* rtems/old-exceptions/cpu.h (PPC_Get_timebase_register): Remove.
* rtems/powerpc/registers.h (PPC_Get_timebase_register,
PPC_Set_timebase_register): Remove.
* rtems/score/cpu.h (PPC_Get_timebase_register,
PPC_Set_timebase_register): New.
* rtems/powerpc/registers.h (PPC_Set_decrementer,
PPC_Get_decrementer): Remove.
* rtems/old-exceptions/cpu.h (PPC_Set_decrementer): Remove.
* rtems/score/cpu.h (PPC_Set_decrementer, PPC_Get_decrementer): New.
* rtems/old-exceptions/cpu.h (CPU_Get_timebase_low, rtems_bsp_delay,
rtems_bsp_delay_in_bus_cycles): Remove.
* rtems/powerpc/registers.h (CPU_Get_timebase_low, rtems_bsp_delay,
* rtems/score/cpu.h (CPU_Get_timebase_low, rtems_bsp_delay,
rtems_bsp_delay_in_bus_cycles): New.
rtems_cpu_configuration_get_exceptions_in_ram): New.
rtems_cpu_configuration_get_exceptions_in_ram): Remove.
* rtems/new-exceptions/cpu.h
(rtems_cpu_configuration_get_clicks_per_usec,
* rtems/score/cpu.h
* rtems/new-exceptions/cpu.h (CPU_swap_u32, CPU_swap_u16): Remove.
* rtems/old-exceptions/cpu.h (CPU_swap_u32, CPU_swap_u16): Remove.
* rtems/score/cpu.h (CPU_swap_u32, CPU_swap_u16): New.
* rtems/old-exceptions/cpu.h: Add _CPU_MSG_GET
(old/new exception processing ABI compatibility).
* rtems/powerpc/registers.h: Use C99 fixed size types.
* rtems/score/powerpc.h: Add __ALTIVEC__ support.
* rtems/score/powerpc.h: Merge ppc603 and ppc603e
PPC_IRQ_*/PPC_TLB_* defines.
* rtems/score/powerpc.h (mpc8260): PPC_ALIGNMENT 8.
* rtems/score/powerpc.h: Remove PPC_HAS_RFCI (Unused).
* rtems/score/powerp.c: Remove PPC_HAS_EXCEPTION_PREFIX (Unused).
* rtems/score/powerpc.h: Remove PPC_CACHE_ALIGN_POWER (Unused).
* rtems/score/powerpc.h: Remove PPC_LOW_POWER_MODE* (Unused).
* rtems/score/powerpc.h: Remove PPC_USE_MULTIPLE (Unused).
* rtems/score/powerpc.h: Remove PPC_D_CACHE, PPC_I_CACHE defines.
* rtems/score/powerpc.h: Remove PPC_MSR_* defines.
* rtems/old-exceptions/cpu.h: Add _PPC_MSR_DISABLE_MASK.
Use _PPC_MSR_DISABLE_MASK instead of PPC_MSR_DISABLE_MASK to set up
_disable_mask.
* cpu.c: New (Stub file for consistency with other ports).
PR 753/rtems
* score/include/rtems/score/object.h,
score/src/objectinitializeinformation.c: Configured number of objects
needs to be of a type with more bits than Objects_Maximum to support
configuring unlimited objects. The type for configuring the maximum
number of objects should probably always be the same fundamental type
as Object Id. For 16-bit Id configurations, the constant
OBJECTS_UNLIMITED_OBJECTS was changed to 0x8000 to move in this
direction.
* rtems/asm.h, rtems/old-exceptions/cpu.h, rtems/score/powerpc.h:
Remove PPC_ABI_POWEROPEN.
* rtems/score/powerpc.h: Remove hard-coded PPC_HAS_FPU.
Tie PPC_HAS_FPU to _SOFT_FLOAT.
* rtems/old-exceptions/cpu.h, rtems/score/powerpc.h:
Remove PPC_ABI_GCC27.
* rtems/asm.h, rtems/score/powerpc.h: Remove XCOFF support.
* Makefile.am: Split out preinstallation rules.
* preinstall.am: New (Split out from Makefile.am).
* rtems/mips/idtcpu.h, rtems/mips/iregdef.h, rtems/score/mips.h:
Header guards cleanup.
* rtems/m68k/m68302.h, rtems/m68k/m68360.h, rtems/m68k/qsm.h,
rtems/m68k/sim.h, rtems/score/m68k.h: Header guards cleanup.
PR 754/rtems
* rtems/asm.h: New (relocated from .).
* asm.h: Remove (moved to rtems/asm.h).
PR rtems/752
* rtems/tic4x/c4xio.h: New (relocated from .).
New header guard.
* c4xio.h: Remove.
PR rtems/752
* rtems/mips/idtcpu.h rtems/mips/iregdef.h: New (relocated from .).
New header guards.
* idtcpu.h, iregdef.h: Remove.
PR rtems/752
rtems/m68k/sim.h: New (relocated from .).
* m68302.h, m68360.h, qsm.h, sim.h: Remove.
