition of the unified workspace constant.
Update #3875.
Move the idle thread body configuration constant out of the
Provide a default definition of the idle thread body constant.
Update #3875.
Move the idle thread stack size configuration constant out of the
Add THREAD_IDLE_STACK_SIZE_DEFAULT and use it to provide a default
definition of the idle thread stack size constant.
Update #3875.
Move the ticks per timeslice configuration constant out of the
Add WATCHDOG_TICKS_PER_TIMESLICE_DEFAULT and use it to provide a default
definition of the watchdog ticks per timeslice constant.
Update #3875.
Remove DEBUG_WORKSPACE support. There are better ways to trace the
application. See Tracing chapter in the RTEMS User Manual.
Remove superfluous includes. Change format.
Allocate new thread queue heads during objects information extend. This
removes an error case and the last dependency on the workspace in
_Thread_Initialize().
Update #3835.
Update #3835.
Update #3835.
Update #3835.
Return block index in _Objects_Extend_information(). This allows to
customize the objects information extend.
Update #3835.
This function is simple enough to be inlined.
Update #3835.
Split up the different objects free methods into separate functions.
This helps to avoid a dependency on the workspace in case no objects or
a static set of objects is configured.
Update #3835.
Split up the different objects allocation methods into separate
functions. This helps to avoid a dependency on the workspace in case no
objects or a static set of objects is configured.
Change license to BSD-2-Clause according to file histories.
Update #3053.
Update #3835.
This is a preparation to allow a customization of the objects
information extend.
Update #3835.
Place idle and MPCI stacks into extra linker sections. This can be
optionally used by applications to control the placement of the stacks.
Update #3835.
Move thread stack allocation to caller side of _Thread_Initialize().
Update #3835.
Update #3835.
Add the Thread_Configuration structure to reduce the parameter count of
_Thread_Initialize(). This makes it easier to add more parameters in
the future. It simplifies the code generation since most architectures
do not have that many registers available for function parameters.
Update #3835.
This allows the linker garbage collection to perform its work.
Update #3835.
Use the stack area to allocate the TLS area.
Update #3835.
Use the stack area to allocate the FP context. This considerably
simplifies the application configuration since the task count no longer
influences the configured work space size. With this change the stack
space size is overestimated since an FP context for each thread is
accounted. Memory constraint applications can use the stack size for
fine tuning.
Update #3835.
This call is superfluous since _Thread_Initialize() will do this also.
Update #3835.
Update #3835.
Remove superfluous Thread_Control::Start::stack member.
Update #3835.
