* Makefile.am: Re-add dirstamps to PREINSTALL_FILES.
Add PREINSTALL_FILES to CLEANFILES.
Add cpuopts.h to DISTCLEANFILES.
* configure.ac: Requires automake >= 1.8.1.
* cpu/Makefile.am: Use @RTEMS_CPU@ instead of $(RTEMS_CPU).
* Makefile.am: Include compile.am, again.
* macros/rtems/score/README: Remove (Redundant with macros/README).
* Makefile.am: Convert to using automake compilation rules.
* Makefile.am: Add libs to CLEANFILES
Set lib*_g_a_SOURCES = lib*_a_SOURCES.
* Makefile.am: Build libscore$(LIB_VARIANT).a instead of
$(ARCH)/libscore.a.
* qsm.h, sim.h: Remove efi68k and efi332 references as they are no
longer in the tree.
* rtems/score/mips.h: Removed junk revision line.
* cpu/Makefile.am: mips64orion port removed as mips port more
completely covers the MIPS family.
* cpu/mips64orion/.cvsignore, cpu/mips64orion/ChangeLog,
cpu/mips64orion/Makefile.am, cpu/mips64orion/asm.h,
cpu/mips64orion/configure.ac, cpu/mips64orion/cpu.c,
cpu/mips64orion/cpu_asm.S, cpu/mips64orion/cpu_asm.h,
cpu/mips64orion/idtcpu.h, cpu/mips64orion/idtmon.h,
cpu/mips64orion/iregdef.h, cpu/mips64orion/rtems/.cvsignore,
cpu/mips64orion/rtems/score/.cvsignore,
cpu/mips64orion/rtems/score/cpu.h,
cpu/mips64orion/rtems/score/mips64orion.h,
cpu/mips64orion/rtems/score/types.h: Removed.
* Makefile.am: Build library using EXTRA_LIBRARIES and automake rules.
PR 533/bsps
* startup/linkcmds: Update linkcmds for gcc 3.3.2.
* Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* Makefile.am: Use mkdir_p. Remove dirs from PREINSTALL_FILES.
* Makefile.am:Restore further parts having been lost.
* Makefile.am: Restore file having been broken in last commit.
* Makefile.am: Remove TMPINSTALL_FILES.
* Makefile.am: Add $(dirstamp) to preinstallation rules.
Remove MACROS.
Remove MACROS.
PR 526/rtems
* src/threadcreateidle.c: Idle task name should be a string and
PR484 broke this.
PR 525/rtems
* include/rtems/system.h: Use RTEMS_INLINES instead of USE_INLINES.
* include/rtems/score/chain.h: Ditto.
* include/rtems/score/thread.h: Ditto.
* src/chain.c: Ditto.
* src/coremutexseize.c: Ditto.
* src/threadget.c: Ditto.
* Makefile.am: Remove all LIB-related rules.
* Makefile.am: Don't use gmake to preinstall.
* Makefile.am: Don't use gmake rules for preinstallation.
* configure.ac: Remove RTEMS_CANONICAL_HOST.
* configure.ac: Remove RTEMS_CHECK_CPU.
* src/coremsgseize.c, src/coremsgsubmit.c:
Remove unnecessary typecasts in assignments to
thread->Wait.return_argument.
PR 504/rtems
* include/rtems/score/coremutex.h: Add fatal error check for a task
blocking on a mutex when thread dispatching is disabled.
* rtems/new-exceptions/cpu.h, rtems/old-exceptions/cpu.h: Obsoleting HP
PA-RISC port and removing all references.
* rtems/score/cpu.h: Obsoleting HP PA-RISC port and removing all
references.
* cpu/hppa1.1/.cvsignore, cpu/hppa1.1/ChangeLog,
cpu/hppa1.1/Makefile.am, cpu/hppa1.1/configure.ac, cpu/hppa1.1/cpu.c,
cpu/hppa1.1/cpu_asm.S, cpu/hppa1.1/rtems/.cvsignore,
cpu/hppa1.1/rtems/score/.cvsignore, cpu/hppa1.1/rtems/score/cpu.h,
cpu/hppa1.1/rtems/score/cpu_asm.h, cpu/hppa1.1/rtems/score/hppa.h,
cpu/hppa1.1/rtems/score/types.h: Removed.
PR 489/rtems
* include/rtems/score/thread.h: Change struct
Thread_Control_struct.libc_reent to using struct _reent*.
* inline/rtems/score/thread.inl: Reflect change above.
PR 484/rtems
* src/threadcreateidle.c: Idle task name was initialized incorrectly.
* inline/rtems/score/userext.inl, macros/rtems/score/userext.inl:
Add missing cast.
* cpu.c, rtems/score/cpu.h, rtems/score/types.h, rtems/score/unix.h:
* cpu.c, cpu_asm.S, rtems/score/cpu.h, rtems/score/sparc.h,
rtems/score/types.h: URL for license changed.
* asm.h, cpu.c, rtems/score/cpu.h, rtems/score/sh.h,
rtems/score/sh_io.h, rtems/score/types.h: URL for license changed.
* rtems/new-exceptions/cpu.h, rtems/old-exceptions/cpu.h,
rtems/powerpc/registers.h, rtems/score/ppc.h, rtems/score/types.h:
* cpu.c, cpu_asm.c, rtems/score/cpu.h, rtems/score/cpu_asm.h,
rtems/score/or32.h, rtems/score/types.h: URL for license changed.
rtems/score/no_cpu.h, rtems/score/types.h: URL for license changed.
* cpu.c, cpu_asm.S, cpu_asm.h, rtems/score/cpu.h,
rtems/score/mips64orion.h, rtems/score/types.h: URL for license
changed.
* cpu.c, cpu_asm.S, rtems/score/cpu.h, rtems/score/mips.h,
* cpu.c, cpu_asm.S, rtems/score/cpu.h, rtems/score/m68k.h,
* cpu.c, cpu_asm.S, rtems/score/cpu.h, rtems/score/i960.h,
