The Cortex-R52 does not support cache coherency and the shareable memory
attribute. If a region is configured to be shareable, then it falls
back to use non-cacheable memory.
Update #4202.
Update #4202.
Update #4202.
Disable the alignment check through SCTLR[A] in
_AArch32_PMSA_Initialize().
Update #4202.
This change allows for the migration of higher priority tasks on the
arrival of a lower priority task limited by affinity constraints.
Change license to BSD-2-Clause according to file history and
re-licensing agreement.
Update #3053.
Move _ISR_Handler() to a separate file since it is now only used if a handler
is installed by _CPU_ISR_install_raw_handler().
Statically initialize the traps for external interrupts to use the new
_SPARC_Interrupt_trap() which directly dispatches the interrupt handlers
installed by rtems_interrupt_handler_install() via the BSP-provided
_SPARC_Interrupt_dispatch().
Since the trap table is now fully statically initialized, there is no longer a
dependency on the Cache Manager in the default configuration.
Update #4458.
This makes them usable in multiple files.
Update #4458.
Statically initialize the trap table in start.S to jump to _SPARC_Bad_trap()
for all unexpected traps. This enables a proper RTEMS fatal error handling
right from the start. Do not rely on the stack and register settings which
caused an unexpected trap. Use the ISR stack of the processor to do the fatal
error handling. Save the full context which caused the trap. Fatal error
handler may use it for error logging.
Unify the _CPU_Exception_frame_print() implementations and move it to cpukit.
Update #4459.
Move _CPU_ISR_install_raw_handler() and _CPU_ISR_install_vector() to separate
files. The goal is to make their use optional.
Update #4458.
Update #4459.
The _ISR_Handler_initialization() does not touch the _ISR_Vector_table[]. Move
the definition of _ISR_Vector_table[] to a separate file.
Change license to BSD-2-Clause according to file history and re-licensing
agreement.
Update #3053.
This variable is actually contained in _Per_CPU_Information[] which is already
zero initialized.
Remove superfluous includes.
This CPU port macro was not used. Since the _ISR_Vector_table[] is statically
allocated, CPU ports could initialize this table in _CPU_Initialize() if
necessary. Remove _CPU_Initialize_vectors() to simplify the CPU port
interface.
The write to RBAR didn't have the valid flag set. Therefore the write to
RASR had an influence on the previously set region. That means for
example that if Region 0 had been enabled but 1 should be disabled due
to a size of 0, the previous code would have disabled region 0 instead.
This patch fixes that behaviour.
Close #4450
Don't initialze regions that have a negative size (for example due to a
wrong calculation).
Update #4450
Update #4202.
The change also helps to avoid reports from static analysers since most
callers of _Thread_queue_Make_ready_again() check the unblock status.
Make the initialization of the per-CPU data optional.
Update #3053.
Set Thread_queue_Context::timeout_absolute in
_Thread_queue_Context_set_timeout_argument() to avoid using it uninitialized.
The bug was introduced by a89ecaa1a94d49ddae7753d6b83923e9d2a00486.
Created futimens.c and utimensat.c to add support for the POSIX
methods futimens() and utimensat().
utime() and utimes() are considered obsolote by POSIX, but RTEMS
will continue to support them.
Closes #4396
Currently, the AArch64 BSPs have a hard time running on real hardware
without building the toolchain and the bsps with -mstrict-align in
multiple places. Configuring the MMU on these chips allows for unaligned
memory accesses for non-device memory which avoids requiring strict
alignment in the toolchain and in the BSPs themselves.
In writing this driver, it was found that the synchronous exception
handling code needed to be rewritten since it relied on clearing SCTLR_EL1 to
avoid thread stack misalignments in RTEMS_DEBUG mode. This is now
avoided by exactly preserving thread mode stack and flags and the new
implementation is compatible with the draft information provided on the
mailing list covering the Exception Management API.
Break out system register definitions and accessors so that they're
usable by other parts of RTEMS.
Ensure the stack remains aligned by keeping the context frame at a
multiple of 16 bytes. This avoids stack alignment exceptions which occur
when the stack pointer is not 16 byte aligned.
