* | + Added object type field to object id. | Joel Sherrill | 1995-08-18 | 4 | -21/+102 |
| | | | | | | | | + Added name pointer to Object_Control. + Modified Object Open and Close to address name field. + Removed name as separate element from Thread and Proxy Control. | ||||
* | Numerous miscellaneous features incorporated from Tony Bennett | Joel Sherrill | 1995-08-17 | 4 | -2/+101 |
| | | | | | | | | | (tbennett@divnc.com) including the following major additions: + variable length messages + named devices + debug monitor + association tables/variables | ||||
* | bug fixes to make macro implementations work | Joel Sherrill | 1995-08-16 | 11 | -74/+23 |
* | added constant for number of notepads | Joel Sherrill | 1995-08-11 | 1 | -8/+10 |
* | cleanup and optimization from Tony | Joel Sherrill | 1995-08-04 | 1 | -12/+18 |
* | *** empty log message *** | Joel Sherrill | 1995-08-02 | 1 | -1/+0 |
* | Switched to events for mp receive server and eliminated the special | Joel Sherrill | 1995-07-31 | 4 | -92/+3 |
| | | | | blocking mechanism for it. | ||||
* | after testing go32 and cvme961 | Joel Sherrill | 1995-07-21 | 1 | -1/+8 |
* | fixed for Linux | Joel Sherrill | 1995-07-18 | 1 | -13/+24 |
* | merged Linux UNIX simulator support (C) | Joel Sherrill | 1995-07-18 | 2 | -2/+23 |
* | Ada95, gnat, go32 | Joel Sherrill | 1995-07-12 | 8 | -359/+551 |
* | added David Glessner's 68302 work. | Joel Sherrill | 1995-06-14 | 1 | -5/+5 |
* | corrected pseudo-code for _ISR_Handler | Joel Sherrill | 1995-06-07 | 1 | -5/+17 |
* | incorporated mc68302 support | Joel Sherrill | 1995-06-07 | 3 | -0/+1239 |
* | changed release number to 3.2.0 | Joel Sherrill | 1995-06-04 | 2 | -11/+12 |
* | TEST | Joel Sherrill | 1995-05-25 | 1 | -0/+2 |
* | Fully tested on all in-house targets | Joel Sherrill | 1995-05-24 | 14 | -171/+104 |
* | Initial revision | Joel Sherrill | 1995-05-11 | 88 | -0/+16347 |
