The Per_CPU_Control::isr_dispatch_disable is a 32-bit integer.
Close #4206.
Make sure that a user-provided stack size is the minimum size allocated
for the stack.
Make sure we meet the stack alignment requirement also for CPU ports
with CPU_STACK_ALIGNMENT > CPU_HEAP_ALIGNMENT.
Clarify CPU_STACK_ALIGNMENT requirements in no_cpu port. Add static
assertion to enforce CPU_STACK_ALIGNMENT requirements.
Remove superfluous check for the objects maximum since the maximum is
also used as a loop limit.
Fix formatting.
Close the thread object if a thread create extension fails. Also call
the delete extension to avoid resource leaks in early extensions if a
late extension fails.
Close #4270.
Update #4267.
Update #4267.
Call _Thread_queue_Flush_critical() directly.
Use the number of threads which must arrive at the barrier to trip the
automatic release also to indicate if the barrier is a manual release
barrier.
Use the type safe _Objects_Open_u32() instead. Return the object
identifier to enforce a common usage pattern.
Require that the corresponding lock is acquired before the action
handler returns. This helps to avoid recursion in the signal
processing.
Update #4244.
This fixes a missing decrement of the number of waiting threads during a
barrier wait timeout.
Close #4230.
Update #4230.
Update #4230.
Rename _Nios2_ISR_Dispatch_with_shadow_non_preemptive() in
_Nios2_ISR_Dispatch_with_shadow_register_set(). Remove
_Nios2_ISR_Dispatch_with_shadow_preemptive().
Use _Thread_Do_dispatch() in
_Nios2_ISR_Dispatch_with_shadow_non_preemptive().
Update #4214.
This allows the BSP to override this function.
The thread dispatch disabled level moved to _Per_CPU_Information some
time ago.
This fix relates to a Coverity issue (UNUSED_VALUE).
This fix relates to a Coverity issue (PW.SET_BUT_NOT_USED).
This fix relates to a Coverity issue (PW.DECLARED_BUT_NOT_REFERENCED).
This fix relates to a Coverity issue (NESTING_INDENT_MISMATCH).
We do not need all the checks if we have a valid indentifier to a thread
class object.
Using the new _Thread_Get_objects_information() instead of the inline
function _Thread_Get_objects_information_by_id() avoids dead code since
the identifier in a thread control is always valid and the return NULL
path in _Thread_Get_objects_information_by_id() would be dead code. The
_Thread_Get_objects_information_by_id() should be an inline function
since it is used by _Thread_Get() and thus performance critical. Static
analyzers which cannot derive that the identifier in a thread control is
always valid, may find a potential NULL pointer access (or otherwise
find dead code).
The identifier in an object control is always valid, see
_Objects_Initialize_information() and _Objects_Extend_information().
Move _RTEMS_tasks_Free() to the only source file which calls this
function.
Rename _Thread_Get_objects_information() in
_Thread_Get_objects_information_by_id() to emphasize that this thread
method uses an object identifier and not a thread control.
Update #4202.
Update #4202.
Update #4202.
Somehow the table index has been missing in the latest patch version.
With that, the configuration for the first region has been applied
multiple times.
Update #4180
Update #4202.
This is the behaviour document in the RTEMS Classic API Guide.
Use common phrases for the file brief descriptions.
Update #3706.
This resolves a warning in the exception frame dump for AArch64 relating
to a missized printf format specifier.
Modify the MPU functions of the stm32h7 BSP to be table based and
available for all ARMV7M BSPs.
Update #4180
Register a custom task stack allocator initialization handler only if
necessary.
Replace runtime checks with compile time assertions. This makes the
INTERNAL_ERROR_BAD_STACK_HOOK obsolete.
This ensures that the saved SP register is sized appropriately depending
on the chosen ABI and prevents a warning in the libmisc stack checker.
Update #4171.
Update #4171.
Update #4171.
Clarify Doxygen comments. Fix formatting.
Update #4171.