Commit 73ebf9a27ed5cd0fd3e0dc0da98345d7faa610a2 accidentally removed the
direct thread dispatch in a self thread restart. In case of a self
restart (always in task context) the directive shall not return. If
this is not possible due to a bad thread dispatch disable level, then a
fatal error shall occur.
Update #4412.
The _Thread_Cancel() (in contrast to _Thread_Restart() which used a
similar code block) may have produced ready threads with an active timer
in case the thread to cancel had its thread life protection enabled. The
problem was this code block:
Priority_Control priority;
_Thread_Add_life_change_request( the_thread );
if ( _Thread_Is_life_change_allowed( previous ) ) {
_Thread_State_release( the_thread, &lock_context );
_Thread_queue_Extract_with_proxy( the_thread );
_Thread_Timer_remove( the_thread );
} else {
_Thread_Clear_state_locked( the_thread, STATES_SUSPENDED );
priority = _Thread_Get_priority( executing );
_Thread_Raise_real_priority( the_thread, priority );
_Thread_Remove_life_change_request( the_thread );
The life change request should only be added/removed if a life change is
allowed (see _Thread_Restart()). Add _Thread_Try_life_change_request()
and use it in _Thread_Cancel() and _Thread_Restart().
Close #4435.
Move common code into _Thread_Exit(). This enables a tail call
optimization in most cases.
Add Thread_queue_Context::timeout_absolute to specify an absolute or
relative timeout. This avoid having to get the current time twice for
timeouts relative to the current time. It moves also functionality to
common code.
The __builtin_unreachable() cannot be used with current GCC versions to
tell the compiler that a function does not return to the caller, see:
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=99151
Add a no return variant of _CPU_Context_switch() to avoid generation of
dead code in _Thread_Start_multitasking() if RTEMS was built with SMP
support enabled.
Move this diagnostic function to a separate file since it does not
provide a core function of the system.
Update #3053.
Add _Per_CPU_Is_ISR_in_progress() as an optimized version of
_ISR_Is_in_progress().
rtems_task_restart() may be called from within interrupt context. So
checking only that the thread to restart is equal to the executing
thread is insufficient to determine a self restart. We have to also
check that no ISR is in progress. Merge _Thread_Restart_other() and
_Thread_Restart_self() into one _Thread_Restart() since they share a lot
of common code.
Close #4412.
Unconditionally set the real priority of the task to its initial
priority during a task restart.
Close #4411.
This simplifies rtems_task_restart().
Use _Objects_Free_nothing() for rtems_message_queue_construct() to avoid
unreachable code in _CORE_message_queue_Close() in case only
user-provided message buffers are used.
Update #4007.
Rename _Stack_Free_nothing() in _Objects_Free_nothing() to make it
reusable for the message queue buffers.
Update #4007.
These two functions are no longer used outside of _Once().
Add a no return variant of _Thread_Dispatch_direct() to avoid generation
of dead code.
This may reduce the code size a bit.
CID 26033: Dereference after null check in _Objects_Extend_information().
Closes #4326
This avoids having conditional statements to get the API-specific status
code.
code.
In case the processor set is not large enough to contain the processor
affinity set of the task return RTEMS_INVALID_SIZE instead of
RTEMS_INVALID_NUMBER. This is more in line with other directives since
the issue is related to the size of an object.
Close #4393.
code.
Last use was removed by:
commit 54550e048d3a49435912797d2024f80671e93267
Author: Sebastian Huber <sebastian.huber@embedded-brains.de>
Date: Fri May 13 08:16:30 2016 +0200
posix: Rework pthread_join()
Rework pthread_join() to use _Thread_Join().
The _CPU_ISR_Is_enabled() function operates on ISR cookies and so must
mask off the appropriate status bits. This also fixes the naming of the
parameters of the _CPU_ISR_* functions to indicate use of ISR cookies
instead of interrupt enable/disable levels.
Replace Objects_Name_or_id_lookup_errors with new Status_Control codes.
Get rid of the _Status_Object_name_errors_to_status lookup table.
Do not adjust the stack area begin address since this may confuse the
stack allocator and result in failed stack frees.
Account for the alignment overhead in the stack space size estimate.
Check that the stack size is in the expected interval.
